Recieving data with libuarte
I am going to transmit and receive data with libuarte. I read the libuarte example, but I am not quite sure my understanding of the data transfer process is correct.
In my opinion, it looks like "nrf_libuarte_async_tx" can do both transmitting and receiving data, the received data will be first pushed to the queue. Then when we want to process it, we just pop the data out. Is my understanding is correct? So based on this, I modified the uarte event handler as followed, which I use to get the received data and process it. Do you think my implementation is reasonable?
Please let me know if the initialization of my libuarte is needed, and thanks in advance for your help:D
static void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t *p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
    case NRF_LIBUARTE_ASYNC_EVT_ERROR:
    case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
        //recieve the data?
        ret = nrf_libuarte_async_tx(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
        if (ret == NRF_ERROR_BUSY)
            RxBuffer buf = {
                .p_data = p_evt->data.rxtx.p_data,
                .length = p_evt->data.rxtx.length,
            //push the data to the queue
            ret = nrf_queue_push(&RxBufferQueue, &buf);
            APP_ERROR_CHECK(ret);
        if (nrf_queue_is_empty(&RxBufferQueue) == false)
            RxBuffer buf;
            //pop the data from queue
            nrf_queue_pop(&RxBufferQueue, &buf);
            //Reset the queue
            nrf_queue_reset(&RxBufferQueue);
            //get the received data
            memcpy(rxdata, buf.p_data, buf.length);
            //process the received data
            processB2B(rxdata);
  • Leogean said:
    Thanks for your detailed explanation. So in my handler, because I do not want to send the received data back to the transmitter, the "nrf_uarte_async_tx" function is not necessary. Also, because I process the received data immediately, the queue functions are also not necessary. Am I right?
     Yes , your understanding is correct.
    Leogean said:
    Ah, the data type of the received data is "uint8_t*", I have just realized that, sorry.
     No worries. Good luck with your project.
