Not able to flash nRF5340 PDK anymore
Hey guys,
All of a sudden, I'm not able to flash my nRF board anymore. I get the following message when I try to connect to the board using segger IDE.
And when I try west flash, I get the following:
As per that message, when I try "west flash --log", I get unknow command error.
Any help would be appreciated.
Other info:
I'm pretty sure that it isn't a problem with the code I'm trying to flash or even anything on the PC because I have another one of the same board which works without any problem.
    First of all, make sure the board is power cycled, the J-Link OB can sometimes lock up and cause the DK to be unresponsive.
    The error log looks like it is unable to detect the family of the device. Please run the following commands. That should skip the step that generated the error, and may allow succeeding. If it still cannot work, please provide the log with --log name.log in the command. Thanks.
    nrfjprog.exe --coprocessor CP_NETWORK --recover -f NRF53
    nrfjprog.exe --coprocessor CP_APPLICATION --recover -f NRF53
    -Amanda H.
  • Hey,
    [2020-Nov-17 09:16:34] [ info] --------------------------------------------------------------------------------
    [2020-Nov-17 09:16:34] [ info] C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --coprocessor CP_APPLICATION --recover -f RF53 --log application.log
    [2020-Nov-17 09:16:34] [ info] nrfjprog version 10.11.1
    Now that I run the command, this is the only output from the log file for both cases.
    Also, the command gives an error saying the following:
    ERROR: Argument provided has a wrong value. Memory access not aligned, value
    ERROR: outside of range or similar.
    thanks
  • Sorry for the mistake, it is "-f NRF53". I have modified the previous commands. Please try again.
    -Amanda H.
  • Hey,
    No worries. I have done it again and both commands give almost the same output which has been attached below:
    [2020-Nov-18 09:07:48] [ info] --------------------------------------------------------------------------------
    [2020-Nov-18 09:07:48] [ info] C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --coprocessor CP_APPLICATION --recover -f NRF53 --log application.log
    [2020-Nov-18 09:07:48] [ info] nrfjprog version 10.11.1
    [2020-Nov-18 09:07:48] [debug] [ nRF0x0] - open_dll
    [2020-Nov-18 09:07:48] [ info] [ nRF0x0] - Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\JLINKARM_NRF53_NRFJPROG.dll.
    [2020-Nov-18 09:07:48] [ info] [ nRF0x0] - Library loaded, loading member functions.
    [2020-Nov-18 09:07:48] [ info] [ nRF0x0] - Member functions succesfully loaded.
    [2020-Nov-18 09:07:48] [ info] [Backend] - Logger callback at 0xaf1610 registered in Segger backend logger.
    [2020-Nov-18 09:07:48] [ info] [  JLink] - [Debug   ] [JLink     ] Logger callback at 0xaf1610 registered in JLink logger.
    [2020-Nov-18 09:07:48] [debug] [nRF530x0] - open
    [2020-Nov-18 09:07:48] [debug] [Backend] - open_dll
    [2020-Nov-18 09:07:48] [ info] [Backend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2020-Nov-18 09:07:48] [ info] [Backend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLinkARM.dll.
    [2020-Nov-18 09:07:48] [ info] [Backend] - Library loaded, loading member functions.
    [2020-Nov-18 09:07:48] [ info] [Backend] - Member functions succesfully loaded.
    [2020-Nov-18 09:07:48] [debug] [Backend] - dll_version
    [2020-Nov-18 09:07:48] [ info] [Backend] - Segger dll version 6.86.f loaded.
    [2020-Nov-18 09:07:48] [debug] [ nRF0x0] - enum_emu_snr
    [2020-Nov-18 09:07:48] [debug] [nRF530x0] - enum_emu_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - is_connected_to_emu
    [2020-Nov-18 09:07:48] [debug] [Backend] - enum_emu_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_enum_emu_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_get_num_emus
    [2020-Nov-18 09:07:48] [debug] [ nRF0x0] - connect_to_emu_with_snr
    [2020-Nov-18 09:07:48] [debug] [nRF530x0] - connect_to_emu_with_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - connect_to_emu_with_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_connect_to_emu_with_snr
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_connect_to_emu_without_snr
    [2020-Nov-18 09:07:48] [ info] [Backend] - Segger logging enabled.
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_load_core_data
    [2020-Nov-18 09:07:48] [ info] [  JLink] - [Debug   ] [JLink     ] Device "CORTEX-M33" selected.
    [2020-Nov-18 09:07:48] [debug] [Backend] - read_debug_port_idr
    [2020-Nov-18 09:07:48] [debug] [Backend] - read_debug_port_register
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_read_debug_port_register
    [2020-Nov-18 09:07:48] [debug] [Backend] - coresight_configure
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_select_debug_port_register
    [2020-Nov-18 09:07:48] [debug] [Backend] - Select AP 255, DP Bank 0, AP Bank 255
    [2020-Nov-18 09:07:48] [error] [  JLink] - [Debug   ] [JLink     ] Not supported by current CPU + target interface combination.
    [2020-Nov-18 09:07:48] [ info] [Backend] - JLinkARM.dll reported "-2", an unknown error.
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_abort_debug_action
    [2020-Nov-18 09:07:48] [ info] [Backend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2020-Nov-18 09:07:48] [debug] [ nRF0x0] - close_dll
    [2020-Nov-18 09:07:48] [debug] [nRF530x0] - close
    [2020-Nov-18 09:07:48] [debug] [Backend] - close
    [2020-Nov-18 09:07:48] [debug] [Backend] - disconnect_from_emu
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_disconnect_from_emu
    [2020-Nov-18 09:07:48] [debug] [Backend] - is_connected_to_device
    [2020-Nov-18 09:07:48] [debug] [Backend] - ---just_is_debug_region_powered
    [2020-Nov-18 09:07:48] [debug] [Backend] - Segger Backend closed.
    [2020-Nov-18 09:07:48] [debug] [nRF530x0] - nRF family DLL closed
    It is pretty similar to the output when the family parameter was not passed
  • Hi Sethu,
    Could you try the latest version of nrfjprog v10.12.1?
    https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-Command-Line-Tools/Download
    Please let me know it can help or not. Thanks.
    -Amanda
