SPIM transfer crashing on nRF5340
I'm developing a program using SPIM instance 1 on nRF5340 PDK, with nRF Connect SDK 1.4.0.
The problem I met is exactly the same as this post. If I want to use a handler, the SPI transfer will crash.
However, it seems I can not solve this problem on nRF5340 like the post above, as there is no nrfx_irqs header file for nRF5340 in the nrfx library.
So, is there any workaround to solve this?
    Sorry for not getting back to you sooner on this issue.
    You can find a working nrfx SPIM example with handler in this post. I tested the example by building it for nrf5340dk_nrf5340_cpuapp target, but I had to modify one function in main.c to the following:
    static void manual_isr_setup()
    #if defined(NRF9160_XXAA)
    	IRQ_DIRECT_CONNECT(UARTE1_SPIM1_SPIS1_TWIM1_TWIS1_IRQn, 0,
    			   nrfx_spim_1_irq_handler, 0);
    	irq_enable(UARTE1_SPIM1_SPIS1_TWIM1_TWIS1_IRQn);
    #elif defined(NRF5340_XXAA)
    	IRQ_DIRECT_CONNECT(SPIM1_SPIS1_TWIM1_TWIS1_UARTE1_IRQn, 0,
    	irq_enable(SPIM1_SPIS1_TWIM1_TWIS1_UARTE1_IRQn);
    #else
    	IRQ_DIRECT_CONNECT(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn, 0,
    	irq_enable(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn);
    Can you check if you are able to use this example?
    Jørgen
  • Thanks, Jørgen. With your code above, now I can get into a SPI handler successfully.
