TWIM EasyDMA Delay Between Bytes
I'm writing a library for the common Hitachi_HD44780 (LCD2004 etc) but need it to be non-blocking. I'll open source it once done. I'm using EasyDMA to do the transfers but the aging HD44780 needs a 50us delay in-between commands. My idea so far is;
1. set a timer with a period of 50us and a counter equal to the amount of bytes with a PPI to halt the timer and fire an interrupt to indicate "done"
2. timer period event fires EasyDMA which transfers one byte.
My question then is around EasyDMA List mode. Can I clarify that what it's doing is adding MAXCNT to the PTR object after each send?
In other words if I set MAXCNT = 1 and use list mode I should get the spaces inbetween the bytes without needing to interrupt to PTR++?
