AT#XHTTPCREQ serial_lte_modem does not handle chunked HTTP response
if a response to the http request is chunked (https://en.wikipedia.org/wiki/Chunked_transfer_encoding), it is not handled correctly by the serial_lte_modem.
Sometimes - e.g. if cloudflare is used, it is not possible to disable chunk encoding, so the serial_lte_modem app is unusable in these scenarios.
00> [00:03:22.707,031] <inf> httpc: Partial data received (743 bytes)
00> [00:03:22.707,061] <inf> httpc: All the data received (743 bytes)
00> [00:03:22.707,489] <inf> at_host: TX
00> 23 58 48 54 54 50 43 52  53 50 3a 37 34 33 2c 30 |#XHTTPCR SP:743,0
00> 0d 0a                                            |..
00> [00:03:22.709,625] <inf> at_host: TX
00> 22 7d 5d 2c 22 67 72 6f  75 70 22 3a 22 63 66 2d |"}],"gro up":"cf-
00> 6e 65 6c 22 2c 22 6d 61  78 5f 61 67 65 22 3a 36 |nel","ma x_age":6
00> 30 34 38 30 30 7d 0d 0a  4e 45 4c 3a 20 7b 22 72 |04800}.. NEL: {"r
00> 65 70 6f 72 74 5f 74 6f  22 3a 22 63 66 2d 6e 65 |eport_to ":"cf-ne
00> 6c 22 2c 22 6d 61 78 5f  61 67 65 22 3a 36 30 34 |l","max_ age":604
00> 38 30 30 7d 0d 0a 53 65  72 76 65 72 3a 20 63 6c |800}..Se rver: cl
00> 6f 75 64 66 6c 61 72 65  0d 0a 43 46 2d 52 41 59 |oudflare ..CF-RAY
00> 3a 20 35 66 31 62 30 35  63 34 39 66 63 35 64 34 |: 5f1b05 c49fc5d4
00> 33 66 2d 48 41 4d 0d 0a  0d 0a 44 65 76 69 63 65 |3f-HAM.. ..Device
00> 20 31 38 32 30 65 66 66  64 20 77 61 73 20 6e 6f | 1820eff d was no
00> 74 20 66 6f 75 6e 64 64  34 39 37 36 63 30 32 39 |t foundd 4976c029
00> 37 37 37 30 38 64 39 66  62 35 36 33 31 30 34 65 |77708d9f b563104e
00> 36 62 30 61 31 31 31 34  31 36 30 35 32 39 37 30 |6b0a1114 16052970
00> 33 34 3b 20 65 78 70 69  72 65 73 3d 53 75 6e 2c |34; expi res=Sun,
00> 20 31 33 2d 44 65 63 2d  32 30 20 31 39 3a 35 30 | 13-Dec- 20 19:50
00> 3a 33 34 20 47 4d 54 3b  20 70 61 74 68 3d 2f 3b |:34 GMT;  path=/;
00> 20 64 6f 6d 61 69 6e 3d  2e 67 77 78 63 6c 6f 75 | domain= .gwxclou
00> 64 2e 63 6f 6d 3b 20 48  74 74 70 4f 6e 6c 79 3b |d.com; H ttpOnly;
00> 20 53 61 6d 65 53 69 74  65 3d 4c 61 78 0d 0a 43 | SameSit e=Lax..C
00> 46 2d 43 61 63 68 65 2d  53 74 61 74 75 73 3a 20 |F-Cache- Status:
00> 44 59 4e 41 4d 49 43 0d  0a 63 66 2d 72 65 71 75 |DYNAMIC. .cf-requ
00> 65 73 74 2d 69 64 3a 20  30 36 36 34 63 31 65 65 |est-id:  0664c1ee
00> 64 63 30 30 30 30 64 34  33 66 36 38 38 37 30 30 |dc0000d4 3f688700
00> 30 30 30 30 30 30 30 31  0d 0a 52 65 70 6f 72 74 |00000001 ..Report
00> 2d 54 6f 3a 20 7b 22 65  6e 64 70 6f 69 6e 74 73 |-To: {"e ndpoints
00> 22 3a 5b 7b 22 75 72 6c  22 3a 22 68 74 74 70 73 |":[{"url ":"https
00> 3a 5c 2f 5c 2f 61 2e 6e  65 6c 2e 63 6c 6f 75 64 |:\/\/a.n el.cloud
00> 66 6c 61 72 65 2e 63 6f  6d 5c 2f 72 65 70 6f 72 |flare.co m\/repor
00> 74 3f 73 3d 4e 65 75 57  66 46 50 6b 75 47 25 32 |t?s=NeuW fFPkuG%2
