NRF9160 & freeRTOS nrf_connect() always times out
I am working on a project which requires using FreeRTOS with the nrf9160.
Setup:
- Boards tested on:actinius icarus, Thingy91)
- VS-Code with Ceedling as build tool.
- J-Link base
- bsdlib version 0.8.1
- Swisscom SIM
I ported the the Zephry example https_example to both the bare-metal and freeRTOS version.
My issue arises with the nrf_connect() API call which does always return -1, with NRF_ETIMEDOUT (60).
I am doing my developpment on two version:
- A bare-metal version where every thing works.
- A freeRTOS version which does always timeout on nrf_connect(fd, res->ai_addr, sizeof(struct nrf_sockaddr_in));
Attempting to fix this issue, I used the example https_example from the nrf sdk.
Both are identical to the Zephry version with exception of calling directly the nrf9160 bsdlib API.
The bare-metal works a treat, the freeRTOS does not.
Some things I tried:
- I used the bare-metal bsd_os.c in my freertos version, to ensure the issue does not come from there. The error is still there.
- I used a blocking only version (from the sdk porting guide template) of bsd_os.c The error is still there.
- I used the same security tag & certificates for the bare-metal and freertos versions. I can assure the certificate is correct in both applications.
- I know the network is connected, because the app is able to resolve google.com and other websites (to ensure they are not in a cache on the device) before opening the TLS.
Could freeRTOS alter configurations with are done by bsdlib, or alter timings in a significant way?
Does someone have experience with freeRTOS on nrf9160?
Do you have any hints ?
If I get this to work, I'll happily share the freeRTOS implementation.
Sincerly,
Manu
  • Sorry for my late answer, we did put this project on hold until february/march.
    I have attached the FreeRTOS bsd_lib.c and the bare-metal version which worked (bsd_os.minimal.c).
    As for the bare-metal version, I only noticied that it worked, but I am not confident that it works in every situation.
    After all it has no mechanism to unlock itself from the timeout. I only noticed that it does strangely work in this situation.
    I have not been able to work to this project.
    I will try to get back to this by march.
    // This is an independent project of an individual developer. Dear PVS-Studio, please check it.
    // PVS-Studio Static Code Analyzer for C, C++, C#, and Java: http://www.viva64.com
    #include <string.h>
    #include <errno.h>
    #include "nrf.h"
    #include "def.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "queue.h"
    #include "semphr.h"
    #include "nrf_errno.h"
    #include "bsd_os.h"
    #include "bsd_platform.h"
    #include "bsd_limits.h"
    FILENUM(94441);
    #define BSD_OS_TRACE_IRQ          EGU2_IRQn
    #define BSD_OS_TRACE_IRQ_PRIORITY 6
    #define BSD_APPLICATION_IRQ       EGU1_IRQn
    static volatile TaskHandle_t sWaitingTaskHandleTbl[BSD_MAX_SOCKET_COUNT];
    static volatile UInt32 sWaitingTaskCount = 0;
    int32_t bsd_os_timedwait(uint32_t context, int32_t *timeout)
        // See https://github.com/nrfconnect/sdk-nrf/blob/master/lib/bsdlib/bsd_os.c
        UNUSED(context);
        TickType_t start = pdTICKS_TO_MS(xTaskGetTickCount());
        TickType_t sleepTime;
        // We can't do an infinite wait
        if(*timeout == 0)
            return(NRF_ETIMEDOUT);
        if((*timeout) < 0)
            // wait forwever, or at least the maximum possible.
            sleepTime = portMAX_DELAY;
            sleepTime = pdMS_TO_TICKS(*timeout);
         * Add this tag to the list of sleeping tasks.
        taskENTER_CRITICAL();
        size_t index = 0;
        // Loop in the table until you find the first emtpy (NULL) space.
        for(index = 0; (index < ARRAY_SIZE(sWaitingTaskHandleTbl)) && (NULL != sWaitingTaskHandleTbl[index]);
            index++)
            continue;
        if(index == ARRAY_SIZE(sWaitingTaskHandleTbl))
            // No space, this should never happen.
            assert(false);
            NVIC_SystemReset();
        sWaitingTaskHandleTbl[index] = xTaskGetCurrentTaskHandle();
        sWaitingTaskCount += 1;
        taskEXIT_CRITICAL();
        // Wait for bsd_os_application_irq_clear() to wakeup this thread.
        // return NRF_ETIMEOUT or remaining time depending on timer.
        ulTaskNotifyTake(pdFAIL, sleepTime);
        sWaitingTaskHandleTbl[index] = NULL;
        sWaitingTaskCount -= 1;
        if(sleepTime == portMAX_DELAY)
            return(0);
        /* Calculate how much time is left until timeout. */
        UInt32 now = pdTICKS_TO_MS(xTaskGetTickCount());
        Int64 remaining = (Int64)(*timeout) - (now - start);
        *timeout = (remaining > 0) ? remaining : 0;
        if(*timeout == 0)
        return(0);
    /// Function required by BSD library. We need to set the EGU1 interrupt.
    void bsd_os_application_irq_set(void)
        NVIC_SetPendingIRQ(BSD_APPLICATION_IRQ);
    /// Function required by BSD library. We need to clear the EGU1 interrupt.
    void bsd_os_application_irq_clear(void)
        NVIC_ClearPendingIRQ(BSD_APPLICATION_IRQ);
    /// Function required by BSD library. We need to set the EGU2 interrupt.
    void bsd_os_trace_irq_set(void)
        NVIC_SetPendingIRQ(BSD_OS_TRACE_IRQ);
    /// Function required by BSD library. We need to clear the EGU2 interrupt.
    void bsd_os_trace_irq_clear(void)
        NVIC_ClearPendingIRQ(BSD_OS_TRACE_IRQ);
    void read_task_create(void)
        // The read task is achieved using SW interrupt.
