How to force the notification to turn on from the server not the client?
uint16_t buffer[4];
buffer[0] = p_nus->handles1.cccd_handle;                  // cccd handle
buffer[1] = 2;                                            // cccd attribute size = 2
buffer[2] = 1;                                            // 1 = enable notifications
buffer[3] = crc16_compute((uint8_t *)buffer, 6, NULL);     // CRC-CCITT (0xFFFF)
err_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.gap_evt.conn_handle, (uint8_t*)(buffer), 8, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
if(err_code == NRF_SUCCESS)
    p_client->is_notification_enabled1 = true;  // Enable notification
I add this code in 'static void on_connect(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt) '  on the sever. But I still got an err_code NRF_ERROR_INVALID_DATA. Softdevice is s132nrf52611. Any suggestions to force the notification? I use the SDK version 15.3.0.
  • Thank you for your reply. But It's not automatic reconnection, it's automatic notify
    No problem at all, I am happy to help!
    My apologies, I should have been more explicit in my previous reply.
    There is no way for a peripheral to force the central to enable notifications. The only possibility here is to have the central enable notifications for specific services / characteristics.
    The nRF Connect for Desktop application with its accompanying connectivity firmware does not support automatic enabling of notification following service discovery.
    The desktop application provides a GUI button for doing this.
    However, if you are creating your own desktop application, you can easily have your central device automatically enable notifications.
    This is demonstrated in the Heart Rate Collector example in the pc-ble-driver github repository. For your application, it sounds like you should take a look at what happens following a CONNECTED event, particularly in the function hrm_cccd_set.
    Please let me know if anything still should be unclear, or if you have any other questions!
    Karl
  • Hi Karl
    Thank you for your detailed explanation again. This time I know it clearly.
    This means that notification can only be enabled on peripheral devices by a central device or mobile phone, right?
  • But I did add the above code in the sample program, which has the effect of forcing the peripheral device to turn on the notification and upload data after the mobile phone is connected with it. And the mobile app (NRF connect) did not click the enable notification.
    Yes, the peripheral may only tell the central that a service or characteristic it provides uses notification, but the central will need to enable these notifications ( setting CCCD ) before any such notification can be sent from the peripheral, correct.
    Centrals do not do this automatically ( since a peripheral may offer a multitude of characteristics with notification ), but you may program your central to look for a specific service or characteristic, and enable their notifications ( writing to their CCCD ) if they are found - like in the HRM example I linked in my previous reply.
    This sequence chart illustrates how a couple of different notification sequences may look to the server ( peripheral ) device. Notice how the "Notifications enabled in CCCD" always happens before the peripheral may send a notification. If notifications is not enabled, the call to sd_ble_gatts_hvx will return with error code NRF_ERROR_INVALID_STATE.
    Karl
