connectivity_bridge malfunctions when BLE client disconnects and reconnects
I noticed that when a BLE client disconnects and then reconnects to the, instead of receiving all data arriving over the UART from nRF9160 to nRF52840, there is a delay of several seconds after which a huge block of 2048 bytes is sent over to the BLE client. This size matches the BRIDGE_BUF_SIZE configuration. The issue is observed on both Thingy:91 using the sample provided as part of the precompiled firmware, and also on nRF9160 DK - I ported the sample to work on it, so I observe the same behaviour on both boards. I tried changing BRIDGE_BUF_SIZE, and since I observed that internally 182 bytes are used for BLE transmission, I used that value. Now parts of the NMEA data sent from the GPS sample is randomly scrambled, resulting in 40% or NMEA packets that fail basic validation and CRC.
This attached log has been recorded from nRF9160dk, using the modified connectivity_bridge, which I adapted to run on the DK.
The GPS sample has also been modified, so send a copy of the NMEA strings to its second UART, which on the modified board links to the nRF52840 chip and is forwarded to BLE (application) and USB (this log file).
The following changes have been made:
nrf/samples/nrf9160/gps/src/main.c
static void print_nmea_data(void)
for (int i = 0; i < nmea_string_cnt; ++i) {
printk("%s", nmea_strings[i]);
+ #if CONFIG_TRACING_TEST
+ TRACING_STRING("%s", nmea_strings[i]);
+ #endif
+ #if CONFIG_UART_BLE
+ int uart_ble_send(char * msg, uint16_t length);
+ uart_ble_send(nmea_strings[i], strlen(nmea_strings[i]));
+ #endif
nrf/applications/connectivity_bridge.nrf9160dk/src/modules/Kconfig
BRIDGE_BUF_SIZE=182
nrf/applications/connectivity_bridge.nrf9160dk/prj.conf
CONFIG_USB_DEVICE_PRODUCT="nrf9160dk UART"
Send a copy of the data being sent to BLE over the debug UART of nRF52840. The USB on nRF9160dk connects to an OpenWRT router which acts as a mobile UART to TCP bridge and is then recorded on a computer using netcat.
nrf/applications/connectivity_bridge_g/src/modules/ble_handler.c
static void bt_send_work_handler(struct k_work *work)
uint16_t len;
uint8_t *buf;
int err;
bool notif_disabled = false;
do {
len = ring_buf_get_claim(&ble_tx_ring_buf, &buf, nus_max_send_len);
err = bt_gatt_nus_send(current_conn, buf, len);
if (err == -EINVAL) {
notif_disabled = true;
len = 0;
} else if (err) {
len = 0;
+ if (len)
+ char msg[BLE_TX_BUF_SIZE];
+ memcpy(msg, buf, len);
+ msg[len] = '\0';
+ printk("%s", msg);
err = ring_buf_get_finish(&ble_tx_ring_buf, len);
if (err) {
LOG_ERR("ring_buf_get_finish: %d", err);
} while (len != 0 && !ring_buf_is_empty(&ble_tx_ring_buf));
if (notif_disabled) {
/* Peer has not enabled notifications: don't accumulate data */
ring_buf_reset(&ble_tx_ring_buf);
The following line is not valid:
$GPGLL,4.31375,N,02445.01620,E,1,04,100.00,312.72,M,0,,*26
Both of the following lines have a valid checksum:
* the first line contains invalid data
* the second line is valid
$GPGGA,085500.23,4208.30949,N,02444.97N,02444.9766.16,217.38,M,0,,*23
$GPGGA,085500.23,4208.30949,N,02444.97660,E,1,10,1.16,217.38,M,0,,*23
Notice how a part of the packet is missing or replaced with data, from
another packet. 40% of the packets are discarded, because they:
* do not begin with $
* do not have * in position line_length - 3
* do not have a valid checksum
From the the remaining 60% of the packets which pass the above validation,
a few are discarded because they:
* have values out of range
* have missing or more than one . character in a float value
* have less or more characters per line of value than expected
In rare events, there are still packets that pass all validation, but
contain slightly invalid data, e.g. there could be a long spike on the map
when our application is drawing the path.
If BRIDGE_BUF_SIZE is reverted to its default value of 2048,
Once the BLE client disconnects and then reconnects, the connectivity bridge
starts working incorrectly and will send large blocks of 2048 bytes containg
multiple NMEA packets.
ble_handler.test.c is my attempt to add tracing code and investigate what
is wrong with the connectivity_bridge. It seems that the ble_handler is holding
all buffers, so the uart_handler has no space to store arriving data.
