Fail to update modem
I'm trying to update the modem on Thingy:91 using nRF Connect Programmer v3.6.0
I get these errors
18:50:16.131
Application data folder: /home/tmh/.config/nrfconnect/pc-nrfconnect-programmer
18:50:16.338
Using nrfjprog library 10.9.0, pc-nrfjprog-js 1.7.3
18:50:17.134
Error while probing devices: Error occured when get serial numbers. Errorcode: CouldNotCallFunction (0x9) Lowlevel error: INVALID_OPERATION (fffffffe)
18:50:42.133
Modem DFU starts to write...
18:50:42.133
Writing /home/tmh/src/thingy_0923/mfwnrf9160121.zip to device
18:50:42.554
MCUboot DFU failed. Please make sure that the device is in MCUboot mode and try again.
I tried to update the
thingy91_ltem_dfu_2020-09-23_b6ad40d0.bin
and
thingy91_nrf52_usb_uart_bridge_dfu_2020-09-23_b6ad40d0.bin
using mcumgr but that does not help
I also tried
thingy91_nrf52_usb_uart_bridge_2020-10-30_5522ca2b.bin
but it never completes uploading.
I have tried using both Linux (OpenSUSE 15.2) and Windows 10
  • Updating to 3.6.1/1.4.8 seems to make to work, I was able to update modem firmware on Windows 10.
    I was not able to update on Linux.
    usb 8-5: USB disconnect, device number 9
    usb 8-5: new full-speed USB device number 10 using ohci-pci
    usb 8-5: New USB device found, idVendor=1915, idProduct=9100, bcdDevice= 2.04
    usb 8-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    usb 8-5: Product: Thingy:91 UART
    usb 8-5: Manufacturer: Nordic Semiconductor
    usb 8-5: SerialNumber: THINGY91_f1b4097f4864
    cdc_acm 8-5:1.0: ttyACM0: USB ACM device
    usb-storage 8-5:1.2: USB Mass Storage device detected
    scsi host6: usb-storage 8-5:1.2
    cdc_acm 8-5:1.3: ttyACM1: USB ACM device
    scsi 6:0:0:0: Direct-Access     ZEPHYR   ZEPHYR USB DISK  0.01 PQ: 0 ANSI: 0 CCS
    sd 6:0:0:0: Attached scsi generic sg4 type 0
    sd 6:0:0:0: [sdd] 32 512-byte logical blocks: (16.4 kB/16.0 KiB)
    sd 6:0:0:0: [sdd] Write Protect is off
    sd 6:0:0:0: [sdd] Mode Sense: 03 00 00 00
    sd 6:0:0:0: [sdd] No Caching mode page found
    sd 6:0:0:0: [sdd] Assuming drive cache: write through
    sdd:
    sd 6:0:0:0: [sdd] Attached SCSI removable disk
  • Great to hear that you got it to work on Windows!
    We will continue working on making the process easier, and figuring out why it does not work as it should on Linux.
