CPU cannot be halted
Hi to everyone!
I am using nRF52832 driven by nRF52 DK and a sensor from Maxim Integrated. As debug output i am using the RTT viewer and as IDE Keil.
When i run my code it seems to work properly but when i use the sensor (it is a like a photodetector and a led, so when i move the finger on it this will cause an interrupt) the outputs on the RTT viewer stops and i ends up to the "**JLink Warning: CPU could not be halted" warning as shown:
Even if the output of the RTT stops i can see that the sensor is continue to work properly, when my finger is detected a led  is set high.
Where this error come from? Is it a problem of the RTT window (LOG) only? if it is not, why my sensor continue to work as defined?
polimarte
