How to acheive high data rate?
Is there any difference(data rate) between sending large data packets through single characteristics and multiple characteristics?
I have created one characteristic with notify property and also created a buffer of size 20 bytes(packet size). I did transmitting the buffer until the sent data size reaches 200KB (transmitting in a for loop until the count reaches 10240).
The problem i face here is, time consumption. For me it took ~36 seconds to transmit 200KB of data. Hence i can only achieve the data rate of 5KB per second. I know that the data rate can be achieved using BLE is 2Mbps,1Mbps and 250kbps.
So please suggest me how to achieve the data rates as specified in the BLE document. Actually i need to transmit the 200KB of data within 1 or 2 sec.
I also tried sending the data using 2 different characteristics. Now each will send 20 bytes of data for 5120 times, but the data rate i achieved is same as above.
I also made changes in the minimum connection interval and maximum connection interval to check whether the required data rate is achieved or not , but i did not get any result as i expected. I also attached my testing results. Please suggest me the min and max connection interval need to be set.
Regards, Balaji
  • yep, now i am also losing packets, i created two characteristics each with 20 bytes payload and connection interval of 10ms, i am trying to send each packet for every 1ms, then for 1s i am recieving 45 to 50 packets varying for every second but theoritically i hav to recieve 500 packets but not recieving
    in one case i am getting 30 packets of char.1 and 20 of char.2 and in other case the number is varying but i am not perfectly getting the all packets transmitting. some packets are lost
