How to receive data in the correct format when sending data to the app_timer
Hi, all
I'm using nRF52832 pca10040, s132.
Like 'ble_app_hrs' example, I changed the 'ble_app_uart' example to send data using app_timer.
In the example of 'hrs', they changed Hexa to Decimal using 'hrm_encode'. Am I right?
But what I want is.. when I send decimal data, I want 'uart_c' to receive the same decimal data.
'uart_c' successfully receive data but cannot read correctly.
I want to know why.
And I also want to understand things like situations that are transformed in the process of sending and receiving data.
This is uart example. (I added)
uint8_t           heart_rate;
heart_rate = 123;
len = sizeof(heart_rate);
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_nus->tx_handles.value_handle;
hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
hvx_params.offset = 0;
hvx_params.p_len  = len;
hvx_params.p_data = heart_rate;
err_code = sd_ble_gatts_hvx(conn_handle, &hvx_params);
and I edited 'uart_c' example like this..
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
          printf("%d\r\n", p_data[i]);
//        do
//            ret_val = app_uart_put(p_data[i]);
//            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
//                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
//                APP_ERROR_CHECK(ret_val);
//        } while (ret_val == NRF_ERROR_BUSY);
This is result.
I think this is how it should be done. )
tx_evt
1
2
0
Best Regards,
lyrics
  • I understand.. There is only one connection handle.. 0x0. (ble_app_uart_c)
    I think the data would be the same as the TX event.
    Does this mean that the central should modify the data encode of the TX side?
    If correct, I modified the ' ble_nus_chars_received_uart_print ' function of uart_c.
    Just like this..
              printf("%d \r\n", p_data[i]);
    //        do
    Or maybe I'm wrong to make this change.
    Thank you in advance. :)
    I don't see any data being passed to ble_nus_data_send_s(), only the service structure and connection handle. Can you post your implementation of this function as well?
  • sorry for late reply..
    Is this right what you said,,?
    static void data_level_meas_timeout_handler(void * p_context)
        static uint32_t cnt = 0;
        ret_code_t      err_code;
        UNUSED_PARAMETER(p_context);
        cnt++;
        err_code = ble_nus_data_send_s(&m_nus, m_conn_handle);
    uint32_t ble_nus_data_send_s(ble_nus_t * p_nus, uint16_t conn_handle)
        uint32_t err_code;
        ble_gatts_hvx_params_t     hvx_params;
        // Send value if connected and notifying
        if (conn_handle != BLE_CONN_HANDLE_INVALID)
            uint8_t          len;
            uint16_t         heart_rate;
            heart_rate = 123;
            return err_code;
  • I solved this problem using hrm_encode function... :)
