How to do buttonless dfu
I am using nRF52832 and sdk 16
I am done secure bootloader dfu. By generating the new firmware application. Zip  , this part is working fine
Now I want to do buttonless dfu.  How to generate the bootloader settings?
2.i have merged all the hex file into single hex file which include bootloader, softdevice, and application
3.how can I make my device to switch to dfu mode?
Please suggest me an answer.
Thanks
  1. Pspavi
  •  as per above link i have modified the ble_app_uart program  . getting the same error
    /**@brief Function for handling DFU events
    * @details This function is called when entering buttonless DFU
    * @param[in] event Buttonless DFU event.
    Add Nordic Semiconductor DFU to SDK Example - Application note
    UBX-19050198 - R01 Buttonless DFU Page 23 of 32
    static void ble_dfu_buttonless_evt_handler(ble_dfu_buttonless_evt_type_t event)
     switch (event)
     case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
     NRF_LOG_INFO("Device is preparing to enter bootloader mode\r\n");
     case BLE_DFU_EVT_BOOTLOADER_ENTER:
     NRF_LOG_INFO("Device will enter bootloader mode\r\n");
     case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
     NRF_LOG_ERROR("Device failed to enter bootloader mode\r\n");
     NRF_LOG_INFO("Unknown event from ble_dfu.\r\n");
    /**@brief Function for handling bootloader power management events
    * @details This function is called to set a persistent register which informs the
    * bootloader it should continue or pass control back to the application
    * @param[in] event Power management event.
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
     switch (event)
     case NRF_PWR_MGMT_EVT_PREPARE_DFU:
     NRF_LOG_INFO("Power management wants to reset to DFU mode\r\n");
     // Change this code to tailor to your reset strategy.
     // Returning false here means that the device is not ready
     // to jump to DFU mode yet.
     // Here is an example using a variable to delay resetting the device:
     /* if (!im_ready_for_reset)
     return false;
     // Implement any of the other events available
     // from the power management module:
     // -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
     // -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
     // -NRF_PWR_MGMT_EVT_PREPARE_RESET
     return true;
     NRF_LOG_INFO("Power management allowed to reset to DFU mode\r\n");
     return true;
     uint32_t err_code;
     ble_nus_init_t nus_init;
    // Initialize NUS (Nordic UART Service)
    // BEGIN Block Added for DFU
    // ONLY ADD THIS BLOCK TO THE EXISTING FUNCTION
    // Initialize the DFU service
     ble_dfu_buttonless_init_t dfus_init =
     .evt_handler = ble_dfu_buttonless_evt_handler
     err_code = ble_dfu_buttonless_init(&dfus_init);
    // END Block Added for DFU
  • I only found your modified main.c file in the attachment. I need the full project.
  • The preprocessor definitions we asked you to add were not included in the project you sent me.
