Sending more than 1 packet per connection with nRF52840
As I'm new to the nRF52840 and Bluetooth, I read documents and DevZone posts related to the bluetooth maximum throughput.
According to the references like Jimmy and Sigurd and so on, it seems that I can get higher throughput if I set MTU to the maximum value and send multiple packets per connection.
The problem is that it was not able for me to find options to enable sending multiple packets.
Currently, I mixed ble_app_uart and saadc examples to get signal and send them via bluetooth. And the data length extension and MTU size are set to the maximum as I know.
And I send data using the following code which is written by another team member
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
Are there any examples sending multiple packets per connection so I can try to implement to mine?
  • P.S. If I reduce the size of data from 240 Bytes to 100 Bytes, 8 packets are sent during a connection. Still far lower than the expected number of packets considering transmission time...
    The actual parameters you get will depend on the configuration and capabilities of both peer devices. So you should expect significant differences between phone models and Android versions, and also other factors that could affect the scheduling on the phone (other BLE devices, and even WiFi traffic etc).
  • The actual parameters you get will depend on the configuration and capabilities of both peer devices.
     As the Android device does not use any WiFi or other Bluetooth device, I cannot expect the cause of sending fewer packets. Does the demo also show a decrease in throughput if it transmits with an Android?
    I see. But regardless of that very few Android devices will allow you to get maximum BLE throughput (what you could achieve by the throughput example and two nRF devices). Which are you using?
    The throughput (and most other factors) depends on the capabilities of the devices. It does not really make sense to talk about Android as a general term when it comes to BLE performance as it varies greatly.
    Knowing which Android device you are testing with and seeing a sniffer trace could explain the performance you get, but there is generally little we can do if the Android device is the limiting factor (which is often the case). That may not be the case here though, so you could set up a test with an nRF on both sides to verify.
  • Which are you using?
    I'm using Samsung Galaxy tab s7+, one of the latest models. And I checked the number of packets according to the log of nRF connect application.
    I	19:37:36.259	Notification received from 6e400003-b5a3-f393-e0a9-e50e24dcca9e, value: (0x) 76-00-76-00-74-00-75-00-75-00-76-00-74-00-73-00-74-00-73-00-74-00-71-00-73-00-71-00-71-00-71-00-71-00-70-00-71-00-6F-00-6D-00-6E-00-6D-00-6D-00-6B-00-6E-00-6B-00-6B-00-6A-00-6B-00-68-00-69-00-69-00-68-00-67-00-69-00-67-00-65-00-65-00-63-00-65-00-63-00-62-00-61-00-61-00-61-00-5E-00-5F-00-5E-00-5E-00-5E-00-60-00-5D-00-5E-00-5B-00-5B-00-59-00-5A-00-5B-00-5A-00-5E-00-5C-00-5A-00-5A-00-57-00-57-00-57-00-57-00-57-00-57-00-56-00-56-00-55-00-56-00-56-00-55-00-54-00-53-00-54-00-52-00-53-00-52-00-53-00-54-00-52-00-54-00-51-00-52-00-53-00-51-00-51-00-4F-00-51-00-51-00-51-00-50-00-4F-00-51-00-4E-00-4E-00-4E-00-4E-00-4E-00-4D-00-4C-00-4C-00-4A-00-4C-00-4A-00-4B-00-4A-00-4B-00-49-00-49-00-4B-00-4A-00-4B-00-4B-00-4A-00-4A-00
    A	19:37:36.259	"v v t u u v t s t s t q s q q q q p q o m n m m k n k k j k h i i h g i g e e c e c b a a a ^ _ ^ ^ ^ ` ] ^ [ [ Y Z [ Z ^ \ Z Z W W W W W W V V U V V U T S T R S R S T R T Q R S Q Q O Q Q Q P O Q N N N N N M L L J L J K J K I I K J K K J J " received
    I	19:37:36.261	Notification received from 6e400003-b5a3-f393-e0a9-e50e24dcca9e, value: (0x) 49-00-49-00-48-00-4A-00-49-00-48-00-48-00-49-00-4A-00-4A-00-4A-00-4A-00-4B-00-49-00-4C-00-4D-00-4C-00-4C-00-4D-00-4D-00-4D-00-4F-00-4D-00-4E-00-4E-00-50-00-4F-00-4F-00-4F-00-50-00-51-00-51-00-53-00-52-00-53-00-4E-00-55-00-53-00-55-00-59-00-57-00-58-00-58-00-57-00-59-00-5A-00-59-00-5B-00-5B-00-5A-00-5A-00-5C-00-5C-00-5B-00-5D-00-5E-00-5E-00-5E-00-5E-00-60-00-60-00-62-00-61-00-63-00-63-00-64-00-64-00-66-00-64-00-66-00-66-00-67-00-67-00-68-00-66-00-68-00-6C-00-6A-00-69-00-69-00-6B-00-6A-00-6C-00-6B-00-6D-00-6B-00-6D-00-6E-00-6C-00-6C-00-6D-00-6E-00-6F-00-6E-00-6F-00-6F-00-71-00-70-00-72-00-72-00-71-00-72-00-71-00-71-00-72-00-71-00-72-00-72-00-71-00-72-00-73-00-73-00-72-00-74-00-73-00-73-00-73-00-74-00-74-00-75-00
    A	19:37:36.261	"I I H J I H H I J J J J K I L M L L M M M O M N N P O O O P Q Q S R S N U S U Y W X X W Y Z Y [ [ Z Z \ \ [ ] ^ ^ ^ ^ ` ` b a c c d d f d f f g g h f h l j i i k j l k m k m n l l m n o n o o q p r r q r q q r q r r q r s s r t s s s t t u " received
    I	19:37:36.271	Notification received from 6e400003-b5a3-f393-e0a9-e50e24dcca9e, value: (0x) 75-00-76-00-76-00-78-00-78-00-78-00-79-00-7C-00-7A-00-79-00-79-00-78-00-7A-00-78-00-79-00-7A-00-79-00-79-00-7B-00-7A-00-7A-00-7B-00-7B-00-7C-00-7C-00-7D-00-7B-00-7B-00-7B-00-7A-00-7B-00-79-00-7A-00-78-00-77-00-78-00-77-00-76-00-76-00-76-00-76-00-76-00-75-00-77-00-75-00-74-00-74-00-75-00-73-00-74-00-73-00-72-00-72-00-73-00-71-00-71-00-71-00-70-00-70-00-6F-00-70-00-6D-00-6D-00-6D-00-6D-00-6C-00-6C-00-6C-00-6B-00-6A-00-6B-00-6A-00-6A-00-68-00-67-00-69-00-66-00-66-00-65-00-64-00-63-00-63-00-62-00-62-00-60-00-61-00-5D-00-60-00-5E-00-5D-00-5D-00-5D-00-5C-00-5C-00-5C-00-5C-00-5B-00-5A-00-5A-00-5A-00-5D-00-5C-00-58-00-5A-00-56-00-56-00-58-00-56-00-58-00-58-00-56-00-56-00-56-00-55-00-55-00-54-00-55-00-51-00-53-00-52-00
    A	19:37:36.271	"u v v x x x y | z y y x z x y z y y { z z { { | | } { { { z { y z x w x w v v v v v u w u t t u s t s r r s q q q p p o p m m m m l l l k j k j j h g i f f e d c c b b ` a ] ` ^ ] ] ] \ \ \ \ [ Z Z Z ] \ X Z V V X V X X V V V U U T U Q S R " received
    As the connection interval is fixed to 11.25ms (I don't know why but the app always fixes it) and counted Notification received messages.
