twi_sensor - override register value with TX and read it with RX - nrf52840 dk
i have an issue with i2c on my nrf52840 dk. I attached the distance sensor vl53l1x to pin 27 (SCL) and 26 (SDA) and wanted to communicate via i2c with it. To test the connection, I planned to write to a register on the vl53l1x and read the value afterwards. Problem, no matter what I write via TX, I can't read the correct written value from the sensor register. It always reads a zero.
#include <stdio.h>
#include <string.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
#define VL53L1X_ADDR        0x29U //from scan
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
uint8_t buffer = 8;
__STATIC_INLINE void data_handler(uint8_t newValue)
    NRF_LOG_INFO("New value: %d ", newValue);
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    NRF_LOG_INFO("handler!");
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(buffer);
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_vl53l1x_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = true
    err_code = nrf_drv_twi_init(&m_twi, &twi_vl53l1x_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
void sensorInit(){
    uint8_t Addr = 0x30;
	uint8_t reg[2] = {Addr, 0x10};
	err_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, &reg, sizeof(reg), false);
void sensorRead(){
    uint8_t regAddr = 0x30;
    err_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, regAddr, 1, false);
	err_code = nrf_drv_twi_rx(&m_twi, VL53L1X_ADDR, &buffer, sizeof(buffer));
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    sensorInit();
    nrf_delay_ms(500);
    while (true)
        nrf_delay_ms(500);
        sensorRead();
        NRF_LOG_FLUSH();
How I understand the i2c drv:
  1. I can send via tx an array like reg[2] = {Addr, value} with a new value to the sensor register.
  2. If I want to read a register I need to point to it, by sending just the address via tx. Then read the sensor via rx and write the read value to a buffer.
Is this correct?
So it overrides the initialized value (8) of the buffer, therefore i think it is reading something but not the correct (written) value. I must have made a mistake somewhere?!
Ps: I use Linux, SDK17, nrf52840 DK, VL53L1X
