I2C or SPI bridge between nrf9160 and nrf52840 (Thingy91)
Hello
I am developing a prototype with the Thingy 91 that allows to have the default log in the UART0 <-> USB and collect the data of a sensor through the P6 expansion port (nrf52 SPARE) through the UART1 of the nrf52840.
I need a bridge to share the sensor data between the nrf52840 and nrf9160 but I run into the problem that the two available UART instances are already busy. My question is if it is possible to bridge via I2C or SPI on the shared MCU_IF pins. For the nrf52840 code I am relying on the usb_uart_bridge example.
Thx!
  • Thanks for the info!
    Only that my goal is to enable an I2C for the nrf52840_pca20035 board, not the nrf52840dk_nrf52840
  • My apologies for not being clear.
    You can copy nrf52840dk_nrf52840.overlay to your project folder and rename to nrf52840_pca20035.overlay Depending on what NCS version you are on, make sure to use correct board name. From NCS v1.3.0 the board names of Thingy:91 were changed to: thingy91_nrf9160 and thingy91_nrf52840. What version of NCS are you working on?
    You can also copy the content of nrf52840dk_nrf52840.overlay and add to your nrf52840_pca20035.dts. The former will concatenate and add/overwrite settings to &i2c0, adding the bme280 as a child node to your &i2c0, providing a zephyr.dts that will look similar to:
    &i2c0 {
    	status = "okay";
    	sda-pin = <25>;
    	scl-pin = <22>;
    	clock-frequency = <I2C_BITRATE_STANDARD>;
    	bme280@77 {
    		compatible = "bosch,bme280";
    		reg = <0x77>;
    		label = "BME280";
