Problem with signing images for OTA DFU
I have had several problems with signing images, so I'll start with something simple, and I hope you can bear with me as I get to my final goal which is to OTA (which I am already doing, but not signed) with the project we are working on.
I am testing everything on a nrf52dk_nrf52832 using both windows 10 and ubuntu 20 VM's and I have had similar problems with both of them. I am using NCS v1.3.2 in both cases. I am not a beginner in Zephyr, or Nordic in general for that matter, but I feel like one with the whole signing, mcumgr cli using the 840 as HCI_USB in ubuntu, etc
Firstly, there are two "how to " pages that do not work following directions, so if you would kindly tell me what is wrong with the instructions.
Please advice.
The first page is "Signing Binaries
Following instructions, the first line has no problem...
antonio@ubuntu:~/ncs$ west build -b nrf52dk_nrf52832 -s bootloader/mcuboot/boot/zephyr -d build-mcuboot
But then the next command line...
antonio@ubuntu:~/ncs$ west build -b nrf52dk_nrf52832 -s zephyr/samples/hello_world -d build-hello-signed -- -DCONFIG_BOOTLOADER_MCUBOOT=y -DCONFIG_MCUBOOT_SIGNATURE_KEY_FILE=\"bootloader/mcuboot/root-rsa-2048.pem\"
Comes with errors...
Including boilerplate (Zephyr base): /home/antonio/ncs/zephyr/cmake/app/boilerplate.cmake
-- Application: /home/antonio/ncs/zephyr/samples/hello_world
-- Zephyr version: 2.3.0-rc1 (/home/antonio/ncs/zephyr)
-- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.5") found components: Interpreter
-- Board: nrf52dk_nrf52832
-- Found west: /home/antonio/.local/bin/west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/gnuarmemb)
-- Found BOARD.dts: /home/antonio/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
-- Generated zephyr.dts: /home/antonio/ncs/build-hello-signed/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/antonio/ncs/build-hello-signed/zephyr/include/generated/devicetree_unfixed.h
Parsing /home/antonio/ncs/zephyr/Kconfig
Loaded configuration '/home/antonio/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
Merged configuration '/home/antonio/ncs/zephyr/samples/hello_world/prj.conf'
Merged configuration '/home/antonio/ncs/build-hello-signed/zephyr/misc/generated/extra_kconfig_options.conf'
/home/antonio/ncs/build-hello-signed/zephyr/misc/generated/extra_kconfig_options.conf:3: warning: attempt to assign the value '"bootloader/mcuboot/root-rsa-2048.pem"' to the undefined symbol MCUBOOT_SIGNATURE_KEY_FILE
error: Aborting due to Kconfig warnings
CMake Error at /home/antonio/ncs/zephyr/cmake/kconfig.cmake:217 (message):
  command failed with return code: 1
  /home/antonio/ncs/zephyr/cmake/app/boilerplate.cmake:506 (include)
  /home/antonio/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /home/antonio/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
FATAL ERROR: command exited with status 1: /usr/bin/cmake -B/home/antonio/ncs/build-hello-signed -S/home/antonio/ncs/zephyr/samples/hello_world -GNinja -DBOARD=nrf52dk_nrf52832 -DCONFIG_BOOTLOADER_MCUBOOT=y '-DCONFIG_MCUBOOT_SIGNATURE_KEY_FILE="bootloader/mcuboot/root-rsa-2048.pem"'
The second page is "SMP Server Sample"
Which, again, the build and flash for the mcu_boot works ok
west build -b <board> -d build_mcuboot bootloader/mcuboot/boot/zephyr
west flash -d build_mcuboot
But when you try the sample application…
west build \
   -b nrf52dk_nrf52832 \
   samples/subsys/mgmt/mcumgr/smp_svr \
   -DOVERLAY_CONFIG=overlay-bt.conf
Works ok if you change your directory to zephyr, or if you alter the command to build fom ./ncs
But the signing has an error:
