Flash Storage Write API has issues
I am trying to use the flash API of fstorage in my code. I have called below function at the start of my code. I want to save some integer values every 1 min interval.
Flash reading is working fine, but when writing was tried my whole code gets problem. When write api called debug messaged also doesn’t get print. I have included my c code for flash below. Kindly suggest what should be done.
Thank You.
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = fstorage_evt_handler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = FLASH_START_ADDR,         //    0x70ff0
    .end_addr   = FLASH_END_ADDR,          //     0x80000
void Flash_init(void)
 uint32_t data_1=5;
      ret_code_t rc;
      #ifdef  FLASH_12
      nrf_fstorage_api_t * p_fs_api;
     /* Initialize an fstorage instance using the nrf_fstorage_sd backend.
     * nrf_fstorage_sd uses the SoftDevice to write to flash. This implementation can safely be
     * used whenever there is a SoftDevice, regardless of its status (enabled/disabled). */
      p_fs_api = &nrf_fstorage_sd;
      rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
      APP_ERROR_CHECK(rc);
      /* It is possible to set the start and end addresses of an fstorage instance at runtime.
     * They can be set multiple times, should it be needed. The helper function below can
     * be used to determine the last address on the last page of flash memory available to
     * store data. */
//     (void) nrf5_flash_end_addr_get();
//       print_flash_info(&fstorage);
      #ifdef  UART_Flash
      printf("Flash Init=%d\n",rc);
            wait_for_flash_ready(&fstorage);
void Flash_Operation(void)
 ret_code_t rc;
 uint32_t local_var=0, data=5;
 uint8_t  len=0;
  /***********************************Flash Read *****************************************/
    #ifdef  FLASH_12
//    printf("Done.");
      rc = nrf_fstorage_read(&fstorage, FLASH_START_ADDR, &local_var, sizeof(local_var));
      #ifdef  UART_Flash
        printf("local_var=%x , RC=%x \n",local_var,rc);
        printf("Flash read Done.\n");
     /***********************************Flash read end *****************************************/
      /***********************************Flash write *****************************************/
           rc = nrf_fstorage_erase(&fstorage, FLASH_START_ADDR , 1, NULL);
            rc = nrf_fstorage_write(&fstorage, FLASH_START_ADDR , &data, sizeof(data), NULL);
                #ifdef  UART_Flash
                printf("ERR code=%d,Flash write %x\n",rc,data);
        /***********************************Flash write end *****************************************/
    I have attached the main file code. I am using SDK 15.2 with SoftDevice 6.1.0.
    I have not updated the definition of SOFTDEVICE_PRESENT  in the linker. When added more issue is coming.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <ctype.h>
    #include <string.h>
    #include "stddef.h"
    //#include "config.h"
    #include "nrf_drv_twi.h"
    #include "nrf_gpio.h"
    #include "app_error.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nrf_drv_clock.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_cli.h"
    #include "nrf_cli_uart.h"
    #include "nrf_fstorage.h"
    #include "nrf_fstorage_sd.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh.h"
    #include "nrf_soc.h"
    * Include section
    * User Prepared Include Files
    #include "GPIOTE_driver.h"
    #include "Relay_driver.h"
    #include "relay.h"
    #include"Timer.h"
    #include "nrf_delay.h"
    #include "PIR.h"
    #include "LED.h"
    #include "config_relay.h"
    #include "main.h"
    #include "Definations.h"
    // Constants section
    #define FLASH_START_ADDR   0x60000
    #define FLASH_END_ADDR     0x61000
    #define BUTTON_DETECTION_DELAY  APP_TIMER_TICKS(50)
    #define APP_BLE_CONN_CFG_TAG    1
    // Boolean variables section
    bool gb_PIR_Operation_Start=0;
    // Character variables section
    uint8_t gb_Power_ON_flag=0;
    // unsigned integer variables section
    uint16_t  gb_OPT_RAW_DATA, gb_OPT_CONFIGURATION_REG_DATA;
    // Signed integer variables section
    // unsigned long integer variables section
    // signed long integer variables section
    // unsigned long long integer variables section
    // signed long long integer variables section
    // Float variables section
    // Double variables section
    // Structure or Union variables section
    // Local Functions Prototypes
    void Flash_init(void);
    //void Flash_read(void);
    void Flash_Operation(void);
    #ifdef  FLASH_12
    void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage);
    // flash
    static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
    /* Dummy data to write to flash. */
    static uint32_t m_data          = 0xBADC0FFE;
    static uint32_t gb_m_data=0;
    static char     m_hello_world[] = "hello world";
    static char     gb_restored_string[50];
    /**@brief   Helper function to obtain the last address on the last page of the on-chip flash that
     *          can be used to write user data.
