I have built several examples in nRF Connect SDK on MacOS and they seem to work OK.
Now trying to build the udp example
I have left the configuration as it was.
I build in the usual way
west build -b nrf9160dk_nrf9160 -p
gives
paul_tanner@iMac udp % west build -b nrf9160dk_nrf9160 -p
-- west build: making build dir /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/build pristine
Including boilerplate (Zephyr base): /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/app/boilerplate.cmake
-- Application: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp
-- Zephyr version: 2.4.0 (/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr)
-- Found Python3: /usr/local/bin/python3.7 (found suitable exact version "3.7.7") found components: Interpreter
-- Found west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160
-- Cache files will be written to: /Users/paul_tanner/Library/Caches/zephyr
-- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/Applications/ARM)
-- Found BOARD.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
nrf9160dk_nrf9160.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
nrf9160dk_nrf9160.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
-- Generated zephyr.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/build/zephyr/include/generated/devicetree_unfixed.h
Parsing /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/Kconfig
Loaded configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/prj.conf'
warning: BSD_LIBRARY (defined at /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/lib/bsdlib/Kconfig:8) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
TRUSTED_EXECUTION_NONSECURE (=n). See
docs.zephyrproject.org/.../CONFIG_BSD_LIBRARY.html and/or look up
BSD_LIBRARY in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: UART_CONSOLE (defined at drivers/console/Kconfig:47) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
docs.zephyrproject.org/.../CONFIG_UART_CONSOLE.html and/or look up
UART_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: AT_CMD (defined at /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/lib/at_cmd/Kconfig:9) has direct dependencies BSD_LIBRARY with value n, but is currently being y-selected by the following symbols:
- LTE_LINK_CONTROL (defined at /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/lib/lte_link_control/Kconfig:7), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/kconfig.cmake:239 (message):
command failed with return code: 1
/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/app/boilerplate.cmake:591 (include)
/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
CMakeLists.txt:11 (find_package)
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/local/opt/python/bin/python3.7 -B/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp/build -S/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/udp -GNinja -DBOARD=nrf9160dk_nrf9160
Also tried
west build -b nrf9160dk_nrf9160ns -p
which seems to build cleanly. when running this we get
*** Booting Zephyr OS build v2.4.0-ncs1 ***
Flash regions
Domain
Permissions
00 00 0x00000 0x08000
Secure
rwxl
01 31 0x08000 0x100000
Non-Secure
rwxl
Non-secure callable region 0 placed in flash region 0 with size 32.
SRAM region
Domain
Permissions
00 07 0x00000 0x10000
Secure
rwxl
08 31 0x10000 0x40000
Non-Secure
rwxl
Peripheral
Domain
Status
00 NRF_P0 Non-Secure
OK
01 NRF_CLOCK Non-Secure
OK
02 NRF_RTC0 Non-Secure
OK
03 NRF_RTC1 Non-Secure
OK
04 NRF_NVMC Non-Secure
OK
05 NRF_UARTE1 Non-Secure
OK
06 NRF_UARTE2 Secure
SKIP
07 NRF_TWIM2 Non-Secure
OK
08 NRF_SPIM3 Non-Secure
OK
09 NRF_TIMER0 Non-Secure
OK
10 NRF_TIMER1 Non-Secure
OK
11 NRF_TIMER2 Non-Secure
OK
12 NRF_SAADC Non-Secure
OK
13 NRF_PWM0 Non-Secure
OK
14 NRF_PWM1 Non-Secure
OK
15 NRF_PWM2 Non-Secure
OK
16 NRF_PWM3 Non-Secure
OK
17 NRF_WDT Non-Secure
OK
18 NRF_IPC Non-Secure
OK
19 NRF_VMC Non-Secure
OK
20 NRF_FPU Non-Secure
OK
21 NRF_EGU1 Non-Secure
OK
22 NRF_EGU2 Non-Secure
OK
23 NRF_DPPIC Non-Secure
OK
24 NRF_GPIOTE1 Non-Secure
OK
25 NRF_REGULATORS Non-Secure
OK
SPM: NS image at 0xc000
SPM: NS MSP at 0x200234a0
SPM: NS reset vector at 0xfaa1
SPM: prepare to jump to Non-Secure image.
and then it stalls
Any suggestions please.