00> 46 4e 61 61 4f 4f 43 65  69 70 41 51 4d 59 75 53 |FNaaOOCe ipAQMYuS
00> 75 61 69 39 36 25 32 46  7a 4e 6c 61 49 6d 50 49 |uai96%2F zNlaImPI
00> 74 72 52 44 67 7a 45 4f  55 61 4a 41 6e 78 66 51 |trRDgzEO UaJAnxfQ
00> 75 47 4f 74 34 75 34 73  52 48 46 5a 65 74 49 67 |uGOt4u4s RHFZetIg
00> 34 34 7a 34 74 6c 54 53  45 32 57 62 49 70 42 38 |44z4tlTS E2WbIpB8
00> 46 58 43 36 67 71 57 52  5a 4c 43 38 4f 69 41 41 |FXC6gqWR ZLC8OiAA
00> 44 43 7a 70 59 77 58 49  34 77 25 33 44 25 33 44 |DCzpYwXI 4w%3D%3D
00> 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00 |........ ........
00> 00 00 00 00 00 00 00                             |.......
  • Hi, thank you, this fix has indeed resolved the problem with chunked transport and cloudflare. However since I patched the file in our code, our subsequent code (json parsing etc..) is failing. I'm investigating it to see if it is related to this fix or it is a bug in our code.
    BR, Michal V.
  • So I've found where the problem is - the length of the chunk is included in the response from XHTTPCREQ and that crashes the json parser. So I belive that chunked responses are still not handled correctly. But I can confirm that the issue with buffer has been fixed.
    NRF91 log:
    00> [00:07:02.802,215] <dbg> net_http.on_message_begin: (0x20021628): -- HTTP POST response (headers) --
    00> [00:07:02.802,612] <dbg> net_http.on_status: (0x20021628): HTTP response status 200 OK
    00> [00:07:02.804,779] <dbg> net_http.print_header_field: (0x20021628): [4] Date
    00> [00:07:02.805,541] <dbg> net_http.print_header_field: (0x20021628): [29] Tue, 01 Dec 2020 14:29:39 GMT
    00> [00:07:02.806,365] <dbg> net_http.print_header_field: (0x20021628): [12] Content-Type
    00> [00:07:02.807,098] <dbg> net_http.print_header_field: (0x20021628): [31] application/json; charset=utf-8
    00> [00:07:02.807,891] <dbg> net_http.print_header_field: (0x20021628): [17] Transfer-Encoding
    00> [00:07:02.808,624] <dbg> net_http.print_header_field: (0x20021628): [7] chunked
    00> [00:07:02.809,356] <dbg> net_http.print_header_field: (0x20021628): [10] Connection
    00> [00:07:02.810,028] <dbg> net_http.print_header_field: (0x20021628): [10] keep-alive
    00> [00:07:02.810,729] <dbg> net_http.print_header_field: (0x20021628): [10] Set-Cookie
    00> [00:07:02.811,492] <dbg> net_http.print_header_field: (0x20021628): [127] __cfduid=d6359a98730e1dcfa60b181709cdefba01606832978; expires=Thu, 31-Dec-20 14:29:38 GMT; path=/; domain=.gwxcloud.com; HttpOn
    00> [00:07:02.812,438] <dbg> net_http.print_header_field: (0x20021628): [4] vary
    00> [00:07:02.814,910] <dbg> net_http.print_header_field: (0x20021628): [15] Accept-Encoding
    00> [00:07:02.815,551] <dbg> net_http.print_header_field: (0x20021628): [15] CF-Cache-Status
    00> [00:07:02.816,528] <dbg> net_http.print_header_field: (0x20021628): [7] DYNAMIC
