DFU
I use a custom board, softdevice and boot loader.
I use DFU to update a slave chip firmware. Everything goes right until we invalidate and write flash :
        // Invalidate bank, marking completion.
        nrf_dfu_bank_invalidate(&s_dfu_settings.bank_1);
        uint32_t ret_val = nrf_dfu_settings_write_and_backup(NULL);
the nrf_dfu_settings_write_and_backup lead to a HARDFAULT handler because of accessing flash :
  • yes it my app that call nrf_dfu_settings_write_and_backup() at the end of our slave chip doanloading
  • Yes, please try again with NRF_DFU_IN_APP  set to 1 in the app. This is probably the reason for the hardfault.
  • in that case this part is not done :
    and the log message say this :
    nrf_dfu_settings: Copying forbidden parts from backup page.
    source, write not needed. Skipping.
    and so after a power off/power on the binary is written again, but I don't want this.
    Actually, what I want is the same behavior when my debugger is connected (the area can be written and all is fine)
    actually the only way I found to have a correct behavior was this : comment the flash protect in the bootloader
    //    ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR, area_size);
    //    ret_val = nrf_bootloader_flash_protect(0,
    //                    nrf_dfu_bank0_start_addr() + ALIGN_TO_PAGE(s_dfu_settings.bank_0.image_size));
  • Hi Vidar,
    maybe i found out why setting NRF_BL_DFU_ALLOW_UPDATE_FROM_APP is not enough in our case.
    actually I look in details the bootloader and found this :
        area_size = BOOTLOADER_SIZE + NRF_MBR_PARAMS_PAGE_SIZE;
        if (!NRF_BL_DFU_ALLOW_UPDATE_FROM_APP && !NRF_BL_DFU_ENTER_METHOD_BUTTONLESS && !NRF_DFU_TRANSPORT_BLE)
            area_size += BOOTLOADER_SETTINGS_PAGE_SIZE;
    in my case BOOTLOADER_SIZE is
    #define BOOTLOADER_SIZE (NRF_MBR_PARAMS_PAGE_ADDRESS - BOOTLOADER_START_ADDR)
    What I found is the following :
    actually it BOOTLOADER_START_ADDR  is 0x00078000 (in debug mode I look at nrf_bootloader_flash_protect() function)
    area_size is 0x7000.
    and so all the end of flash is then protected and then the bootloader settings as well.
    Maybe we have miss something here.
    Could you tell us more on this?
    Thanks
  • one more things
    in nrf_dfu_types.h i found this:
    #elif defined( NRF52832_XXAA )
        #define BOOTLOADER_SETTINGS_ADDRESS     (0x0007F000UL)
    and
    #elif defined(NRF52832_XXAA)
        #define NRF_MBR_PARAMS_PAGE_ADDRESS         (0x0007E000UL)
    so area_size = BOOTLOADER_SIZE + NRF_MBR_PARAMS_PAGE_SIZE
    BOOTLOADER_SIZE = (NRF_MBR_PARAMS_PAGE_ADDRESS - BOOTLOADER_START_ADDR)
    NRF_MBR_PARAMS_PAGE_ADDRESS = 0x7e000
    BOOTLOADER_START_ADDR = 0x78000
    so BOOTLOADER_SIZE  = 0x6000
    NRF_MBR_PARAMS_PAGE_SIZE = CODE_PAGE_SIZE
    CODE_PAGE_SIZE = 1024 * sizeof( uint32) == 1000
    area_size= 0x7000
    so evrything should work fine as the MBR settings start at 0x7f000.
    so why the nrf_dfu_settings_write_and_backup() function lead to hardfault handler ?
    maybe it try to access something that is not in BOOTLOADER settings but in MBR params?