At some point the buffers are freed by BLE, but then UART sends another 2048 bytes
of data, which arrave at bt_send_work_handler(). It starts sending blocks of
nus_max_send_len=182 until the BLE driver chokes. At this point BLE transmission
stalls for a few seconds, and UART RX will drop some data. Next the process repeats.
I am sorry for not being able to provid more details, and this parragraph may not be
fully accurate, because the code is extremely hard to follow.
I need to make one very important note towards the Nordic SDK developers:
Please make things simple and reliable!
I cannot say if the above issue is due to the existing design patterns in Zephyr OS,
but I see that all design patters are extremely complex and hard to follow, even
for taks that are very simple to implement, such as read/write from UART or BLE,
I see that you write 400 lines of code for each!
Hence it comes to no surprise that such a complex code has bugs which are hard to
diagnose or resolve. For example, as part of my testing I needed to change the
gps sample for nRF9160dk, so that in addition to its normal output, it sends a copy
with only the NMEA strings to its second UART, which I routed to the nRF52840 chip to
forward over BLE. My expectation was that I can simply write the data to UART.
But instead of a one line solution, I was forced to dedicate 330 lines of code:
zephyr/boards/arm/nrf9160dk_nrf9160_g/uart_ble.c
with a lot of handling routines and thigs that should normally be handled by
the driver, and any decent operating system provides a simple to use interface.
Using Nordic SDK master
nrf
commit ecf5d334f1577cc7fca11ae7b5a7fb86f0ea757a
zephyr
commit 7d20f2ebf25991b2897b91275939f8d16d38513a
 4572.projects.7z
  • If you like we can also try debugging my Thingy:91, where the issue is already reproduced. We can exchange phone or e-mail as a private message, then arrange for a call and I can let you access my computer.
  • For now I just need to get an overview of your issue and what it's about. But maybe we can do this later on. I will get back to you.
  • I was able to run your application on the Thingy:91, connect it to the  nRF Connect for mobile app and see the GPS data notified. However, I had some problems running your iPhone application. I was able to download it but encountered some errors when I tried to open it. I'm new to the iPhone world, so I may have done something stupid. I'll continue tomorrow.
  • Hello Simon!
    The nRF Connect for mobile app is not a very useful tool. It would have been nice if it ccoult at least show any received data as a text log. Unfortunately it only shows hex values. You might still use it and look for the delay between updates, which should be around 0.5 seconds for the GPS demo. You are not doing anything stupid, iPhones prevent running apps which are downloaded from the Internet, until you go to Settings, General, Profiles & Device Management, and hopefully there you should see my developer certificate. Once you enable trust, the app should run. I assume you were able to install it and see a white icon with circles and X. https://support.apple.com/en-us/HT204460
    Unfortunately I just updated to iOS 14.2 and I no longer see Device Management, however the application just works as soon as I confirm that I want to install it from the web page. I am also new to the process of sharing development versions of apps. There are different ways to export the app, and I cannot tell which one should be used. I did test the process to make sure it works before sharing the app with you. Another way of installing apps is by downloading the .ipa file on a Mac computer, then right-click, Share, AirDrop. Select your Phone and it should get installed. If you still have difficulties, we can try to work this together. The whole security design makes it hard to deploy the first time.
  • I put off some time and looked into the connectivity_bridge application and how the UART-BLE flow worked. I'll give an illustration of my understanding:
    The connectivity application is basically a stream, and in your case the input to the stream is the UART data from the nRF160 and the output of the stream is the BLE notificaitons sent from the nRF52840. If the input is larger than the output, the internal buffers will eventually fill up and you will loose data. In your case the stream stop outputting when you're not in a BLE connection or when notifications are disabled.
    The solution to this is either to increase the internal buffers or decrease the input.
    The only internal buffers I can see in the stream is the DMA buffers and the Ring buffer. However, I think the best approach to this is to stop sending data when the nRF52840 is not able to send. It is not able to send when it's not in a BLE connection or when notifications are disabled. Maybe you could implement a solution where the nRF52840 signals to the nRF9160 when it's ready and able to send data, either through UART or maybe a GPIO signal. Then you could set a boolean to true/false in the nRF9160 GPS sample.
    You could also add some buffers in the nRF9160 GPS samples, that stores the data when the nRF52840 is not ready to receive data.
    The stuff I'm saying here may be obvious to you, but I'm just thinking out loud. The optimal solutions would probably be that this was handled by the firmware automatically without the user needing to anything. I will talk to some of the developers and get back to you.
    Simon