west sign -t imgtool -- --key bootloader/mcuboot/root-rsa-2048.pem
antonio@ubuntu:~/ncs$ west sign -t imgtool -- --key bootloader/mcuboot/root-rsa-2048.pem
=== image configuration:
partition offset: 49152 (0xc000)
partition size: 204800 (0x32000)
text section offset: 0 (0x0)
=== signed binaries:
bin: /home/antonio/ncs/build/zephyr/zephyr.signed.bin
Usage: imgtool sign [OPTIONS] INFILE OUTFILE
Error: Invalid value for "-H" / "--header-size": Minimum value for -H/--header-size is 32
FATAL ERROR: command exited with status 2: /home/antonio/.local/bin/imgtool sign --version 0.0.0+0 --align 4 --header-size 0 --slot-size 204800 --key bootloader/mcuboot/root-rsa-2048.pem /home/antonio/ncs/build/zephyr/zephyr.bin /home/antonio/ncs/build/zephyr/zephyr.signed.bin
    I am sorry this has taken so long, but we are still looking into this. There is also another bug in NCS 1.4 which prevents setting MCUboot overlay via CMakeLists.txt. So instead the key file must be specified on the command line similar to this instead:
    west build -b nrf52dk_nrf52832 --pristine -- -Dmcuboot_OVERLAY_CONFIG=mcuboot.conf
    That brings us a bit further, but are still some issues. I am discussing with the R&D team and hope to have a proper solution in a few days.
  • Hi Einar,
    Do you have news on this?
    I saw that there is a 1.4.1-rc1. Do you think it is fixed there?
    Thanks!
  • Hi Antonio,
    No, it is not fixed in 1.4.1. I think the only way around it for now is to set the key configurations in your app for the app and in the mcboot folder in within NCS. It has been reported though and the developers are looking at it, so I hope it will be fixed in 1.5.
  • Hi Einar,
    I tried again with the sample app smp_svr from the v1.4.1-rc1, using the default keys, not even mine, and could not make it work. It would keep reseting, I imagine because it is not accepting the primary image.
    Can you make it work with that sample code in the BLE configuration, flash the first image, create another and OTA it, and send me a step by step of how to do it?
    Or, if you prefer, copy the smp_svr folder outside ncs, like ~/Documents, make it work in the BLE configuration, flash the first image, create another and OTA it, and attach here the folder? I can just check what you did in the config files.
    At this point I am feeling helpless and I already tried everything.
    Thanks.
    I am sorry for the delay with this. I do not have a proper way of handling this yet, but the R&D team responsible has it on their list.
    There is a dirty but very simple workaround you can do though, which is to simply replace the path to the default key with the path to your key in ncs/bootloader/mcuboot/boot/zephyr/Kconfig:
    diff --git a/boot/zephyr/Kconfig b/boot/zephyr/Kconfig
    index f283e67..8028726 100644
    --- a/boot/zephyr/Kconfig
    +++ b/boot/zephyr/Kconfig
    @@ -153,7 +153,7 @@ config BOOT_SIGNATURE_KEY_FILE
     	default "root-ec-p256.pem" if BOOT_SIGNATURE_TYPE_ECDSA_P256
     	default "root-ed25519.pem" if BOOT_SIGNATURE_TYPE_ED25519
     	default "root-rsa-3072.pem" if BOOT_SIGNATURE_TYPE_RSA && BOOT_SIGNATURE_TYPE_RSA_LEN=3072
    -	default "root-rsa-2048.pem" if BOOT_SIGNATURE_TYPE_RSA && BOOT_SIGNATURE_TYPE_RSA_LEN=2048
    +	default "/Users/eith/src/smp_svr_test/test_keyfile.pem" if BOOT_SIGNATURE_TYPE_RSA && BOOT_SIGNATURE_TYPE_RSA_LEN=2048
     	help
     	  You can use either absolute or relative path.
     	  In case relative path is used, the build system assumes that it starts
    This is not ideal, but it is a simple workaround that works.