    00> [00:07:02.817,108] <dbg> net_http.print_header_field: (0x20021628): [13] cf-request-id
    00> [00:07:02.818,267] <dbg> net_http.print_header_field: (0x20021628): [32] 06c04e94010000d44788baf000000001
    00> [00:07:02.819,305] <dbg> net_http.print_header_field: (0x20021628): [9] Report-To
    00> [00:07:02.820,190] <dbg> net_http.print_header_field: (0x20021628): [127] {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report?s=jj2GNMCYecVq5hD8ci0dB2gKd6f75hi6eoWByctGmAhyCV07FX7T8PZA76aOwnBk
    00> [00:07:02.823,120] <dbg> net_http.print_header_field: (0x20021628): [3] NEL
    00> [00:07:02.823,608] <dbg> net_http.print_header_field: (0x20021628): [39] {"report_to":"cf-nel","max_age":604800}
    00> [00:07:02.824,096] <dbg> net_http.print_header_field: (0x20021628): [6] Server
    00> [00:07:02.824,554] <dbg> net_http.print_header_field: (0x20021628): [10] cloudflare
    00> [00:07:02.850,463] <dbg> net_http.print_header_field: (0x20021628): [6] CF-RAY
    00> [00:07:02.851,165] <dbg> net_http.print_header_field: (0x20021628): [20] 5fad80666f7ad447-HAM
    00> [00:07:02.851,562] <dbg> net_http.on_headers_complete: (0x20021628): No body expected
    00> [00:07:02.851,898] <dbg> net_http.on_message_complete: (0x20021628): -- HTTP POST response (complete) --
    00> [00:07:02.852,355] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  53 50 3a 38 33 32 2c 30 |#XHTTPCR SP:832,0
    00> 0d 0a                                            |..
    00> [00:07:02.854,827] <inf> at_host: TX
    00> 48 54 54 50 2f 31 2e 31  20 32 30 30 20 4f 4b 0d |HTTP/1.1  200 OK.
    00> 0a 44 61 74 65 3a 20 54  75 65 2c 20 30 31 20 44 |.Date: T ue, 01 D
    00> 65 63 20 32 30 32 30 20  31 34 3a 32 39 3a 33 39 |ec 2020  14:29:39
    00> 20 47 4d 54 0d 0a 43 6f  6e 74 65 6e 74 2d 54 79 | GMT..Co ntent-Ty
    00> 70 65 3a 20 61 70 70 6c  69 63 61 74 69 6f 6e 2f |pe: appl ication/
    00> 6a 73 6f 6e 3b 20 63 68  61 72 73 65 74 3d 75 74 |json; ch arset=ut
    00> 66 2d 38 0d 0a 54 72 61  6e 73 66 65 72 2d 45 6e |f-8..Tra nsfer-En
    00> 63 6f 64 69 6e 67 3a 20  63 68 75 6e 6b 65 64 0d |coding:  chunked.
    00> 0a 43 6f 6e 6e 65 63 74  69 6f 6e 3a 20 6b 65 65 |.Connect ion: kee
    00> 70 2d 61 6c 69 76 65 0d  0a 53 65 74 2d 43 6f 6f |p-alive. .Set-Coo
    00> 6b 69 65 3a 20 5f 5f 63  66 64 75 69 64 3d 64 36 |kie: __c fduid=d6
    00> 33 35 39 61 39 38 37 33  30 65 31 64 63 66 61 36 |359a9873 0e1dcfa6
    00> 30 62 31 38 31 37 30 39  63 64 65 66 62 61 30 31 |0b181709 cdefba01
    00> 36 30 36 38 33 32 39 37  38 3b 20 65 78 70 69 72 |60683297 8; expir
    00> 65 73 3d 54 68 75 2c 20  33 31 2d 44 65 63 2d 32 |es=Thu,  31-Dec-2
    00> 30 20 31 34 3a 32 39 3a  33 38 20 47 4d 54 3b 20 |0 14:29: 38 GMT;
    00> 70 61 74 68 3d 2f 3b 20  64 6f 6d 61 69 6e 3d 2e |path=/;  domain=.
