Modem errors when combining HTTPS and GPS
After building and testing separate HTPS and GPS examples, I am getting modem errors when combining both projects into one application. One of our goals is to send GPS data over HTTPS to our server, and I have successfully gotten these examples to work individually, but now receive these errors when combining into one.
I am not sure if my prj,conf file is wrong, or if there was a step I missed when combining the applications, but I am wondering if someone can take a look at my project and see if there are any errors I missed or if there are certain issues with combining HTTPS and GPS
#include "https.h"
char prod_num[] = "200001-A";
char serial_num[] = "10000001";
char tok[] = "5e9564ab-7ac4-4b26-8e5f-8222cdcdcf24";
char firmware_tok[] = "e4828545-0c1b-429c-a932-f355de7a6307";
char postData[SEND_BUFF_SIZE];
char postGPSData[SEND_BUFF_SIZE];
 * Copyright (c) 2019 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#ifdef CONFIG_SUPL_CLIENT_LIB
#include <supl_os_client.h>
#include <supl_session.h>
#include "supl_support.h"
#define AT_XSYSTEMMODE      "AT\%XSYSTEMMODE=1,0,1,0"
#define AT_ACTIVATE_GPS     "AT+CFUN=31"
#define AT_ACTIVATE_LTE     "AT+CFUN=21"
#define AT_DEACTIVATE_LTE   "AT+CFUN=20"
#define AT_COEX0            "AT\%XCOEX0"
#define GNSS_INIT_AND_START 1
#define GNSS_STOP           2
#define GNSS_RESTART        3
#define AT_CMD_SIZE(x) (sizeof(x) - 1)
#ifdef CONFIG_BOARD_NRF9160DK_NRF9160NS
#define AT_MAGPIO      "AT\%XMAGPIO=1,0,0,1,1,1574,1577"
#ifdef CONFIG_GPS_SAMPLE_ANTENNA_ONBOARD
#define AT_COEX0       "AT\%XCOEX0=1,1,1565,1586"
#elif CONFIG_GPS_SAMPLE_ANTENNA_EXTERNAL
#endif /* CONFIG_BOARD_NRF9160DK_NRF9160NS */
#ifdef CONFIG_BOARD_THINGY91_NRF9160NS
#define AT_MAGPIO      "AT\%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200," \
			"3,824,894,4,880,960,5,791,849,7,1565,1586"
#endif /* CONFIG_BOARD_THINGY91_NRF9160NS */
static const char update_indicator[] = {'\\', '|', '/', '-'};
static const char *const at_commands[] = {
	AT_XSYSTEMMODE,
#if defined(CONFIG_BOARD_NRF9160DK_NRF9160NS) || \
	defined(CONFIG_BOARD_THINGY91_NRF9160NS)
	AT_MAGPIO,
	AT_COEX0,
	AT_ACTIVATE_GPS
static int                   gnss_fd;
static char                  nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static uint32_t                 nmea_string_cnt;
static bool                  got_fix;
static uint64_t                 fix_timestamp;
static nrf_gnss_data_frame_t last_pvt;
K_SEM_DEFINE(lte_ready, 0, 1);
void bsd_recoverable_error_handler(uint32_t error)
	printf("Err: %lu\n", (unsigned long)error);
static int setup_modem(void)
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		if (at_cmd_write(at_commands[i], NULL, 0, NULL) != 0) {
                        printk("Failed Command: %s\n", at_commands[i]);
			return -1;
	return 0;
/* Accepted network statuses read from modem */
static const char status1[] = "+CEREG: 1";
static const char status2[] = "+CEREG:1";
static const char status3[] = "+CEREG: 5";
static const char status4[] = "+CEREG:5";
static void wait_for_lte(void *context, const char *response)
	if (!memcmp(status1, response, AT_CMD_SIZE(status1)) ||
		!memcmp(status2, response, AT_CMD_SIZE(status2)) ||
		!memcmp(status3, response, AT_CMD_SIZE(status3)) ||
		!memcmp(status4, response, AT_CMD_SIZE(status4))) {
		k_sem_give(&lte_ready);
static int activate_lte(bool activate)
	if (activate) {
		if (at_cmd_write(AT_ACTIVATE_LTE, NULL, 0, NULL) != 0) {
			return -1;
		at_notif_register_handler(NULL, wait_for_lte);
		if (at_cmd_write("AT+CEREG=2", NULL, 0, NULL) != 0) {
			return -1;
		k_sem_take(&lte_ready, K_FOREVER);
