pc-ble-driver-py missing high-rate notifications
whilst implementing my embedded device software, I'm developing a tool running on a Windows laptop to validate my work.
The idea is to use pc-ble-driver-py python bindings to implement simple interactions with the device over BLE using the services exposed.
The current setup is:
  • pc-ble-driver-py 0.15.0 (latest)
  • nRF52840 Dongle (PCA10059) running connectivity FW 4.1.2 SD API v5 (latest supported)
Most of the functionalities seem to be working fine.
But when I try to collect notifications from a certain rate on, looks like the system is not able to "catch-up".
To give some context - from the embedded device, I'm polling data and queuing notifications on certain char every 10ms. The connection interval is set 15ms.
The moment I enable the notifications on this char from Client side(after the wanted connection intervals are updated), I start receiving as a return value from sd_ble_gatts_hvx the error code NRF_ERROR_RESOURCES on the server side - it's not always the case, but very often, at least 10/20 times per second.
The only explanation I can give to this is that the Central (i.e. the python script) is not meeting all the connection events at fixed interval (15ms), and this way the notification queue on the Server is increasing till its limit.
I tested this scenario with different platforms (Windows UWP, Android) and this is the only case I'm seeing this behaviour.
What I find rather odd is that using exactly the same dongle (with same FW), but from the nRF Connect Desktop App GUI this is NOT happening - I can subscribe to the notifications and getting them at the rate I expect.
Adding a couple of graph to make things clearer:
Notifications Intervals (ms) from nRF Connect Desktop:
Notifications Intervals (ms) from pc-ble-driver-py:
It's clear that in the first case, two notifications are sometimes very close as the queuing rate is higher than the connection interval (i.e you get more than one notification for conn interval).
Instead in the second case, interval is never below 15ms, meaning that for sure notifications are lost (I imagine due to missed connection events...).
I tried to do the same but changing the dongle with a nRF52-DK. The result is that in this case the system crashes and disconnects after a couple of seconds from the enabling of notifications with this log:
2020-10-20 15:17:21,194 [21092/LogThread] h5_decode error, code: 0x802c, H5 error count: 1. raw packet: c0 f0 0e 02 00 02 39 00 00 00 00 00 00 00 1c 00 01 12 00 f7 03 71 03 d0 02 de 02 fe 02 0e c0
As a quick workaround, If I try to queue notifications every 20ms (or anything above the connection interval), I don't see any problem and the system works flawlessly.
Can you help me understanding what's going on?
I'm evaluating this python libraries for the system testing framework of our devices - and of course we'll need to evaluate also the high-rate notifications.
I think reproducing the issue would be quite trivial, but maybe there is something I'm missing that can solve this straightaway.
Thanks!
  • Hello Davege,
    Attached you will find a zip file for the peripheral project to be used with SDK v.17.0.2. It is modified to send two notifications every connection event, with a connection interval of 15 ms.
    The attached python file is the file you should run for the central, with the pc-ble-driver-py python package installed.
    Please flash an nRF52 DK with the peripheral firmware, and run a central with the pc-ble-driver-py code, and take a trace of the communication that is happening.
    Ideally we should then see multiple notifications per connection event.
