PWM library simpler way for on/off (enable/disable) than the example with SDK?
Is there a way to set duty cycle before app_pwm_enable(&PWM1) call ?
Or some other simple way to switch on and off a passive buzzer signal without every time at off/on cycle to go with complex sequence for setting duty value as per pwm_library example?
Let say some app like Morse Code where the frequency will be resonance of the buzzer and duty cycle will be constant 50 (or less).
Thanks
  • Hi, but you have in your code, that you put as example before, couple lines that using gpiote channel index?
     NRF_GPIOTE->TASKS_CLR[SOUND_GPIOTE_CH] = 1;
    NRF_PPI->CH[SOUND_PPI_CH_A].TEP = (uint32_t)&NRF_GPIOTE->TASKS_SET[SOUND_GPIOTE_CH];
    NRF_PPI->CH[SOUND_PPI_CH_B].TEP = (uint32_t)&NRF_GPIOTE->TASKS_CLR[SOUND_GPIOTE_CH];
    The only task address I could get right away is the out task I created in order to use nrf_drv_gpiote_out_init and it has same config as what you made with registers in your example?
    I by the way still didn't  clear all the mess I made with adding the code for the passive buzzer, but move one step better, by getting at least the sound working and I'm using
    gpioteChIndex = (nrfx_gpiote_out_task_get(SS_SDK_CFG_BZR_PIN) % 48) / 4;
    But if I could rid of need of gpiote channel index would be better.
    Regards
  • Hi
    There are two functions called nrfx_gpiote_set_task_addr_get(nrfx_gpiote_pin_t pin) and nrfx_gpiote_clr_task_addr_get(nrfx_gpiote_pin_t pin)
    I believe these functions should provide the task addresses you need.
    Best regards
    Torbjørn