		at_notif_deregister_handler(NULL, wait_for_lte);
		if (at_cmd_write("AT+CEREG=0", NULL, 0, NULL) != 0) {
			return -1;
	} else {
		if (at_cmd_write(AT_DEACTIVATE_LTE, NULL, 0, NULL) != 0) {
			return -1;
	return 0;
static int gnss_ctrl(uint32_t ctrl)
	int retval;
	nrf_gnss_fix_retry_t    fix_retry    = 0;
	nrf_gnss_fix_interval_t fix_interval = 1;
	nrf_gnss_delete_mask_t	delete_mask  = 0;
	nrf_gnss_nmea_mask_t	nmea_mask    = NRF_GNSS_NMEA_GSV_MASK |
					       NRF_GNSS_NMEA_GSA_MASK |
					       NRF_GNSS_NMEA_GLL_MASK |
					       NRF_GNSS_NMEA_GGA_MASK |
					       NRF_GNSS_NMEA_RMC_MASK;
	if (ctrl == GNSS_INIT_AND_START) {
		gnss_fd = nrf_socket(NRF_AF_LOCAL,
				     NRF_SOCK_DGRAM,
				     NRF_PROTO_GNSS);
		if (gnss_fd >= 0) {
			printk("GPS Socket created\n");
		} else {
			printk("Could not init socket (err: %d)\n", gnss_fd);
			return -1;
		retval = nrf_setsockopt(gnss_fd,
					NRF_SOL_GNSS,
					NRF_SO_GNSS_FIX_RETRY,
					&fix_retry,
					sizeof(fix_retry));
		if (retval != 0) {
			printk("Failed to set fix retry value\n");
			return -1;
					NRF_SOL_GNSS,
					NRF_SO_GNSS_FIX_INTERVAL,
					&fix_interval,
					sizeof(fix_interval));
		if (retval != 0) {
			printk("Failed to set fix interval value\n");
			return -1;
					NRF_SOL_GNSS,
					NRF_SO_GNSS_NMEA_MASK,
					&nmea_mask,
					sizeof(nmea_mask));
		if (retval != 0) {
			printk("Failed to set nmea mask\n");
			return -1;
	if ((ctrl == GNSS_INIT_AND_START) ||
	    (ctrl == GNSS_RESTART)) {
					NRF_SOL_GNSS,
					NRF_SO_GNSS_START,
					&delete_mask,
					sizeof(delete_mask));
		if (retval != 0) {
			printk("Failed to start GPS\n");
			return -1;
	if (ctrl == GNSS_STOP) {
					NRF_SOL_GNSS,
					NRF_SO_GNSS_STOP,
					&delete_mask,
		if (retval != 0) {
			printk("Failed to stop GPS\n");
			return -1;
	return 0;
static int init_app(void)
	int retval;
	if (setup_modem() != 0) {
		printk("Failed to initialize modem\n");
		return -1;
	retval = gnss_ctrl(GNSS_INIT_AND_START);
	return retval;
static void print_satellite_stats(nrf_gnss_data_frame_t *pvt_data)
	uint8_t  tracked          = 0;
	uint8_t  in_fix           = 0;
	uint8_t  unhealthy        = 0;
	for (int i = 0; i < NRF_GNSS_MAX_SATELLITES; ++i) {
		if ((pvt_data->pvt.sv[i].sv > 0) &&
		    (pvt_data->pvt.sv[i].sv < 33)) {
			tracked++;
			if (pvt_data->pvt.sv[i].flags &
					NRF_GNSS_SV_FLAG_USED_IN_FIX) {
				in_fix++;
					NRF_GNSS_SV_FLAG_UNHEALTHY) {
				unhealthy++;
	printk("Tracking: %d Using: %d Unhealthy: %d\n", tracked,
							 in_fix,
							 unhealthy);
static void print_gnss_stats(nrf_gnss_data_frame_t *pvt_data)
	if (pvt_data->pvt.flags & NRF_GNSS_PVT_FLAG_DEADLINE_MISSED) {
		printk("GNSS notification deadline missed\n");
	if (pvt_data->pvt.flags & NRF_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME) {
		printk("GNSS operation blocked by insufficient time windows\n");
static void print_fix_data(nrf_gnss_data_frame_t *pvt_data)
	printf("Longitude:  %f\n", pvt_data->pvt.longitude);
	printf("Latitude:   %f\n", pvt_data->pvt.latitude);
	printf("Altitude:   %f\n", pvt_data->pvt.altitude);
	printf("Speed:      %f\n", pvt_data->pvt.speed);
	printf("Heading:    %f\n", pvt_data->pvt.heading);
	printk("Date:       %02u-%02u-%02u\n", pvt_data->pvt.datetime.day,
					       pvt_data->pvt.datetime.month,
					       pvt_data->pvt.datetime.year);
	printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
					       pvt_data->pvt.datetime.minute,
					      pvt_data->pvt.datetime.seconds);
static void print_nmea_data(void)
	for (int i = 0; i < nmea_string_cnt; ++i) {
		printk("%s", nmea_strings[i]);
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
	int retval;
	retval = nrf_recv(gnss_fd,
