I want to try Zephyr on the nrf52dk_nrf52832. (PCA10040)
I can not get it to work.
If I try to use -DBOARD=nrf52dk_nrf52810 All is OK
Here is what I do:
cd ~/zephyr_test/hello_world
mkdir _bld; cd _bld
cmake -DBOARD=nrf52dk_nrf52810 ..
The Output is:
Including boilerplate (Freestanding): /home/joe/zephyrproject/zephyr/cmake/app/boilerplate.cmake
-- Application: /home/joe/zephyr_test/hello_world
-- Zephyr version: 2.4.99 (/home/joe/zephyrproject/zephyr)
-- Found Python3: /usr/bin/python3.7 (found suitable exact version "3.7.3") found components: Interpreter
-- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Board: nrf52dk_nrf52810
-- Cache files will be written to: /home/joe/.cache/zephyr
ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found toolchain: zephyr (/home/joe/zephyr-sdk-0.11.4)
-- Found dtc: /home/joe/zephyr-sdk-0.11.4/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/joe/zephyrproject/zephyr/boards/arm/nrf52dk_nrf52810/nrf52dk_nrf52810.dts
-- Generated zephyr.dts: /home/joe/zephyr_test/hello_world/_bld/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/joe/zephyr_test/hello_world/_bld/zephyr/include/generated/devicetree_unfixed.h
Parsing /home/joe/zephyrproject/zephyr/Kconfig
Loaded configuration '/home/joe/zephyrproject/zephyr/boards/arm/nrf52dk_nrf52810/nrf52dk_nrf52810_defconfig'
Merged configuration '/home/joe/zephyr_test/hello_world/prj.conf'
Configuration saved to '/home/joe/zephyr_test/hello_world/_bld/zephyr/.config'
Kconfig header saved to '/home/joe/zephyr_test/hello_world/_bld/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.0
-- The CXX compiler identification is GNU 9.2.0
-- Found assembler: /home/joe/zephyr-sdk-0.11.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Configuring done
-- Generating done
-- Build files have been written to: /home/joe/zephyr_test/hello_world/_bld
I then run make and all is OK.
Than (in another terminal window):
minicom -D /dev/ttyACM0 -b 115200
I'm Flashing the board:
nrfjprog -f nrf52 --program ./zephyr/zephyr.hex --sectorerase
And reset it:
nrfjprog -f nrf52 --reset
In minicom I get:
*** Booting Zephyr OS build zephyr-v2.4.0-1657-g5a58ad508cb3 ***
Hello World! nrf52dk_nrf52810
So far All is OK.
I then do:
rm -r *
cmake -DBOARD=nrf52dk_nrf52832 ..
And The Output is:
-- Board: nrf52dk_nrf52832
-- Found BOARD.dts: /home/joe/zephyrproject/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
Error: nrf52dk_nrf52832.dts.pre.tmp:415.3-4 syntax error
FATAL ERROR: Unable to parse input tree
CMake Error at /home/joe/zephyrproject/zephyr/cmake/dts.cmake:206 (message):
command failed with return code: 1
/home/joe/zephyrproject/zephyr/cmake/app/boilerplate.cmake:589 (include)
/home/joe/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/home/joe/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:102 (include_boilerplate)
CMakeLists.txt:5 (find_package)
****** And this is the end of the show ******
What is wrong?
Same Error with samples/basic/blinky and samples/bluetooth/beacon (the one I tested).
Guess it is the same with ALL "samples" that use "nrf52dk_nrf52832",
When I test with "nrf52dk_nrf52810", it is OK
