Struggling with encryption, nrf52840 using ncs 1.3.1
I'm really struggling with encryption, kind of lost in the woods of libraries, api's and documentation. Can anyone point me in the right direction?
Config: I have CONFIG_NORDIC_SECURITY_BACKEND=y set
To start simple, I want to encrypt a block of data using AES.
Using the following code:
u8_t testkey[16] =  { 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5 };
u8_t testiv[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 1, 2, 3, 4, 5, 6 };
u8_t testinput[] = { 't', 'e', 's', 't',0,0,0,0,0,0,0,0,0,0,0,0};
u8_t testoutput[64];
memset(testoutput, 0, sizeof(testoutput));
mbedtls_aes_setkey_enc(&aes, testkey, sizeof(testkey) * 8);
mbedtls_aes_crypt_cbc(&aes, MBEDTLS_AES_ENCRYPT, 16, testiv, testinput, testoutput);
This runs (the two mbedtls functions return 0, all ok), but 'testoutput' does not contain anything (all zero's)
So, I found out about the 'cipher' API (from the nrfconnect crypto test). Created the following code for that:
mbedtls_cipher_init (&ctx);
LOG_DBG("setup %d", mbedtls_cipher_setup (&ctx, mbedtls_cipher_info_from_values(MBEDTLS_CIPHER_ID_AES, sizeof(testkey)*8, MBEDTLS_MODE_ECB)));
LOG_DBG("setkey %d", mbedtls_cipher_setkey (&ctx, testkey, sizeof(testkey)*8, MBEDTLS_ENCRYPT));
LOG_DBG("setiv %d", mbedtls_cipher_set_iv (&ctx, testiv, sizeof(testiv)*8));
LOG_DBG("reset %d", mbedtls_cipher_reset (&ctx));
LOG_DBG("update %d", mbedtls_cipher_update (&ctx, testinput, sizeof(testinput), testoutput,  &r));
LOG_DBG("finish %d", mbedtls_cipher_finish (&ctx, testoutput,  &r));
mbedtls_cipher_free (&ctx);
The mbedtls_cipher_setup call fails with MBEDTLS_ERR_CIPHER_ALLOC_FAILED, so obviously the subsequent calls fail aswell.
So.. help? What am I doing wrong here? Which API should I use, what configuration do I need?