			  gps_data,
			  sizeof(nrf_gnss_data_frame_t),
			  NRF_MSG_DONTWAIT);
	if (retval > 0) {
		switch (gps_data->data_id) {
		case NRF_GNSS_PVT_DATA_ID:
			memcpy(&last_pvt,
			       gps_data,
			       sizeof(nrf_gnss_data_frame_t));
			nmea_string_cnt = 0;
			got_fix = false;
			if ((gps_data->pvt.flags &
				NRF_GNSS_PVT_FLAG_FIX_VALID_BIT)
				== NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
				got_fix = true;
				fix_timestamp = k_uptime_get();
		case NRF_GNSS_NMEA_DATA_ID:
			if (nmea_string_cnt < 10) {
				memcpy(nmea_strings[nmea_string_cnt++],
				       gps_data->nmea,
				       retval);
		case NRF_GNSS_AGPS_DATA_ID:
			printk("\033[1;1H");
			printk("\033[2J");
			printk("New AGPS data requested, contacting SUPL server, flags %d\n",
			       gps_data->agps.data_flags);
			gnss_ctrl(GNSS_STOP);
			activate_lte(true);
			printk("Established LTE link\n");
			if (open_supl_socket() == 0) {
				printf("Starting SUPL session\n");
				supl_session(&gps_data->agps);
				printk("Done\n");
				close_supl_socket();
			activate_lte(false);
			gnss_ctrl(GNSS_RESTART);
			k_sleep(K_MSEC(2000));
	return retval;
int inject_agps_type(void *agps,
		     size_t agps_size,
		     nrf_gnss_agps_data_type_t type,
		     void *user_data)
	ARG_UNUSED(user_data);
	int retval = nrf_sendto(gnss_fd,
				agps,
				agps_size,
				0,
				&type,
				sizeof(type));
	if (retval != 0) {
		printk("Failed to send AGNSS data, type: %d (err: %d)\n",
		       type,
		       errno);
		return -1;
	printk("Injected AGPS data, flags: %d, size: %d\n", type, agps_size);
	return 0;
//static const struct spi_config spi_cfg = {
//	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
//		     SPI_MODE_CPOL | SPI_MODE_CPHA,
//	.frequency = 4000000,
//	.slave = 0,
//struct device *spi_dev;
//struct device *i2c;
//static void spi_init(void)
//    const char* const spiName = "SPI_3";
//    spi_dev = device_get_binding(spiName);
//    if (spi_dev == NULL) {
//        printk("Could not get %s device\n", spiName);
//        return;
int main()
        int err;
        bool hasData = false;
        nrf_gnss_data_frame_t gps_data;
	uint8_t cnt = 0;
        memset(&postData, 0, sizeof(postData));
	err = bsdlib_init();
	if (err)
		printk("Failed to initialize bsdlib!");
		return;
	/* Initialize AT comms in order to provision the certificate */
	err = at_comms_init();
	if (err)
		return;
	printk("Waiting for network.. \n");
	err = lte_lc_init_and_connect();
	if (err)
		printk("Failed to connect to the LTE network, err %d\n", err);
		return;
	printk("Connected to LTE Network\n");
        printk("Starting GPS application\n");
	if (init_app() != 0) {
		return -1;
        printk("Getting GPS data...\n");
	while (!hasData) {
		do {
			/* Loop until we don't have more
			 * data to read
		} while (process_gps_data(&gps_data) > 0);
		if (IS_ENABLED(CONFIG_GPS_SAMPLE_NMEA_ONLY)) {
			print_nmea_data();
		} else {
			printk("\033[2J");
			print_satellite_stats(&last_pvt);
			print_gnss_stats(&last_pvt);
			printk("---------------------------------\n");
			if (!got_fix) {
				printk("Seconds since last fix: %lld\n",
				       (k_uptime_get() - fix_timestamp) / 1000);
				cnt++;
				printk("Searching [%c]\n",
				       update_indicator[cnt%4]);
			} else {
				print_fix_data(&last_pvt);
                                printk("Fixed data receieved. Exiting loop\n");
                                hasData = true;
			printk("\nNMEA strings:\n\n");
			print_nmea_data();
			printk("---------------------------------");
		k_sleep(K_MSEC(500));
