use NrfConnect SDK with 52840 dongle USB CDC Shell/console
I would like to use the USB dongle with the Openthread CLI example (and eventually an open thread app) as the SDK is just too big and overpowered for my prototypes, I would like to use the USB CDC as the Shell to communicate with the CLI and zephyr.
https://github.com/zephyrproject-rtos/zephyr/issues/16761
I also looked at the Thingy applications/connectivity bridge which is similar
I can program using nrfconnect or nrfutil, but I never see the USB CDC serial port come up after programming.
I'm using nrfconnect sdk 1.4.0 os OS X
I have added to boards
nrf52840dongle_nrf52840.overlay
/* Copyright (c) 2020 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
&uart0 {
status = "okay";
* In some default configurations within the nRF Connect SDK,
* e.g. on nRF52840, the chosen zephyr,entropy node is &cryptocell.
* This devicetree overlay ensures that default is overridden wherever it
* is set, as this application uses the RNG node for entropy exclusively.
chosen {
zephyr,entropy = &rng;
Also added a config overlay, I tried with and without some UART interrupt setting mentioned in other posts.
# Copyright (c) 2020 Nordic Semiconductor
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# Enable Thread 1.2 features
CONFIG_OPENTHREAD_THREAD_VERSION_1_2=y
CONFIG_OPENTHREAD_DUA=y
CONFIG_OPENTHREAD_MLR=y
CONFIG_OPENTHREAD_BACKBONE_ROUTER=y
CONFIG_GPIO=y
CONFIG_SENSOR=y
#CONFIG_BME280=y
#CONFIG_MCP9600=y
#CONFIG_ACS71020=y
# USB
CONFIG_USB=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_MANUFACTURER="Nordic Semiconductor"
CONFIG_USB_DEVICE_VID=0x1915
CONFIG_USB_DEVICE_PID=0x9100
CONFIG_USB_DEVICE_PRODUCT="Zephyr UART"
CONFIG_USB_CDC_ACM=y
CONFIG_UART_SHELL_ON_DEV_NAME="CDC_ACM_0"
I also added the dongle to  Allow to sample.yaml
sample:
  description: Test OpenThread Command Line Interface.
  name: OpenThread CLI sample
tests:
  samples.openthread.cli:
    build_only: true
    build_on_all: true
    tags: openthread cli
    platform_allow: nrf52840dk_nrf52840 nrf52833dk_nrf52833 nrf52840dongle_nrf52840
  • Actually I had that in my main.c, but also had a bunch of other stuff from the subways/usb/console that may have been breaking bits using it as a console.
    So I added to prj.conf ( I may see if the CONFIG_USB_UART_CONSOLE is needed, but hey this works...)
    CONFIG_GPIO=y
    CONFIG_USB=y
    CONFIG_USB_DEVICE_MANUFACTURER="SER Consulting LLC"
    CONFIG_USB_DEVICE_PRODUCT="BaseBoard Thermostat"
    CONFIG_USB_DEVICE_PID=0x520F
    CONFIG_USB_UART_CONSOLE=y
    I created a nrf52840dongle_nrf52840.overlay that is just a duplicate of the dk version
    It just needed the include and usb_enable in main.c to work. I think the extra code tried to use it as a console instead of a shell... So I may be trying to create a multi device with 2 CDC's on it, one for shell and one for console, but I'll experiment with this first. May want to add this in to the SDK as an overlay for the dongle.
  • This did work nicely until SDK 1.5.1.  With SDK 1.6.0 and 1.6.1 the USB shell does not respond anymore. Any idea what has changed with SDK 1.6.0?