    00> 67 77 78 63 6c 6f 75 64  2e 63 6f 6d 3b 20 48 74 |gwxcloud .com; Ht
    00> 74 70 4f 6e 6c 79 3b 20  53 61 6d 65 53 69 74 65 |tpOnly;  SameSite
    00> 3d 4c 61 78 0d 0a 76 61  72 79 3a 20 41 63 63 65 |=Lax..va ry: Acce
    00> 70 74 2d 45 6e 63 6f 64  69 6e 67 0d 0a 43 46 2d |pt-Encod ing..CF-
    00> 43 61 63 68 65 2d 53 74  61 74 75 73 3a 20 44 59 |Cache-St atus: DY
    00> 4e 41 4d 49 43 0d 0a 63  66 2d 72 65 71 75 65 73 |NAMIC..c f-reques
    00> 74 2d 69 64 3a 20 30 36  63 30 34 65 39 34 30 31 |t-id: 06 c04e9401
    00> 30 30 30 30 64 34 34 37  38 38 62 61 66 30 30 30 |0000d447 88baf000
    00> 30 30 30 30 30 31 0d 0a  52 65 70 6f 72 74 2d 54 |000001.. Report-T
    00> 6f 3a 20 7b 22 65 6e 64  70 6f 69 6e 74 73 22 3a |o: {"end points":
    00> 5b 7b 22 75 72 6c 22 3a  22 68 74 74 70 73 3a 5c |[{"url": "https:\
    00> 2f 5c 2f 61 2e 6e 65 6c  2e 63 6c 6f 75 64 66 6c |/\/a.nel .cloudfl
    00> 61 72 65 2e 63 6f 6d 5c  2f 72 65 70 6f 72 74 3f |are.com\ /report?
    00> 73 3d 6a 6a 32 47 4e 4d  43 59 65 63 56 71 35 68 |s=jj2GNM CYecVq5h
    00> 44 38 63 69 30 64 42 32  67 4b 64 36 66 37 35 68 |D8ci0dB2 gKd6f75h
    00> 69 36 65 6f 57 42 79 63  74 47 6d 41 68 79 43 56 |i6eoWByc tGmAhyCV
    00> 30 37 46 58 37 54 38 50  5a 41 37 36 61 4f 77 6e |07FX7T8P ZA76aOwn
    00> 42 6b 42 55 33 36 68 54  78 58 30 42 6f 70 48 53 |BkBU36hT xX0BopHS
    00> 37 6f 6e 63 50 69 79 75  52 6d 78 34 52 43 77 58 |7oncPiyu Rmx4RCwX
    00> 67 51 6f 6b 68 69 49 36  37 49 4c 77 30 6a 57 75 |gQokhiI6 7ILw0jWu
    00> 38 4d 4f 67 25 33 44 25  33 44 22 7d 5d 2c 22 67 |8MOg%3D% 3D"}],"g
    00> 72 6f 75 70 22 3a 22 63  66 2d 6e 65 6c 22 2c 22 |roup":"c f-nel","
    00> 6d 61 78 5f 61 67 65 22  3a 36 30 34 38 30 30 7d |max_age" :604800}
    00> 0d 0a 4e 45 4c 3a 20 7b  22 72 65 70 6f 72 74 5f |..NEL: { "report_
    00> 74 6f 22 3a 22 63 66 2d  6e 65 6c 22 2c 22 6d 61 |to":"cf- nel","ma
    00> 78 5f 61 67 65 22 3a 36  30 34 38 30 30 7d 0d 0a |x_age":6 04800}..
