Issues with CLI over BLE Example
Hi!
I am trying to test the CLI over BLE example. I want to use it in another application for logging data to a laptop console over BLE.
However, I am having trouble following the steps in the example documentation. I can compile and run the application just fine, but I'm having trouble starting the ble_serial.py script. Here's the command I'm running:
python ble_serial.py --snr 680834186 --name Nordic_CLI --com COM115 --family NRF52
And here's the output:
  File "ble_serial.py", line 64, in <module>
    ble_driver_init(args.family[0])
  File "ble_serial.py", line 61, in ble_driver_init
    from pc_ble_driver_py import config
ImportError: No module named pc_ble_driver_py
I tried "pip3 uninstall nrfutil" and then "pip3 install nrfutil", as well as "pip3 uninstall pc_ble_driver_py" and then "pip3 install pc_ble_driver_py".
However, this does not fix the issue. Can anyone provide some guidance on what I should try? And how do I connect to the board via its destination address (step 4) on a Mac?
  • Hey Jared!
    I tried using the Mac terminal, running a command like,
    ssh user@localhost -p8889
    This causes the example to crash with an error message like,
    Connected with 127.0.0.1:56148
      File "ble_serial.py", line 242, in <module>
        b = BLE_Serial(comport, args.name, conn)
      File "ble_serial.py", line 96, in __init__
        self.adapter.driver.open()
      File "/Users/kylemassa/Library/Python/2.7/lib/python/site-packages/pc_ble_driver_py/ble_driver.py", line 127, in wrapper
        raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
    pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 3
    And the terminal exits with,
    kex_exchange_identification: read: Connection reset by peer
    EDIT: While connected to my laptop via a usb connection, the board just appears as
    /dev/tty.usbmodem0006826720121
    which is just its serial number with three 0's appended to the front. Is this the COM port I should be using in the ble_serial.py inputs?
    Thanks!
    What are you passing as parameters to the script now? Could you describe in more detail exactly what step you're at and what you're doing?
     And why are you using ssh? I think it should be enough to just type in the destination address
     Yes.
    I'm running
    python ble_serial.py --snr 682672012 --name Nordic_CLI --com COM0006826720121 --family NRF52
    which produces the output
    "Board already flashed with connectivity firmware.
    Socket created
    Socket bind complete
    Socket now listening"
    So I've completed step 3 and am working on step 4. When I type
    127.0.0.1:8889
    in a different terminal window without any command, it returns "Command not found". The output produced in my above reply is triggered when I've completed step 3 and I use ssh for step 4.
    Thanks!
    I still don't think that SSH would be the correct protocol. I'm not sure as we haven't tested the application on Mac OS AFAIK. Doing a quick google search revealed that the telnet protocol would be the appropriate one to get a raw TCP/IP connection. Could you try this one instead?
    Also, if you do have a windows computer with PuTTY available, then I strongly suggest that you use that one for testing the example.
    regards
    Jared
  • Thanks Jared! So to be clear, I am still trying to get past step 4 of the example instructions.
    In one terminal window, I ran ble_serial.py and got the following output (command included):
    Socket created
    Connected with 127.0.0.1:57604
    In another terminal window, I ran telnet as you suggested. Here is the output from that window (command included):
    telnet 127.0.0.1 8889
    Trying 127.0.0.1...
    Connected to localhost.
    Escape character is '^]'.
    Connection closed by foreign host.
    It looks like the connection is being dropped immediately after it's established. What could be causing this behavior?
