App_timer and RTC Calendar example confliction
I am using  timer ( created with app_timer and started with period of 1 sec ) and ported RTC calendar example in it . But both features do  not work together ( since RTC is used in both the example ) . I want to have a real time calendar which should print my current time with date -month- year and with that, periodically ,I need some timers( app timers) for sensor data acquisition and other task . So how can we achieve this ?
exampled used : ble_app_blinky  ( ported RTC calendar and app timer )
SDK version : 15.3.0
Hardware : Nordic NRF 52 DK ( PCA10040)
  • This doesn't tell me much unfortunately. Try adding DEBUG to your preprocessor definitions and check the log. If it still doesn't print anything where it points to a specific place in your project, try setting a breakpoint in the app_error_fault_handler() in app_error_weak.c. Try setting a breakpoint in the cases:
    case NRF_FAULT_ID_SDK_ASSERT:
    and
    case NRF_FAULT_ID_SDK_ERROR:
    Are any of them hit?
  • I have a app timer defined  inside system_clock_init() as ,
    app_timer_create(&m_repeated_timer_id1,
    APP_TIMER_MODE_REPEATED,
    timer_led_event_handler);
    app_timer_start(m_repeated_timer_id1, APP_TIMER_TICKS(1000), NULL);
    And this I am calling here in main.c
    // Initialize.
    log_init();
    clock_init();
    timers_init(); <<<<<<<<<<<<<<<<<<<<<<<<< app timer init
    system_clock_init(); <<<<<<<<<<<<<<<<< app timer create and start
    now just after this , I have added RTC calendar example code as ,
    uint8_t uart_byte;
    uint32_t year, month, day, hour, minute, second;
    //app_timer_pause();
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
    while(NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
    nrf_cal_init();
    nrf_cal_set_callback(calendar_updated, 4);
    while(1){
    print_current_time();
    nrf_delay_ms(1000);
    now this must print the date and time on UART as ,
    <info> app: Uncalibrated time: 01/01/70 - 00:00:00
    <info> app: Calibrated time: 01/01/70 - 00:00:00
    but just after this , it gives ,
    <error> app: Fatal error
    and this fatal error is because , I have started one app timer , once the timer expires after 1 second ,
    its not able to start again , it goes to RTC1_IRQHandler()  from below app_error_check .
    uint32_t err_code = app_sched_event_put(&timer_event, sizeof(timer_event), timeout_handler_scheduled_exec);
    Which means , app_sched_event_put function is returning error .
    And this function is defined in app_timer.c inside below function .
    static void timeout_handler_exec(timer_node_t * p_timer)
    hoping this will clarify your doubts .
  • FYI ,
    after enabling DEBUG , instead of Fatal error I am getting ,
    <error> app: ERROR 9 [NRF_ERROR_INVALID_LENGTH] at :0
    PC at: 0x00000000
    <error> app: End of error report
  • I have solved the issue .
    In the calendar example ,
    they are starting the LFCLK manually as below ,
    and I have ported this  code in ble_blinky where softdevice starts the LFCLK by it's own .
    So , we need to remove these lines of codes from two places , one from above and the other one from ,
    nrf_cal_init() function and make sure the calendar works on RTC2 , since app_timer uses RTC1 and softdevice  takes RTC0 .
    In this way we can able to run all three RTCs .
