End Device reports bad behavior on low power device
We have been working with an end device based on nRF52840 with nRF5_SDK_for_Thread_and_Zigbee_v4.0.0_dc7186b, Softdevice and FreeRTOS.
We built 2 configurations for this device: normal and low power. The last one contains some considerations like:
- At FreeRTOSConfig.h we set configUSE_TICKLESS_IDLE to 1
-We enabled SoftDevice Low power mode and enabled DCDC mode
-Also set SCB_SCR_SLEEPDEEP_Msk flag
Once joined to a Zigbee network, some cluster bindings are performed automatically to the coordinator and some reports are automatically being sent. The max time for each one is 60 seconds while the min timeout is 0.
On normal configuration, attribute reporting is accomplished without problem every 60 seconds. But in the low power configuration, times get longer and seem to increase with the time.
Is there any special consideration or appropiate setting for low power mode?
Santiago
  • Hi ,
    Just to be sure: Sleepy End Devices are set by just calling zb_set_rx_on_when_idle(ZB_FALSE)
    Yes, and you need to enable the End Device role in the application as well of course.
    But sleep functionality is not implemented for OS-based applications applications in the nRF5 SDK for Thread & Zigbee. This is why the multisensor example with FreeRTOS is categorized as "experimental", and the CAN_SLEEP event are overwritten in main.c to being empty.
    You may be better off migrating to NCS if you don't want to go through all the work on implementing sleepy functionality yourself for RTOS in nRF5 SDK.
    The ZB_COMMON_SIGNAL_CAN_SLEEP signal will be sent to the application when RxOnOnWhenIdle is set to 'False' anytime the scheduler finds out that the application can go to sleep, read more about this in 'Power saving for ZED'. You need to handle this signal to suspend any tasks and then go to sleep. zb_sleep_now() must be called from the ZB_COMMON_SIGNAL_CAN_SLEEP signal.
    Then you need to implement your own sleep routine, as the OSIF implementation in nRF5 SDK is not written for OS implementations.
    If you call zb_sleep_now() the stack will call zb_nrf52_sleep(). See external/zboss/osif/zb_nrf52_common.c this function is implemented as a weak function, so you can implement it in your application without changing common components.
    You also need to have some signaling structures to wake up the ZBOSS task whenever is needed (as is done in NCS with zigbee_event_poll()).
    Comparing the implementation of zb_nrf52_sleep() on the nRF5 SDK to the zigbee sleep function on NCS zb_osif_sleep() we see some differences and similarities, but there are probably several things you will need to modify to make the sleep implementation in nRF5 SDK RTOS-friendly. Some points to consider:
    • zb_nrf52_priph_disable() This function disables all Zigbee stack related peripherals (except the radio which is handle by the stack), but may not be correct when sharing resources with other components that may want to use these peripherals even if the radio is sleeping.
    • zb_nrf52_sched_sleep(sleep_tmo):sets an alarm inside the radio driver so the MCU is woken up by the RTC clock after an specific timeout value. This not valid for RTOS solutions. You should lock the RTOS thread for a specific amount of time and give the context down to the idle task which implements sleep functionality.
    • zb_osif_wait_for_event(): ZBOSS task should not be woken up upon every single event. Not needed if RTOS is in use.
    • time_slept_ms = zb_nrf52_get_time_slept(): every implementation of zb_nrf52_sleep_has to return the actual time (in milliseconds), so the zboss timer may be fast-forward to the correct time value.
    • zb_nrf52_priph_enable(): need to enable everything that was previously disabled.
    Marjeris
    EDIT: I edited my answer to be clear that you have to call zb_sleep_now() from the ZB_COMMON_SIGNAL_CAN_SLEEP signal. It's not allowed to call zboss API from other thread that the one running main loop iteration. The signal handler is the ZBOSS context (called from the main loop iteration).
