FDS event handler is not occur.
I am developing using nRF52820 / SDK 17.0.2
In order to store data in FDS, the handlers were registered and initialized as follows.
void BLE_Init(void)
	ble_stack_init();
	gap_params_init();
	gatt_init();
	advertising_init();
	services_init();
	conn_params_init();
	peer_manager_init();
	return;
static void FDS_Event_handler( fds_evt_t const * p_evt )
	SEGGER_RTT_printf(0, "FDS_Event_handler id : %d / result : %d\n", p_evt->id, p_evt->result);
    switch (p_evt->id)
        case FDS_EVT_INIT:
		case FDS_EVT_GC:
		case FDS_EVT_WRITE:
		case FDS_EVT_DEL_RECORD:
		case FDS_EVT_UPDATE:
int main( void )
	fds_record_desc_t desc = {0};
	fds_find_token_t  tok  = {0};
	fds_record_t RecordData;
	RecordData.file_id = DATA_FILE_ID;
	RecordData.key = DEFAULT_RKEY;
	RecordData.data.p_data = pData;
	RecordData.data.length_words = DATA_FILE_SIZE;
    BLE_Init();
    fds_register(FDS_Event_handler);
    if( fds_record_find( RecordData.file_id, RecordData.key, &desc, &tok ) == NRF_SUCCESS )
		if( fds_record_update( &desc, &RecordData ) == FDS_ERR_NO_SPACE_IN_FLASH )
			fds_gc();					// run garbage collection
			fds_record_update ( &desc, &RecordData );
FDS_Event_handler does not occur after fds_record_update().
Why the event is not occurring?
An event occurs when garbage collection is executed, but an event does not occur when FDS update.
And how can I check that the update is completed in queue process after the update?
I would like to know that the FDS update is complete without using a event handler if possible.
  • Hi.
    Sorry for the late reply
    I tested it as you told me.
    Softdevice event did not occur after FDS update was executed.
    00> BLE_GAP_EVT_CONNECTED
    00> PM_EVT_(0x05)
    00> PM_EVT_CONN_SEC_START
    00> PM_EVT_(0x05)
    00> PM_EVT_CONN_SEC_SUCCEEDED
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> Start FDS update
    I run an FDS update to store the Peer ID in FDS after pairing.
    But the FDS event handler(fds_evt_handler) I added doesn't executed.
    Is it because of the peer manager?
  • You should register all FDS users before fds_init() is called from pm_init(), but I don't think that is related to the problem. From the snippet you posted I noticed that you are not doing any error checks. Can you check if fds_record_update() is being called, and if it is returning an error code or not?
  • This is the log that added the FDS update error code.
    00>
    00> PM_EVT_(0x05)
    00> PM_EVT_(0x05)
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> FDS_Event_handler occurred. ID : 0x1, Result : 0x0
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> SoC event: 0x2.
    00> record update error code : 0x0
    FDS update is executed even at boot time, but in that case, FDS handler occurs normally.
  • I see the NRF_EVT_FLASH_OPERATION_SUCCESS events are reported several times when the PM updates data in FDS, but not when you update fds from main(). Does logging stop after the "record update error code : 0x0" line?
  • Yes, After executing fds_record_update(), it waits until FDS_Event_handler() occurs.
    This is to check if the FDS update is complete.
