sd_ble_gap_disconnect returns 0x08, BLE_GAP_EVT_DISCONNECTED never arrives, further attempts to disconnect fail, unable to reconnect - advertising stops.
Hey
I am working on nRF51822 SDK12, S130
I have encountered a problem when connecting and disconnecting from the device at a fast rate, occasionally comes an event in which the sd_ble_gap_disconnect() command fails (the error received is 0x08.), the BLE_GAP_EVT_DISCONNECTED never arrives, the device stops advertising and no longer available to reconnection. the device is gone.
I have tried to disconnect again after a small interval, that does not help.
I have tried to wait for a long time for the BLE_GAP_EVT_DISCONNECTED to arrive, it never arrives.
I have tried to set m_conn_handle = BLE_CONN_HANDLE_INVALID as seen in some thread on the forum. that doesn't help.
nothing works
Any advice will be much appreciated
Thanks!
  • Which softdevice version is this of the S130? I can check for known issues.
    Kenneth
  • Hi Kenneth
    As I said, I have tried to restart the BLE which seems to cause a chip reset, I have seen that the reset to the chip does not occur if I do not initialize my ADC-PPI,
    I have seen in a different Thread a similar issue being raised and the solution was lowering the priority of the ADC interrupt, in my case it is the lowest, so note that does not seem to solve my problem
    Thanks again
  • Hey Kenneth
    An Update regarding the softdevice reset issue, I found out what was missing in my Reinitialization, Now I Reinitialize the softdevice properly and it seems to work, so I just reset the softdevice whenever the disconnect command fails, still, this is not optimal and I would like to know why it fails to begin with (and prevent it ofcourse)
    Thank you
    Hmmm...  what PPI channels did you use here? Is it possible that you are somehow blocking interrupts here and/or possible touching PPI channels used by the softdevice?
    Kenneth
  • Hey
    I use channel the RTC1 channel to the ADC via PPI so:
        uint32_t timer_compare_event_addr = (uint32_t)&NRF_RTC1->EVENTS_COMPARE[2];
        uint32_t adc_sample_event_addr = nrf_drv_adc_start_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, adc_sample_event_addr);  //NRF_ADC->TASKS_START);
    But as I said it seems the this issue was solved by properly reinitializing the Softdevice BLE configuration after the disabling.
    Did you check if it possible that there is some issue with the S130 that explains why the disconnection fails, because I don't want to be coerced to reset the softevice, that is not the greatest solution.
    Thanks!
