compiler ERROR UART code
Hi, i have been working on initializing the UART periferial based on the UART example in the SDK5. I got following error.
1> error: unplaced section: .log_dynamic_data_balloc_log_mempool [nrf_log_frontend.o], size=4, align=2
1> error: unplaced section: .log_const_data_app [nrf_log_frontend.o], size=8, align=4
1> error: unplaced section: .nrf_balloc [nrf_log_frontend.o], size=28, align=4
1> error: unplaced section: .log_dynamic_data_app [nrf_log_frontend.o], size=4, align=2
1> error: undefined symbol: __start_log_const_data
1> error: undefined symbol: __start_log_filter_data
I know that i probably missed a header file or something simular but i was not able to find out which.
Please help
    I see you are using the Segger linker, so then this would be different. I do not have any experience with that unfortunately, and it is not used in the SDK example projects (which use the GNU linker). Is there a particular reason you use the SES linker, and organize your project differently than how it is done  in the SDK? In most cases doing it the same way as in the SDK examples make sense as that will save you time, and perhaps more importantly, that is how we test the SDK.
  • No there is no particular reason, I've just started working with the NRF chips and i am a little confused with the workflow. I can change the linker to GNU if it helps. The reason my project is organized this way is because i included the missing header and C files according to the compiler errors,
  • I see. Then I suggest you start of with an SDK example project and adapt that, instead of building the project yourself. Also, starting with a project that use much of the libraries you need will save you the time needed to add all dependencies, configuration macros etc.
  • At some point i will have to add functions from diffrent examples, and i am going to have the same issue. On the long run its going to give problems. All across the devZone you tell people to use the examples but this doesn't seems to be a sustainable workflow, if your developing something new out of the box. Wouldn't it be a goed idea to give a list of header Files in the SDK which are nessesary to use the given SDK function? Nevertheless thanks for the support.
  • I see your point. To be honest the problem is that the way the nRF5 SDK is organized there is a lot of dependencies between modules, with a significant number of files and configuration macros etc, making it tedious to add everything ourselves. That is one of the reasons we recommend starting with an example that is close to what you need - to save time. You will probably have to add more yourself, and remove something, but doing it this way saves time and trouble. (To be more specific, we generate the projects automatically using an internal tool, saving us that work. But this tool is not available to customers.)
    But even if you start off with a minimal example project, I still recommend you follow the same approach as in the SDK examples when adding new libraries/drivers etc, as that way you can copy-past or compare with the configuration of existing examples. Again, this will probably save you time and trouble.
