hx711 routines using in ant bike powe rmeter example
i am developing a bike power meter and designed my own hardware.
From software point of view I used the Ant+ bikepowermeter example from Nordic.
So far  my status is,
connect to Garmin sportswatch  and accepted as bike powermeter.   works!
calculating the cadence:  work
transmit calculated cadence and simulated power. work
Now i am trying to go ahead with the HX711
Viards example of HX711 works also on my hardware ( NRF52840) and I can see the measurements in the debug window
My next step was to include your files in my project.
compilation works also and I can start the programm
But it hangs when it comes out of your  hx711_init(INPUT_CH_A_128, hx711_callback);
the next step will be:
softdevice_setup();
but than  : it runs  into the NRF_BREAKPOINT_COND
i tried to debug, and saw that
ret_code = nrf_drv_gpiote_in_init(DOUT, &gpiote_config, gpiote_evt_handler)
APP_ERROR_CHECK(ret_code);
 in HX711.c gives a 4 as ret_code, which is a memory error
my mememory map looks :
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x31000
FLASH_SIZE=0x6e000
RAM_START=0x20002000
RAM_SIZE=0xf480
Thanks in advance
any idea ?
