nRF9160 I2C_1 issue.
I used the mpu6050 sensor and did it according to 1.2 of this blog.
The driver of this sensor is in the ncs\zephyr\drivers\sensor\mpu6050 directory.Error after compiling the project:
i2c_nrfx_twim: Error 195952641 occurred for message 0
Both ncs1.3.0 and ncs1.4.0 only use I2C_1 and this error occurs, while other I2C The interface communicates normally.
prj.confg:
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_MPU6050=y
CONFIG_MPU6050_TRIGGER_NONE=y
CONFIG_SENSOR_LOG_LEVEL_WRN=y
CONFIG_I2C_1=y
nrf9160dk_nrf9160ns:
&i2c2 {
	status = "disabled";
&i2c1 {
	status = "okay";
	sda-pin = <0>;
    scl-pin = <1>;
	clock-frequency = <100000>;
	mpu6050@68 {
		compatible = "invensense,mpu6050";
		reg = <0x68>;
		status = "okay";
		label = "MPU6050";
		int-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>;
&uart1 {
main.c:
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr.h>
#include <device.h>
#include <drivers/sensor.h>
#include <stdio.h>
static const char *now_str(void)
	static char buf[16]; /* ...HH:MM:SS.MMM */
	u32_t now = k_uptime_get_32();
	unsigned int ms = now % MSEC_PER_SEC;
	unsigned int s;
	unsigned int min;
	unsigned int h;
	now /= MSEC_PER_SEC;
	s = now % 60U;
	now /= 60U;
	min = now % 60U;
	now /= 60U;
	h = now;
	snprintf(buf, sizeof(buf), "%u:%02u:%02u.%03u",
		 h, min, s, ms);
	return buf;
static int process_mpu6050(struct device *dev)
	struct sensor_value temperature;
	struct sensor_value accel[3];
	struct sensor_value gyro[3];
	int rc = sensor_sample_fetch(dev);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_ACCEL_XYZ,
					accel);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_GYRO_XYZ,
					gyro);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP,
					&temperature);
	if (rc == 0) {
		printf("[%s]:%g Cel\n"
		       "  accel % f % f % f m/s/s\n"
		       "  gyro  % f % f % f rad/s\n",
		       now_str(),
		       sensor_value_to_double(&temperature),
		       sensor_value_to_double(&accel[0]),
		       sensor_value_to_double(&accel[1]),
		       sensor_value_to_double(&accel[2]),
		       sensor_value_to_double(&gyro[0]),
		       sensor_value_to_double(&gyro[1]),
		       sensor_value_to_double(&gyro[2]));
	} else {
		printf("sample fetch/get failed: %d\n", rc);
	return rc;
#ifdef CONFIG_MPU6050_TRIGGER
static struct sensor_trigger trigger;
static void handle_mpu6050_drdy(struct device *dev,
				struct sensor_trigger *trig)
	int rc = process_mpu6050(dev);
	if (rc != 0) {
		printf("cancelling trigger due to failure: %d\n", rc);
		(void)sensor_trigger_set(dev, trig, NULL);
		return;
#endif /* CONFIG_MPU6050_TRIGGER */
void main(void)
	const char *const label = DT_LABEL(DT_INST(0, invensense_mpu6050));
	struct device *mpu6050 = device_get_binding(label);
	if (!mpu6050) {
		printf("Failed to find sensor %s\n", label);
		return;
	trigger = (struct sensor_trigger) {
		.type = SENSOR_TRIG_DATA_READY,
		.chan = SENSOR_CHAN_ALL,
	if (sensor_trigger_set(mpu6050, &trigger,
			       handle_mpu6050_drdy) < 0) {
		printf("Cannot configure trigger\n");
		return;
	printk("Configured for triggered sampling.\n");
	while (!IS_ENABLED(CONFIG_MPU6050_TRIGGER)) {
		int rc = process_mpu6050(mpu6050);
		if (rc != 0) {
		k_sleep(K_SECONDS(2));
	/* triggered runs with its own thread after exit */
