Segger Embedded Studio cannot find include
Using the nRF Connect SDK from Nordic Semiconductor is a terrible experience. One reason it being unreliable with many broken samples. And another being the Segger Embedded Studio, which takes ages to open a project, requires a reload every time a project is changed, forgets the project settings each time a new project is opened. Once we reach the point of building the project, many undefined symbol errors are reported during the linking phase. These can be resolved by adding correct CONFIG_ flags in the .prj file, yet this is is not obvious in any way, and finding the correct flags required by a project is a long and painful experience. Once we get past that point, and we try to program our application, Segger cannot find some headers. And it keeps asking again and again, I've had cases of more than 20-30 prompts. The whole process is extremely tedious and unproductive.
https://youtu.be/BOM5gGFlUQ8
    There is a lot of things here, but I will try to comment what I can.
    The nRF Connect SDK is a bit different then the nRF5 SDK, and many samples are part of Zephyr and not necessarily tested or integrated with nRF devices. Perhaps this is the problem here?
    Yes. To make configurations persistent, you would need to make the change in prj.conf (as you have noted). SES does not do this for you, unfortunately.
    If you use a sample project that would indicate that there is a problem with the toolchain. Can you specify which sample you use, from which NCS version, and how you installed the toolchain? If you are on Windows, then using the Toolchain manager which is part of nRF Connect for Desktop is the easiest way to install a functional toolchain.
    Lastly we have got some feedback that the nRF Connect SDK together with Segger Embedded Studio is not always very user friendly. We are noting the feedback and are looking into how to improve it in the future.
  • Hello Einar!
    What difference does that make to your clients who buy a large amount of chips and are expected to write software on top of the broken SDK? When Nordic offers an SDK with its hardware it is expected to work correctly. The most important samples that are broken are: connectivity_bridge and GPS. They even come precompiled with the firmware. It is a common use case, where the developer simply programs a ready sample on one of the CPUs and then develops code for the other (nRF9160 + nRF52840).
    https://devzone.nordicsemi.com/f/nordic-q-a/67372/connectivity_bridge-malfunctions-when-ble-client-disconnects-and-reconnects
    https://devzone.nordicsemi.com/f/nordic-q-a/68716/gps-stops-updating-timestamp-after-a-few-days-of-uptime-indoors/282807#282807
    Do you expect every developer to know this and also know how to do it? Have you tried switching between multiple projects? Every additional task we have to repeat has a negative impact on the productivity. Your team might want to work with Segger and improve this.
    Say we start from a copy of existing sample. Then add some posix calls or use some functions that are commonly used. We add the proper headers but the project fails to build because of missing symbols. The solution is to find that CONFIG_ flags needs to be defined in order for that symbol to become available. Of course we have no clue what config flags have to be added, and it's a long research and guess work. As a reference, on our own RTOS - EUROS, we just add the headers and everything just works. It's not a question on which particular samples or functions are used. Rather a matter of good and bad practices.
    The toolchain is installed from the nRF Connect GUI on both Windows and macOS.
    Alas the Nordic SDK is a very unproductive environment. Try using EUROS: https://www.euros-embedded.com/
    Another example: I wanted to make a small change to the GPS sample, so that a copy of the NMEA strings is sent to the second UART. Usually this should require three lines: 1. open UART, 2. check if valid, 3. send. The Zephyr API forced me to write 300 lines of code to achieve this simple thing. When the complexity is increased 100 times, I'm not surprised that many samples are broken. After trying to fix the connectiviry_bridge for over a week, I figured that's unreasonable. Porting and entire RTOS + UART driver took two days. And it's rock solid.
    Thank you for the feedback. I understand what you are saying, and you definitely have some valid points. I would say though that the nRF Connect SDK is still quite young, and we are working hard to improve all aspects of it, including quality and user friendliness.
