buttonless dfu ble. error in uploading file.
nrf52810 used and sdk 15.3 used . i able to run my program without error and i even able connect my ble dfu. but i cant upload my zip file and i cant bond with nordic dfu. its showing invalid object. even i cant bond with device
  • Can you show me the full nrfutil command you use to build the zip package as well as the settings page? (no need for a screenshot, just copy-past the full commands - that gives better readability).
    Generally, the most important things for an APP update that relies on the SoftDevice is:
    • Specify the correct (existing) SoftDevice ID with --sd-req
    • Specify the correct application hex with --application
    • Specify a application version that is higher than what is currently installed using --application-version
    • specify the correct HW version (meaning same as you used when generating the settings page) using --hw-version
    • Sign with the correct private key using --key-file
    See Generating DFU packages for details.
  • nRF Connect, 2020-12-17
    DfuTarg (E0:6E:0D:23:1D:8E)
    I	15:33:34.503	[Server] Server started
    V	15:33:34.523	Heart Rate (0x180D)
    - Heart Rate Measurement [N] (0x2A37)
       Client Characteristic Configuration (0x2902)
    - Body Sensor Location [R] (0x2A38)
    - Heart Rate Control Point [W] (0x2A39)
    Unknown Service (0000aaa0-0000-1000-8000-aabbccddeeff)
    - Unknown Characteristic [N R] (0000aaa1-0000-1000-8000-aabbccddeeff)
       Unknown Descriptor (0000aab0-0000-1000-8000-aabbccddeeff)
       Characteristic User Description (0x2901)
       Characteristic Presentation Format (0x2904)
    - Unknown Characteristic [I W WNR] (0000aaa2-0000-1000-8000-aabbccddeeff)
    User Data (0x181C)
    - First Name [R W] (0x2A8A)
    - Last Name [R W] (0x2A90)
    - Gender [R W] (0x2A8C)
    V	15:33:35.249	Connecting to E0:6E:0D:23:1D:8E...
    D	15:33:35.249	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	15:33:35.284	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	15:33:35.284	[Server] Device with address E0:6E:0D:23:1D:8E connected
    D	15:33:35.295	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	15:33:35.295	Connected to E0:6E:0D:23:1D:8E
    D	15:33:35.352	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	15:33:35.352	Discovering services...
    D	15:33:35.352	gatt.discoverServices()
    I	15:33:35.738	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
    I	15:33:35.841	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	15:33:35.931	[Callback] Services discovered with status: 0
    I	15:33:35.931	Services discovered
    V	15:33:35.945	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    - Central Address Resolution [R] (0x2AA6)
    Generic Attribute (0x1801)
    Secure DFU Service (0xFE59)
    - DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
    - DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
    I	15:33:35.995	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
    V	15:33:44.149	[DFU] DFU service started
    V	15:33:44.149	[DFU] Opening file...
    I	15:33:44.160	[DFU] Firmware file opened successfully
    V	15:33:44.160	[DFU] Connecting to DFU target...
    D	15:33:44.160	[DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
    I	15:33:44.165	[DFU] Connected to E0:6E:0D:23:1D:8E
    V	15:33:44.166	[DFU] Discovering services...
    D	15:33:44.166	[DFU] gatt.discoverServices()
    I	15:33:44.176	[DFU] Services discovered
    D	15:33:44.194	[DFU] wait(1000)
    V	15:33:45.204	[DFU] Requesting new MTU...
    D	15:33:45.204	[DFU] gatt.requestMtu(517)
    I	15:33:45.215	[DFU] MTU changed to: 247
    V	15:33:45.215	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
    D	15:33:45.215	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
    D	15:33:45.216	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I	15:33:45.244	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
    V	15:33:45.244	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
    A	15:33:45.246	[DFU] Notifications enabled
    D	15:33:45.246	[DFU] wait(1000)
    V	15:33:46.247	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	15:33:46.247	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	15:33:46.279	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-01
    I	15:33:46.281	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-8D-00-00-00-80-7B-36-E2
    A	15:33:46.281	[DFU] Command object info received (Max size = 256, Offset = 141, CRC = E2367B80)
    A	15:33:46.281	[DFU] Received CRC match Init packet
    V	15:33:46.282	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	15:33:46.282	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	15:33:46.310	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	15:33:46.311	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	15:33:46.311	[DFU] Command object executed
    V	15:33:46.311	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	15:33:46.311	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	15:33:46.341	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-02
    I	15:33:46.341	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-10-00-00-00-00-00-00-00-00-00-00
    A	15:33:46.342	[DFU] Data object info received (Max size = 4096, Offset = 0, CRC = 00000000)
    V	15:33:46.394	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	15:33:46.394	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	15:33:46.459	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	15:33:46.460	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-08
    E	15:33:46.461	[DFU] Remote DFU error: OPERATION NOT PERMITTED
    V	15:33:46.461	[DFU] Disconnecting...
    D	15:33:46.461	[DFU] gatt.disconnect()
    I	15:33:46.479	[DFU] Disconnected
    D	15:33:46.479	[DFU] gatt.refresh() (hidden)
    D	15:33:46.479	[DFU] gatt.disconnect()
    D	15:33:46.479	[DFU] gatt.close()
    D	15:33:46.479	[DFU] wait(600)
    I	15:33:46.565	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	15:33:46.805	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
    I see you get a Remote DFU error: OPERATION NOT PERMITTED now. Not sure why that is. Did you change anything? In any case, please let me know how you generate the zip package with nrfutil as I mentioned in my previous reply. I suspect we will find something useful there (and again, if you would like more detailed errors, then testing with the debug bootloader would be better - just remember to modify it to use your own public key).
  • <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Settings OK
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20002B14)
    <debug> app: timer_activate (0x20002B14)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00022000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    <debug> nrf_dfu_ble: Connected
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_dfu_ble: max_conn_interval: 12
    <debug> nrf_dfu_ble: min_conn_interval: 12
    <debug> nrf_dfu_ble: slave_latency: 0
    <debug> nrf_dfu_ble: conn_sup_timeout: 600
    <debug> nrf_dfu_ble: max_conn_interval: 6
    <debug> nrf_dfu_ble: min_conn_interval: 6
    <debug> nrf_dfu_ble: conn_sup_timeout: 500
    <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
    <debug> app: timer_fire (0x20002B14)
    <info> app: Inactivity timeout.
    <debug> app: Resetting bootloader.
    <info> nrf_dfu_settings: Backing up settings page to address 0x2E000.
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0002E000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x20004A94, len=440 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 0
  • this is the error n computer i get while trying to upload a file. showing gatt error