    00> 53 65 72 76 65 72 3a 20  63 6c 6f 75 64 66 6c 61 |Server:  cloudfla
    00> 72 65 0d 0a 43 46 2d 52  41 59 3a 20 35 66 61 64 |re..CF-R AY: 5fad
    00> 38 30 36 36 36 66 37 61  64 34 34 37 2d 48 41 4d |80666f7a d447-HAM
    00> 0d 0a 0d 0a 35 36 0d 0a  7b 22 64 61 74 61 22 3a |....56.. {"data":
    00> 22 33 35 38 32 65 32 31  39 32 39 30 30 39 39 64 |"3582e21 9290099d
    00> 38 62 34 38 62 66 61 34  38 31 34 38 65 39 64 35 |8b48bfa4 8148e9d5
    00> 34 64 31 38 34 35 64 63  64 64 36 62 30 62 66 32 |4d1845dc dd6b0bf2
    00> 37 63 30 37 64 30 30 66  30 63 36 61 32 32 31 66 |7c07d00f 0c6a221f
    00> 61 22 2c 22 63 6d 64 22  3a 6e 75 6c 6c 7d 0d 0a |a","cmd" :null}..
    On the line 79, it can be seen that there is: CR LF CR LF (separator of headers and body in HTTP) 56 CR LF (hex length of the chunk and CR LF as chunk length separator), the `56 CR LF` should not be there.
    `00> 0d 0a 0d 0a 35 36 0d 0a  7b 22 64 61 74 61 22 3a |....56.. {"data":`
    In this simple case we can work around the issue, but I'm not sure whether the solution would hold if the body is transferred in more than one chunk.
  • Good to hear that the fix worked to a certain extent even though it revealed more issues. I'm working with the developer to sort it out!
    Carl Richard
  • Hi again, Michal!
    A fix should have been pushed to the NCS master branch now. As described in the pull request the body was skipped. If you want to stay on 1.4.0 remove the following code from zephyr/subsys/net/lib/http/http_client.c
    if ((req->method == HTTP_PUT || req->method == HTTP_POST) &&
        req->internal.response.content_length == 0) {
    	NET_DBG("No body expected");
    	return 1;
    This should also fix the issue with the modem crashing, mentioned in your other ticket. Please report back there if it doesn't!
    Carl Richard
    Thank you for the fix - now it seems to me that the DBG message is gone, but the problem persists as the response still contains "headers" of the individual chunks.
    00> 23 58 48 54 54 50 43 52  45 51 3a 30 0d 0a       |#XHTTPCR EQ:0..
    00> [00:07:58.417,144] <dbg> net_http.http_client_req: (0x20021628): Sent 190 bytes
    00> [00:07:59.161,193] <dbg> net_http.on_message_begin: (0x20021628): -- HTTP POST response (headers) --
    00> [00:07:59.162,261] <dbg> net_http.on_status: (0x20021628): HTTP response status 200 OK
    00> [00:07:59.163,055] <dbg> net_http.print_header_field: (0x20021628): [4] Date
    00> [00:07:59.163,787] <dbg> net_http.print_header_field: (0x20021628): [29] Mon, 07 Dec 2020 17:04:48 GMT
    00> [00:07:59.164,611] <dbg> net_http.print_header_field: (0x20021628): [12] Content-Type
    00> [00:07:59.165,344] <dbg> net_http.print_header_field: (0x20021628): [31] application/json; charset=utf-8
