nRF Connect SDK: How to get the system timestamp(epoch time) on nRf52840dk
Hi nRF support team,
In my application, I need to show system date and time, so I am trying to get the system epoch time by using the nRF Connect SDK on nRF52840 dev kit.
Can you please let me know, what needs to configure to get the system epoch time OR sample code to get system epoch time?
Thanks in advance.
Kalyan
  • Kalyan,
    It's been a while since I worked with this, and it was with the nRF5 SDK environment.  I basically followed the example from NordicPlayground/nrf5-calendar-example.
    https://github.com/NordicPlayground/nrf5-calendar-example
    I added the nrf_calendar.c and associated nrf_calendar.h to a SDK ble_peripheral example based project.  The NordicPlayground has a good example of how to set up the RTC and set and get time.  If you have a tm structure with the epoch time, it should be easy enough to set the RTC following the nrf_calendar example.  I didn't do much else than use the functions detailed in the NordicPlayground code.
    I was then able to use the RTC maintained time for timestamps data-logging sensor data.
    Max
  • Hi Max,
    Thanks for the response.
    I have tried Zephyr kernel timers (based on the 32k RTC) and it is working as expected and I am receiving timer event handler and able to set the RTC timer or counter.
    Kalyan
  • Wow!  This was a LONG time ago and done for some contract work under NDA.  So I can't give a full working example of the nRF52 code.  This was for a custom board with a nRF52832 module with a lot of code you wouldn't want to wallow through.  I can't say I even recall all the details to provide helpful hints.
    The code examples at the Nordic Playground aren't enough?  All I did was integrate that code into my project (I used SES) as described in this post.  The project involved setting the date and time in the nRF52832 RTC, then reading it and providing a timestamp on sensor data written into an external EEPROM.
    According to my notes, what I did was based on the SDK Blinky example into which I merged NRF_CLI and NRF_CLI_BLE_UART as well as the Nordic Playground calendar routines.  This gave a path to connect to an external internet connected device and send a command to set date and time.  Initial debugging of the CLI was done with a hardwired serial to USB cable to send the date and time from a PC.  TeraTerm on the PC could then connect to the serial port and set date and time as well as read it.  TeraTerm had a macro language which allowed you to read time from the system which then could be transmitted to the nRF52832 with a CLI command to set the time and date.  I vaguely recall using an app on a tablet called Serial BLE Terminal to test the CLI command over BLE.  I think I just entered the command manually with some date and time data.  Eventually an app would be written to use this interface with the internet time.  This was somebody else's responsibility.
    I'm not sure this is the sort of interface you're looking for.  I could probably dredge up copies of the CLI commands to set and read time.  I'm not sure this will tell you much more than outlined above.
    Max