        sprintf(postGPSData, "{\"product_number\": \"%s\",\"serial_number\": \"%s\",\"token\": \"%s\",\"timestamp\": \"xxxx-xx-xx xx:xx:xx\", \"device_data\": [{\"al\": %f}, {\"ak\": %f}]}", prod_num, serial_num, tok, last_pvt.pvt.longitude, last_pvt.pvt.latitude);
	printk("HTTPS client sample started\n\r");
        sprintf(postData, "{\"product_number\": \"%s\",\"serial_number\": \"%s\",\"token\": \"%s\",\"firmware_token\": \"%s\"}", prod_num, serial_num, tok, firmware_tok);
        printk("data to be sent: %s\n", postData);
	post_request("/api/device/capture", "fleet-test.staflsystems.com", postGPSData);
	//get_request();
	while (1)
		k_cpu_idle();
    return 0;
#include "https.h"
int at_comms_init()
	int err;
	err = at_cmd_init();
	if (err)
		printk("Failed to initialize AT commands, err %d\n", err);
		return err;
	err = at_notif_init();
	if (err)
		printk("Failed to initialize AT notifications, err %d\n", err);
		return err;
	return 0;
int tls_setup(int fd)
	int err;
	int verify;
	/* Security tag that we have provisioned the certificate with */
	const sec_tag_t tls_sec_tag[] = {
		TLS_SEC_TAG,
	/* Set up TLS peer verification */
	enum
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
	verify = REQUIRED;
	err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
	if (err)
		printk("Failed to setup peer verification, err %d\n", errno);
		return err;
	/* Associate the socket with the security tag
	 * we have provisioned the certificate with.
	err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag,
					 sizeof(tls_sec_tag));
	if (err)
		printk("Failed to setup TLS sec tag, err %d\n", errno);
		return err;
	return 0;
char* parseRecv(const char *input)
	char *pch = NULL;
    //search for the end of the response headers for the meat of the content
	pch = strstr(input, "\r\n\r\n");
    //return pointer to start of what we want
	return pch;
void get_request(const char *path, const char *host)
	int err;
	int bytes, sockfd, totalBytes = 0;
	size_t off;
	struct addrinfo *res;
	struct addrinfo hints;
	char sendBuff[SEND_BUFF_SIZE];
	char recBuff[RECV_BUFF_SIZE];
	int sendLength = sprintf(sendBuff,
							 GET_TEMPLATE,
							 path,
							 host);
	memset(&hints, 0, sizeof(hints));
	hints.ai_family = AF_INET;
	hints.ai_socktype = SOCK_STREAM;
	printk("HTTP GET started..\n\r");
	err = getaddrinfo(host, NULL, &hints, &res);
	if (err)
		printk("getaddrinfo errno %d\n", errno);
		/* No clean up needed, just return */
		return;
	printk("Address info received\n\r");
	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTPS_PORT);
	sockfd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
	if (sockfd == -1)
		printk("Failed to open socket\n");
		return;
	enum
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
	int verify = OPTIONAL;
	err = setsockopt(sockfd, SOL_TLS, TLS_PEER_VERIFY, &verify,
					 sizeof(verify));
	if (err)
		printk("setsockopt err: %d\n", errno);
	err = connect(sockfd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in));
	if (err > 0)
		printk("connect err: %d\n", errno);
		return; //goto clean_up;
	off = 0;
	printk("%s\n", sendBuff);
	do
		bytes = send(sockfd, sendBuff, sendLength - off, 0);
		if (bytes < 0)
			printk("send() failed, err %d\n", errno);
		off += bytes;
	} while (off < sendLength);
	printk("Sent %d bytes\n", off);
	do
		/* TODO: make a proper timeout *
            * Current solution will just hang
            * until remote side closes connection */
		bytes = recv(sockfd, recBuff, RECV_BUFF_SIZE, 0);
		totalBytes += bytes;
		printk("total number of bytes: %d\n", totalBytes);
		printk("num bytes: %d\n", bytes);
		if (bytes < 0)
			printk("\nrecv errno: %d\n", errno);
		printk("%s\n", recBuff);
	} while (bytes > 0);
	printk("Received %d bytes\n", off);
