I'm trying to write my own application based on the ble_lbs example on nrf51822. Recently I've discovered a problem with reconnection to the beacon. I can successfully make two cycles of connect and disconnect. When I try to connect for the third time, the application calls APP_ERROR_HANDLER from conn_params_error_handler.
Is this a problem with connection params initialization?
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;//true;//
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
Best regards, Konrad
