Trying to run the experimental nfc pairing reference on a couple of 840 DKs for Bluetooth pairing as it's shipped in SDK 17.
Successfully compiled the micro-ecc make files for my appropriate boards, and I have the Adafruit PN532 breakout board with headers soldered on it so it will fit the DK (or should I be using the PN532 Adafruit shield specifically?).
After compiling and flashing the central reference example with no modification, I get a fatal error with no other debug messages.
After some debugging, I've narrowed it down to the adafruit_pn532_init function and I get this.
So the error is an NRF_ERROR_INTERNAL, but why no other debug messages from the function? I'm quite confused.
Here is my main function
NRF_LOG_INFO("Main");
logs_init();
NRF_LOG_INFO("logs init");
timer_init();
NRF_LOG_INFO("timer init");
buttons_init();
NRF_LOG_INFO("buttons init");
ble_stack_init();
NRF_LOG_INFO("ble stack init");
gatt_init();
NRF_LOG_INFO("gatt init");
peer_manager_init(false);
NRF_LOG_INFO("peer manager");
nfc_init();
NRF_LOG_INFO("nfc init");
scan_init();
NRF_LOG_INFO("scan init");
NRF_LOG_INFO("NFC Connection Handover BLE Central device example started.");
while (true)
nfc_tag_process();
And here is the nfc_init function with my debug messages added.
void nfc_init(void)
NRF_LOG_INFO("NFC INIT FUNCTION");
ret_code_t err_code = adafruit_pn532_init(false);
NRF_LOG_INFO("The error code is %d", err_code);
nrf_ble_lesc_peer_oob_data_handler_set(nfc_peer_oob_data_get);
// Register handler for BLE events.
NRF_SDH_BLE_OBSERVER(m_ble_observer, NFC_BLE_PAIR_OBSERVER_PRIO, ble_nfc_pair_handler, NULL);
I get the same results even when setting the <force> argument to true.
Currently I have SEL0 and SEL1 open on the pn532 breakout, so i2c should be enabled, but I can't tell if this is the problem area.
Again, I haven't touched the Adafruit PN532 library at all since extracting it fresh from SDK 17.
All I want to do is get a my two 840 DKs to pair over NFC.
Any help would be appreciated!
Thanks!
Sam