	printk("\n\rFinished. Closing socket\r\n");
	freeaddrinfo(res);
	err = close(sockfd);
void post_request(const char *path, const char *host, char *sendData)
	int err;
	char *p = NULL; //pointer to response
	size_t off;
	memset(&recBuff, 0, sizeof(recBuff));
	int sendLength = snprintf(sendBuff,
							  500,
							  POST_TEMPLATE,
							  path,
							  host,
							  strlen(sendData),
							  SEND_DATA);
	printk("HTTP POST started..\n\r");
	if (err)
		return;
	err = tls_setup(sockfd);
	if (err)
		return;
	enum
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
					 sizeof(verify));
	if (err)
	if (err > 0)
		return; //goto cleanup
	off = 0;
	do
		if (bytes < 0)
			return;
		off += bytes;
	do
		if (bytes < 0)
	//	/* Print HTTP response */
	//	p = strstr(recBuff, "\r\n");
	//	if (p) {
	//		off = p - recBuff;
	//		recBuff[off + 1] = '\0';
	//		printk("\n>\t %s\n\n", recBuff);
	freeaddrinfo(res);
	p = parseRecv(recBuff);
	printk("Filtered response: %s", p);
6433.https.h
# Copyright (c) 2019 Nordic Semiconductor
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
cmake_minimum_required(VERSION 3.8.2)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(NONE)
target_sources(app PRIVATE src/main.c)
zephyr_include_directories(src)
add_subdirectory(src/https)
CONFIG_BSD_LIBRARY=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEWLIB_LIBC=y
CONFIG_AT_CMD=y
CONFIG_AT_NOTIF=y
# Enable SUPL client support
CONFIG_SUPL_CLIENT_LIB=n
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Disable native network stack to save some memory
CONFIG_NET_NATIVE=n
CONFIG_MODEM_KEY_MGMT=y
CONFIG_LTE_LINK_CONTROL=y
# Main thread
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_STACK_SIZE=4096
  • Hi Didrik,
    Thanks again for the providing this information. It looks like the PSM option may be the best for our application. We are sending CAN data from our BMS over HTTPS every second, but also sending GPS data over HTTPS every 5 seconds, and since we can only re attach to the network 30 times per hour, PSM may be our only option. We are generally sending data, not so much receiving data over the network. The only time we receive data from our servers is once during boot-up when we check for firmware updates and certain parameters for our device (CAN capture rate, etc..). Also we are using Hologram sim cards.
    Thanks again for all the detailed info, we greatly appreciate it!
    Sincerely,
    Kyle Garland
  • Do you need to send the BMS data every second?
    To me, it does not sound like the GPS will be able to run between each transmission.
    In the LTE network, after you send somthing, there is a period where you have to stay connected to the tower and listen for incomming messages. This period is usually longer than 1 second, which means that the GPS would not be able to run in between.
    Depending on the network etc., it might be possible to tweak the performance so that it is possible, but the easiest would be to reduce the number of times you send data.
    Another option would be to use an external GPS module. Then, you would be able to run GPS and LTE in parallell, which should make your use case possible.
  • Yeah sending BMS data frequently is crucial to our fleet management application.
    I agree it doesn't seem plausible for GPS to run in between, so I think an external GPS module may be necessary. Does Nordic have separate GPS modules that you recommend?
    Thanks for all your help Didrik!
     For that, you should ask your Regional Sales Manager.
    If you do not know how to contact your RSM, you can send me a private message with your location, and I will provide the contact information.
