What function should be used to associate an interrupt with an event?
I wanted to know the function or functions and the steps to associate an interrupt with an event.
I will be getting a single Pulse(Low To High) which will be my interrupt signal.
I wanted to read this and generate an event to sleep.
Can someone please let me know the step by step function's usage?
    First off, do yourself a favour and use the latest SDK (v17.0.2) as this contains improvements, bug fixes and supports the latest devices. This could save you time and frustration down the road.
    Summarized this example idles in the main loop until it gets an interrupt from the GPIO (button) being toggled, in which case it executes the code inside the event handler.
    RJD said:
    Also how does this line work- nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
     This initates GPIOTE on PIN_IN using the settings in in_config, and triggering an interrupt on the in event which will run the code in in_pin_handler.
    RJD said:
    As in_pin_handler is a function and also not of type  nrfx_gpiote_evt_handler_t   but void
     Not sure why this is done, you can change this if you want.
    RJD said:
    And also why does nrf_drv_gpiote_in_init does throw an error when in_pin_handler is called on being of a void type and not nrfx_gpiote_evt_handler_t
    Not sure what you mean, this builds fine on my side.
    RJD said:
    How are the parameters being passed to in_pin_handler in nrf_drv_gpiote_in_init
    Not sure I understand what you mean. This is handled by the driver though, you should look through the code and documentation.
    RJD said:
    Q3- How and where are the "action" parameter being generated  and passed
    Do you mean what is triggering the event?  This is determined through the settings in the in_config supplied when calling nrf_drv_gpiote_in_init: in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true).
    RJD said:
    Q4- Also how to associate the action(function name(s) too) with an event to put the device to sleep or any other event I want to use it for?
    Not sure I understand, but it is hard to give a generic solution. It depends on what you want to do, but in general when the chip has executed the event handler it will return to the main while loop in this case. To go to sleep you might need to add a __WFE(); in the main loop.
    Andreas