        NVIC_SetPriority(BSD_APPLICATION_IRQ, BSD_APPLICATION_IRQ_PRIORITY);
        NVIC_EnableIRQ(BSD_APPLICATION_IRQ);
    void trace_task_create(void)
        NVIC_SetPriority(BSD_OS_TRACE_IRQ, BSD_OS_TRACE_IRQ_PRIORITY);
        NVIC_EnableIRQ(BSD_OS_TRACE_IRQ);
    void bsd_os_init(void)
        memset((UInt8 *)sWaitingTaskHandleTbl, 0, sizeof(sWaitingTaskHandleTbl));
        read_task_create();
        trace_task_create();
    int32_t bsd_os_trace_put(const uint8_t *const data, uint32_t len)
        UNUSED(data);
        UNUSED(len);
        return(0);
    /// Function required by BSD library. Stores an error code we can read later.
    void bsd_os_errno_set(int err_code)
        // Translate nrf_errno.h errno to the OS specific value.
        errno = err_code;
    void EGU1_IRQHandler(void)
        bsd_os_application_irq_handler();
        // Wakup sleeping/timeout threads.
        BaseType_t xHigherPriorityTaskWoken;
        UInt32 sleeperNotified = 0;
        size_t i = 0;
        while(sleeperNotified < sWaitingTaskCount)
            assert(i < ARRAY_SIZE(sWaitingTaskHandleTbl));
            xHigherPriorityTaskWoken = pdFALSE;
            TaskHandle_t hdl = sWaitingTaskHandleTbl[i];
            if(hdl != null)
                vTaskNotifyGiveFromISR(hdl, &xHigherPriorityTaskWoken);
                sleeperNotified += 1;
            i += 1;
        portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
    void EGU2_IRQHandler(void)
        bsd_os_trace_irq_handler();
    #include <string.h>
    #include <errno.h>
    #include "nrf.h"
    #include "def.h"
    #include "xfTimeout.h"
    #include "bsd_os.h"
    FILENUM(94441);
        UNUSED(context);
        if(*timeout < 0)
            return(0);
        Int16 timeoutHandle = xfTimeout_CreateTimeout(*timeout);
        assert(timeoutHandle >= 0);
        while(false == xfTimeout_HasTimedOut(timeoutHandle))
            __asm("nop");
        xfTimeout_ReleaseTimeout(timeoutHandle);
        //return(0);
        read_task_create();
        UNUSED(data);
        UNUSED(len);
        return(0);
        errno = err_code;
    // void IPC_IRQHandler(void)
    As for the nrf_connect context, it is called by this code.
    static TransportStatus_t prv_OpenTLSSocket(NetworkContext_t *pNetworkContext)
        int err;
        /* Security tag that we have provisioned the certificate with */
        const nrf_sec_tag_t tls_sec_tag[] = {
            pNetworkContext->TLSSecureTag
        /* Set up TLS peer verification */
        enum {
            NONE = 0,
            OPTIONAL = 1,
            REQUIRED = 2,
        nrf_sec_peer_verify_t verify = (nrf_sec_peer_verify_t)REQUIRED;
        int sock = nrf_socket(NRF_AF_INET, NRF_SOCK_STREAM, NRF_SPROTO_TLS1v2);
        if(sock == -1)
            logWarn("Failed to create socket, err %d\n", errno);
            return(NRF_TRANSPORTSTATUS_CONNECT_FAILURE);
        err = nrf_setsockopt(sock, NRF_SOL_SECURE, NRF_SO_SEC_PEER_VERIFY, &verify, sizeof(verify));
        if(err)
            logError("Failed to setup peer verification, err %d\n", errno);
            nrf_close(sock);
            return(NRF_TRANSPORTSTATUS_INVALID_PARAMETER);
        // err = nrf_setsockopt(sock, NRF_SOL_SECURE, NRF_SO_HOSTNAME, pNetworkContext->Url, strlen(pNetworkContext->Url));
        // if(err)
        //     logError("Failed to setup TLS hostname, err %d\n", errno);
        //     nrf_close(sock);
        //     return(NRF_TRANSPORTSTATUS_INVALID_PARAMETER);
        struct nrf_timeval nrf_timeo;
        nrf_timeo.tv_sec = 10;
        nrf_timeo.tv_usec = 0;
        err = nrf_setsockopt(sock, NRF_SOL_SECURE, NRF_SO_RCVTIMEO, &nrf_timeo, sizeof(struct nrf_timeval));
        if(err)
            logError("Failed to setup RCVTTIMEO hostname, err %d\n", errno);
            nrf_close(sock);
         * Associate the socket with the security tag
         * we have provisioned the certificate with.
        err = nrf_setsockopt(sock, NRF_SOL_SECURE, NRF_SO_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
        if(err)
            logWarn("Failed to setup TLS sec tag, err %d\n", errno);
            nrf_close(sock);
        char dest[64];
        nrf_inet_ntop(NRF_AF_INET, (struct nrf_sockaddr *)&(pNetworkContext->ServerAddr.sin_addr), dest, 64);
         * Connect
        logInfo("Opening TLS socket to cloud on ip: %s", dest);
        err = nrf_connect(sock, &(pNetworkContext->ServerAddr), sizeof(struct nrf_sockaddr_in));
        if(err)
            logError("nrf_connect() over TLS failed, err: %d", errno);
            nrf_close(sock);
        pNetworkContext->Socket = sock;
        return(NRF_TRANSPORTSTATUS_SUCCESS);
    I did not try the newer versions of the modem firmware, which seems to fix some things related to TCP.
    Until then, thank you for your time.
    I hope to find some time before to narrow down the problem.