    00> [00:07:59.166,137] <dbg> net_http.print_header_field: (0x20021628): [17] Transfer-Encoding
    00> [00:07:59.166,870] <dbg> net_http.print_header_field: (0x20021628): [7] chunked
    00> [00:07:59.167,602] <dbg> net_http.print_header_field: (0x20021628): [10] Connection
    00> [00:07:59.170,166] <dbg> net_http.print_header_field: (0x20021628): [10] keep-alive
    00> [00:07:59.170,867] <dbg> net_http.print_header_field: (0x20021628): [10] Set-Cookie
    00> [00:07:59.171,936] <dbg> net_http.print_header_field: (0x20021628): [127] __cfduid=d9f449204d08bfbd44f220c8051bf75ce1607360688; expires=Wed, 06-Jan-21 17:04:48 GMT; path=/; domain=.gwxcloud.com; HttpOn
    00> [00:07:59.172,912] <dbg> net_http.print_header_field: (0x20021628): [4] Vary
    00> [00:07:59.173,980] <dbg> net_http.print_header_field: (0x20021628): [15] Accept-Encoding
    00> [00:07:59.175,018] <dbg> net_http.print_header_field: (0x20021628): [15] CF-Cache-Status
    00> [00:07:59.175,933] <dbg> net_http.print_header_field: (0x20021628): [7] DYNAMIC
    00> [00:07:59.176,513] <dbg> net_http.print_header_field: (0x20021628): [13] cf-request-id
    00> [00:07:59.177,154] <dbg> net_http.print_header_field: (0x20021628): [32] 06dfc2c7880000d9055a0d0000000001
    00> [00:07:59.177,795] <dbg> net_http.print_header_field: (0x20021628): [9] Report-To
    00> [00:07:59.178,436] <dbg> net_http.print_header_field: (0x20021628): [127] {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report?s=7ZqXcSGhkNFV%2FsOiuiL4QZsTPwu6xPX5iP6hLIhx6WF16taysh%2B0lic8osfS
    00> [00:07:59.179,229] <dbg> net_http.print_header_field: (0x20021628): [3] NEL
    00> [00:07:59.179,687] <dbg> net_http.print_header_field: (0x20021628): [39] {"report_to":"cf-nel","max_age":604800}
    00> [00:07:59.186,004] <dbg> net_http.print_header_field: (0x20021628): [6] Server
    00> [00:07:59.186,401] <dbg> net_http.print_header_field: (0x20021628): [6] cloudf
    00> [00:07:59.224,151] <dbg> net_http.print_header_field: (0x20021628): [4] lare
    00> [00:07:59.224,639] <dbg> net_http.print_header_field: (0x20021628): [6] CF-RAY
    00> [00:07:59.255,035] <dbg> net_http.print_header_field: (0x20021628): [20] 5fdfd3ec0a7cd905-AMS
    00> [00:07:59.255,798] <dbg> net_http.on_headers_complete: (0x20021628): Headers complete
    00> [00:07:59.256,164] <dbg> net_http.on_body: (0x20021628): Processed 86 length 86
    00> [00:07:59.256,500] <dbg> net_http.on_body: (0x20021628): Calling callback for partitioned 838 len data
    00> [00:07:59.256,988] <dbg> net_http.on_message_complete: (0x20021628): -- HTTP POST response (complete) --
    00> [00:07:59.257,843] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  53 50 3a 38 34 33 2c 30 |#XHTTPCR SP:843,0
    00> 0d 0a                                            |..