    static uint32_t nrf5_flash_end_addr_get()
        uint32_t const bootloader_addr = NRF_UICR->NRFFW[0];
        uint32_t const page_sz         = NRF_FICR->CODEPAGESIZE;
        uint32_t const code_sz         = NRF_FICR->CODESIZE;
        return (bootloader_addr != 0xFFFFFFFF ?
                bootloader_addr : (code_sz * page_sz));
    /**@brief   Initialize the timer. */
    static void timer_init_1(void)
    /**@brief   Sleep until an event is received. */
    static void power_manage(void)
    //#ifdef SOFTDEVICE_PRESENT
        (void) sd_app_evt_wait();
    //#else
    //    __WFE();
    //#endif
        ret_code_t rc;
        uint32_t   ram_start;
        /* Enable the SoftDevice. */
        rc = nrf_sdh_enable_request();
        rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
        rc = nrf_sdh_ble_enable(&ram_start);
    static void print_flash_info(nrf_fstorage_t * p_fstorage)
        printf("========| flash info |========");
        printf("erase unit: \t%d bytes",      p_fstorage->p_flash_info->erase_unit);
        printf("program unit: \t%d bytes",    p_fstorage->p_flash_info->program_unit);
        printf("==============================");
        if (p_evt->result != NRF_SUCCESS)
            NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
            return;
        switch (p_evt->id)
            case NRF_FSTORAGE_EVT_WRITE_RESULT:
                NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
                             p_evt->len, p_evt->addr);
            } break;
            case NRF_FSTORAGE_EVT_ERASE_RESULT:
                NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
            } break;
            case  NRF_FSTORAGE_EVT_READ_RESULT :
                          printf("Flash read sucess\n");
        /* While fstorage is busy, sleep and wait for an event. */
        while (nrf_fstorage_is_busy(p_fstorage))
            power_manage();
    // Global Functions
    void main(void)
     ret_code_t rc=0;
     uint32_t data_1=5;
        // Hardware initialization
        Hardware_INIT();
        #ifdef  FLASH_12
        // Flash initialization
          Flash_init();
        // Flash Read function
          Flash_Operation();
        printf("\r Initialization completed \r\n ");
        //Power ON Flag set
        gb_Power_ON_flag=1;
        // config all function
        // Config_all();
        //nrf_delay_ms(2000);
        gb_Calibration_Time_flag_for_OPT=0;
          // relay made off
          //x`(1);
          // load 30 sec to timer for PIR to configure
          gb_PIR_config_time=35;
          // wait time 30 sec for PIR sensor to calibrate itself
          while(gb_PIR_config_time!=0){   /* do nothing */}
          printf("delay\n");
          // nrf_drv_gpiote_out_set(const_LED);   // LED can be made ON to indicate PIR is active now
          // operation start flag is cleared
    /* Main loop */
        while (1)
        // operation
     uint32_t data_1=5;
          ret_code_t rc;
          #ifdef  FLASH_12
         * store data. */
          #ifdef  UART_Flash
    //            wait_for_flash_ready(&fstorage);
     ret_code_t rc;
     uint8_t  len=0;
        #ifdef  FLASH_12
    //    printf("Done.");
                     NRF_LOG_INFO("Enabling the SoftDevice.");
                      ble_stack_init();
          #ifdef  UART_Flash
    //           rc = nrf_fstorage_erase(&fstorage, FLASH_START_ADDR , 1, NULL);
                    #ifdef  UART_Flash
    * End of file.
  • I have just replicated the flash storage example along with sdk_config definitions. Nothing much added. May be from my side sdk_config.h definitions are missings or I am enabling different library.
    Kindly guide me to that also.
    This does not build when dropped into the flash_storage example. Also, it is a bit vague which modifications you have made and I am very interested in seeing exactly your setup so that I do not have to make assumptions and know I will see the issue you are seeing. Therefore I wonder if you can make a zip archive of the whole project folder (e.g. <SDK>\examples\peripheral\flash_fstorage\ and including all subfolder etc) and upload here? That way I  can test exactly the same setup as you? Please specify which exact project file you are using as well.
    It is a bit difficult for me to share the total code. Instead of that can you please suggest the process of adding flash storage to any code? I mean which definitions need to be enabled in sdk_config.h and which preprocessor definition need to add in the project and all the process in simple steps. So that I can try that in my code. I will roll back my all changes and try to go by your steps.
    The Flash Storage Example demonstrates exactly how to properly use fstorage. Please note that there are projects for both using and not using a SoftDevice and differences in the code (search for SOFTDEVICE_PRESENT). You also need to use nrf_fstorage_sd.c with the SoftDevice and nrf_fstorage_nvmc.c if not using a SoftDevice. Essentially you just need to do exactly the same as in the example project using SoftDevice (but you can of course skip all the CLI related stuff).
    In addition to the example projects that demonstrate this in full (including sdk_config.h), you also have the fstorage documentation that describes how fstorage works and should be used.
