Timeslot API - low power optimization
I'm working with timeslot API (basing on github.com/.../observer). I have an advertising and active scanning running concurrently. However, I want to completly switch off scanning functionality for some period of time. For example, I want to scan with 15000us timeslot length and 30000us timeslot distance, but just for every 5 seconds. To manage that I have a timer running and switching on/off scanning:
static void scanner_timer_timeout_handler(void * p_context)
	btle_status_codes_t btle_err_code;
    UNUSED_PARAMETER(p_context);
	scan_run ^= true;
	if(scan_run)
		btle_err_code = btle_scan_init (SWI1_IRQn);
		scan_enable.scan_enable = BTLE_SCAN_MODE_ENABLE;
		btle_err_code = btle_scan_enable_set (scan_enable);
	} else {
		scan_enable.scan_enable = BTLE_SCAN_MODE_DISABLE;
It works fine, scanning is enabled / disabled for every timer callback call. However, I noticed that after scan disable (btle_scan_enable_set(..disable param..)) there is about 950uA current consumption.
I tested it in a following way: before an endless loop in the main() I'm invoking:
// current consumption before invoking timeslot_init() is about 0.01mA
timeslot_init()
  btle_err_code = btle_scan_param_set (scan_param);
  // enable scanning, current consumption here is about 11mA
   // wait for 2 sec
   nrf_delay_us(2000000);
   // disable scanning
   // ..after disable, current is about 950uA!
main()
   // some initialization here..
    timeslot_init();
    while(1) {
       sd_app_evt_wait();
       if(sw_interrupt()){
           // handling adv and resp packets
void SWI1_IRQHandler(void)
   sw_interrupt = true;
and I'm stuck.. I'm searching in TS source code and considering what can be disabled, but can't find anything.. (I'm using PCA10004 dev board for tests).
Could you please advise me what can I do?
Thanks!
