interactive sd_ble_gap_connect() -> error
Hi Nordic,
I want to establish a user controlled connection  to a ble_peripheral.  I am using the Sdk 15.3, s140 and the nrf52840.
The idea is: Ble_central show all scanned devices, then based on a command, the user selects to whom it should connect. Similar as the ble_app_interactive idea, but there a bonding is always implemented.
In our application, with every  BLE_GAP_EVT_ADV_REPORT event, the p_ble_evt->evt.gap_evt.params.adv_report.peer_addr is saved.
The intention is to use it then with the sd_ble_gap_connect() function.
  	static ble_gap_conn_params_t const m_connection_param =
		NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL,
		NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL,
		NRF_BLE_SCAN_SLAVE_LATENCY,
	    NRF_BLE_SCAN_SUPERVISION_TIMEOUT
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
    .timeout       = SCAN_DURATION_WITELIST,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
 err_code = sd_ble_gap_connect(&p_ble_evt->evt.gap_evt.params.adv_report.peer_addr,
        			&m_scan_param,
					&m_connection_param,
					APP_BLE_CONN_CFG_TAG);
This returns 07 as an error which is invalid param.
Is there something  that i'm missing?
In the ble_app_interactive example, the peer_addr is took from the bonding data.  Is this the only possibility?
Thank you in advance.