    Looking forward to hearing back from you,
    Karl
    8255.__ble_app_hrs_multiple_notifications_pca10040.zip
    # Copyright (c) 2016 Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without modification,
    # are permitted provided that the following conditions are met:
    #   1. Redistributions of source code must retain the above copyright notice, this
    #   list of conditions and the following disclaimer.
    #   2. Redistributions in binary form must reproduce the above copyright notice, this
    #   list of conditions and the following disclaimer in the documentation and/or
    #   other materials provided with the distribution.
    #   3. Neither the name of Nordic Semiconductor ASA nor the names of other
    #   contributors to this software may be used to endorse or promote products
    #   derived from this software without specific prior written permission.
    #   4. This software must only be used in or with a processor manufactured by Nordic
    #   Semiconductor ASA, or in or with a processor manufactured by a third party that
    #   is used in combination with a processor manufactured by Nordic Semiconductor.
    #   5. Any software provided in binary or object form under this license must not be
    #   reverse engineered, decompiled, modified and/or disassembled.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
    # ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    # DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
    # ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    # (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    # LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
    # ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    # SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    import sys
    import time
    import logging
    from queue import Queue, Empty
    from pc_ble_driver_py.observers import *
    TARGET_DEV_NAME = "Nordic_HRM"
    CONNECTIONS = 1
    CFG_TAG = 1
    def init(conn_ic_id):
        # noinspection PyGlobalUndefined
        global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEConfigConnGap, BLEGapScanParams
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        # noinspection PyUnresolvedReferences
        from pc_ble_driver_py.ble_driver import (
            BLEDriver,
            BLEAdvData,
            BLEEvtID,
            BLEEnableParams,
            BLEGapTimeoutSrc,
            BLEUUID,
            BLEGapScanParams,
            BLEConfigCommon,
            BLEConfig,
            BLEConfigConnGatt,
            BLEConfigConnGap,
        from pc_ble_driver_py.ble_adapter import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class HRCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(HRCollector, self).__init__()
            self.adapter = adapter
            self.conn_q = Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.adapter.default_mtu = 250
        def open(self):
            self.adapter.driver.open()
            if config.__conn_ic_id__.upper() == "NRF51":
                self.adapter.driver.ble_enable(
                    BLEEnableParams(
                        vs_uuid_count=1,
                        service_changed=0,
                        periph_conn_count=0,
                        central_conn_count=1,
                        central_sec_count=0,
            elif config.__conn_ic_id__.upper() == "NRF52":
                gatt_cfg = BLEConfigConnGatt()
                gatt_cfg.att_mtu = self.adapter.default_mtu
                gatt_cfg.tag = CFG_TAG
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
                conn_cfg = BLEConfigConnGap()
                conn_cfg.conn_count = 1
                conn_cfg.event_length = 320
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gap, conn_cfg)
                self.adapter.driver.ble_enable()
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            scan_duration = 5
            params = BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=scan_duration)
            self.adapter.driver.ble_gap_scan_start(scan_params=params)
            try:
                new_conn = self.conn_q.get(timeout=scan_duration)
                self.adapter.service_discovery(new_conn)
                self.adapter.enable_notification(
                    new_conn, BLEUUID(BLEUUID.Standard.battery_level)
                self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
                return new_conn
            except Empty:
                print(f"No heart rate collector advertising with name {TARGET_DEV_NAME} found.")
                return None
        def on_gap_evt_connected(
            self, ble_driver, conn_handle, peer_addr, role, conn_params
            print("New connection: {}".format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print("Disconnected: {} {}".format(conn_handle, reason))
        def on_gap_evt_adv_report(
            self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name = "".join(chr(e) for e in dev_name_list)
            address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print(
                "Received advertisment report, address: 0x{}, device_name: {}".format(
                    address_string, dev_name
            if dev_name == TARGET_DEV_NAME:
                self.adapter.connect(peer_addr, tag=CFG_TAG)
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            if len(data) > 32:
                data = "({}...)".format(data[0:10])
            print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
    def main(selected_serial_port):
        print("Serial port used: {}".format(selected_serial_port))
        driver = BLEDriver(
            serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="debug"
        adapter = BLEAdapter(driver)
        collector = HRCollector(adapter)
        collector.open()
        conn = collector.connect_and_discover()
        if conn is not None:
            time.sleep(10)
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print("\t{} : {}".format(i, it))
        print(" ")
        while True:
            try:
                choice = int(input("Enter your choice: "))
                if (choice >= 0) and (choice < len(item_list)):
                    break
            except Exception:
                pass
            print("\tTry again...")
        return choice
    if __name__ == "__main__":
        logging.basicConfig(
            level="DEBUG",
            format="%(asctime)s [%(thread)d/%(threadName)s] %(message)s",
        serial_port = None
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs = BLEDriver.enum_serial_ports()
            choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
            choice = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
  • Hello!
    How did you developed a tool running on a Windows laptop? I need to do the same with C# but I don't know where to start. I'll appreciate your help.
    As discussed in the previous comments on this ticket you can use the (now deprecated) pc-ble-driver to create an windows application that does Bluetooth through a Nordic BLE Connectivity device.
    As far as I know we do not have any application made using C#, could you elaborate on this requirement on your part? I personally have no experience working with C#, but could it not be a possibility to interface your C# based application with a standard C or python application?
    Please keep in mind that this ticket is over 3 years old, and so I would not expect the original poster to come back to this ticket quickly. In this case I would therefore recommend opening a new ticket for this issue.
    Karl
