Hello everybody, I am using Zephyr with the nrf52840-dk device. I would like to store the DTLS credentials with a secure way. I don't want to be part of the code and thus to be written raw in flash. Any proposals?
It is difficult to say that something is secure, as there will always be limitations (and certainly are in this case). But it will be more secure. But it still remains a fact that the nRF52840 does not have secure flash nor a KMU, so your root key needs to stay in normal flash. There is no way around it. If the security is good enough of not depends on your requirements.
I should also add that with NCS 1.4 you also got the possibility to use derived keys directly in CC310, without actually exposing the derived key in normal RAM. You could do that by using e.g. mbedtls_aes_setkey_enc_shadow_key_derived() to use a derived key based on the root key you loaded with nrf_cc3xx_platform_kdr_load_key().
If it is possible to make a flash address (or sector) not readable (as you propose for the root key) why not to store there the encryption/decryption key (generated by the server during production) directly in this sector and then to make this sector unreadable. It may be stupid question
You can do that. But then you can only use it up to the point where you make the flash page accessible. If that works in your use case that is no problem, but if you need access to this at a later stage it will not work.
Thank you again. I am not expert in security for this reason I have so many question. So your idea is based that the root key is saved in normal flash but the first stage boot loader (B0) reads it and make the flash un-readable immediately so nobody can read the root key from this point. But with this method can you avoid: 1) that somebody can read the flash without power on the device and start the B0 (is it really a thing? -I have no idea-) so the B0 is not started to protect the root key area? 2) that the B0 will start but the malicious will have time to block (somehow) B0 to prevent protect the root key area.
Sorry for in details questions. I am not looking for the perfect solution, I just want to understand if the overhead of implementing secure credentials storing with this way worth it.
Nikos Karamolegkos said:But with this method can you avoid: 1) that somebody can read the flash without power on the device and start the B0 (is it really a thing? -I have no idea-) so the B0 is not started to protect the root key area?
No, you cannot. The nRF52840 is not a hardened device. For instance, If you get debug access in some manner, you can dump the entire flash.
Nikos Karamolegkos said:2) that the B0 will start but the malicious will have time to block (somehow) B0 to prevent protect the root key area.
B0 is by nature the first FW that runs, so nothing else should be able to do that. And the B0 should write protect itself using ACL before starting the next stage bootloader or app, so that it cannot be modified.