    00> [00:07:59.260,345] <inf> at_host: TX
    00> 0a 44 61 74 65 3a 20 4d  6f 6e 2c 20 30 37 20 44 |.Date: M on, 07 D
    00> 65 63 20 32 30 32 30 20  31 37 3a 30 34 3a 34 38 |ec 2020  17:04:48
    00> 6b 69 65 3a 20 5f 5f 63  66 64 75 69 64 3d 64 39 |kie: __c fduid=d9
    00> 66 34 34 39 32 30 34 64  30 38 62 66 62 64 34 34 |f449204d 08bfbd44
    00> 66 32 32 30 63 38 30 35  31 62 66 37 35 63 65 31 |f220c805 1bf75ce1
    00> 36 30 37 33 36 30 36 38  38 3b 20 65 78 70 69 72 |60736068 8; expir
    00> 65 73 3d 57 65 64 2c 20  30 36 2d 4a 61 6e 2d 32 |es=Wed,  06-Jan-2
    00> 31 20 31 37 3a 30 34 3a  34 38 20 47 4d 54 3b 20 |1 17:04: 48 GMT;
    00> 3d 4c 61 78 0d 0a 56 61  72 79 3a 20 41 63 63 65 |=Lax..Va ry: Acce
    00> 74 2d 69 64 3a 20 30 36  64 66 63 32 63 37 38 38 |t-id: 06 dfc2c788
    00> 30 30 30 30 64 39 30 35  35 61 30 64 30 30 30 30 |0000d905 5a0d0000
    00> 73 3d 37 5a 71 58 63 53  47 68 6b 4e 46 56 25 32 |s=7ZqXcS GhkNFV%2
    00> 46 73 4f 69 75 69 4c 34  51 5a 73 54 50 77 75 36 |FsOiuiL4 QZsTPwu6
    00> 78 50 58 35 69 50 36 68  4c 49 68 78 36 57 46 31 |xPX5iP6h LIhx6WF1
    00> 36 74 61 79 73 68 25 32  42 30 6c 69 63 38 6f 73 |6taysh%2 B0lic8os
    00> 66 53 4a 73 34 38 48 68  6e 53 4b 5a 6d 62 6a 62 |fSJs48Hh nSKZmbjb
    00> 41 44 25 32 42 47 76 30  62 31 41 57 36 34 4e 77 |AD%2BGv0 b1AW64Nw
    00> 36 69 53 43 64 4f 59 72  38 57 4f 30 6a 5a 30 35 |6iSCdOYr 8WO0jZ05
    00> 4f 47 51 4d 55 32 62 6d  48 67 25 33 44 25 33 44 |OGQMU2bm Hg%3D%3D
    00> 3a 20 35 66 64 66 64 33  65 63 30 61 37 63 64 39 |: 5fdfd3 ec0a7cd9
    00> 30 35 2d 41 4d 53 0d 0a  0d 0a 35 36 0d 0a 7b 22 |05-AMS.. ..56..{"
    00> 64 61 74 61 22 3a 22 33  33 34 36 61 62 32 36 65 |data":"3 346ab26e
    00> 32 37 63 30 39 37 66 38  66 33 62 64 31 32 36 38 |27c097f8 f3bd1268
    00> 66 35 39 37 30 30 34 35  65 34 66 35 30 64 34 37 |f5970045 e4f50d47
    00> 37 34 38 37 66 63 34 33  61 62 34 37 37 61 36 35 |7487fc43 ab477a65
    00> 30 61 63 32 34 66 38 22  2c 22 63 6d 64 22 3a 6e |0ac24f8" ,"cmd":n
    00> 75 6c 6c 7d 0d 0a 30 0d  0a 0d 0a                |ull}..0. ...
    00> [00:07:59.302,124] <dbg> net_http.http_client_req: (0x20021628): Received 843 bytes
    In the end of the log two lines can be seen with the chunk headers:
    `00> 30 35 2d 41 4d 53 0d 0a  0d 0a 35 36 0d 0a 7b 22 |05-AMS.. ..56..{"`
    `00> 75 6c 6c 7d 0d 0a 30 0d  0a 0d 0a                |ull}..0. ...    `
    I believe the bytes `35 36 0d 0a` and `30 0d  0a 0d 0a` should not be part of the response, as they are just fragments of the http transport and have no meaning for the application communicating over HTTP. Also it would mean that the app has to parse again this response to eliminate those chunk headers.
    You can easily test this by calling:
    AT#XHTTPCCON=1,"gwxcloud.com",80
    AT#XHTTPCREQ="GET","/",""
    in the LTE Link Monitor app. In the following snippet, the ada is the chunk header.
    Server: cloudflareCF-RAY: 5fdfcd499edefa5c-AMS
    ada
    <!DOCTYPE html>
    I haven't tested the modem crashing yet.
    Thank you for your help, Michal V.
