Pin confirmation
Hi All,
We are using nRF52840 MCU and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71. We are designing a device that uses switches connected to the below pins,
Pin used are below,
1) ExtSW2 - P0.26
2) Learn - P0.17
3) Optional1 - P0.13
4) Optional 2 - P0.15
5) Up - P1.10
6) Down - P1.13
Regarding the above pins in the product specification document ie.,nRF52840_PS_v1.1 they are mentioned as GPIO pins. But in pca10056.h file,
P0.13 is mapped to" LED1",
P0.26 is mapped to "SPI Master In Slave Out GPIO pin number",
P1.15 is mapped to "SPI READY GPIO pin number" as well as "UART Clear To Send pin number. Not used if HWFC is set to false.", and
P0.02 is mapped to "SPI MOSI signal
I have checked the main.c file they are not used but to avoid any further issue while developing code can you tell me whether I can use these pins or not.
If yes, then how can I use these all pins in the main file without altering pca10056.h file. Because if I do any change in pca10056.h file my entire project file will affect.
Please let me know how to use these pins as per my requirement or will it affect anything to my project.
And also, can I use these below-mapped pins as per requirement? Or Do need to take care of any changes? If yes, then please let me know what all required changes to be done so that below all pins are assessable without altering pca10056.h file or without affecting this file.
#define BSP_QSPI_SCK_PIN   19
#define BSP_QSPI_CSN_PIN   17
#define BSP_QSPI_IO0_PIN   20
#define BSP_QSPI_IO1_PIN   21
#define BSP_QSPI_IO2_PIN   22
#define BSP_QSPI_IO3_PIN   23
// serialization APPLICATION board - temp. setup for running serialized MEMU tests
#define SER_APP_RX_PIN              NRF_GPIO_PIN_MAP(1,13)    // UART RX pin number.
#define SER_APP_TX_PIN              NRF_GPIO_PIN_MAP(1,14)    // UART TX pin number.
#define SER_APP_CTS_PIN             NRF_GPIO_PIN_MAP(0,2)     // UART Clear To Send pin number.
#define SER_APP_RTS_PIN             NRF_GPIO_PIN_MAP(1,15)    // UART Request To Send pin number.
#define SER_APP_SPIM0_SCK_PIN       NRF_GPIO_PIN_MAP(0,27)     // SPI clock GPIO pin number.
#define SER_APP_SPIM0_MOSI_PIN      NRF_GPIO_PIN_MAP(0,2)      // SPI Master Out Slave In GPIO pin number
#define SER_APP_SPIM0_MISO_PIN      NRF_GPIO_PIN_MAP(0,26)     // SPI Master In Slave Out GPIO pin number
#define SER_APP_SPIM0_SS_PIN        NRF_GPIO_PIN_MAP(1,13)     // SPI Slave Select GPIO pin number
#define SER_APP_SPIM0_RDY_PIN       NRF_GPIO_PIN_MAP(1,15)     // SPI READY GPIO pin number
#define SER_APP_SPIM0_REQ_PIN       NRF_GPIO_PIN_MAP(1,14)     // SPI REQUEST GPIO pin number
// serialization CONNECTIVITY board
#define SER_CON_RX_PIN              NRF_GPIO_PIN_MAP(1,14)    // UART RX pin number.
#define SER_CON_TX_PIN              NRF_GPIO_PIN_MAP(1,13)    // UART TX pin number.
#define SER_CON_CTS_PIN             NRF_GPIO_PIN_MAP(1,15)    // UART Clear To Send pin number. Not used if HWFC is set to false.
#define SER_CON_RTS_PIN             NRF_GPIO_PIN_MAP(0,2)     // UART Request To Send pin number. Not used if HWFC is set to false.
#define SER_CON_SPIS_SCK_PIN        NRF_GPIO_PIN_MAP(0,27)    // SPI SCK signal.
#define SER_CON_SPIS_MOSI_PIN       NRF_GPIO_PIN_MAP(0,2)     // SPI MOSI signal.
#define SER_CON_SPIS_MISO_PIN       NRF_GPIO_PIN_MAP(0,26)    // SPI MISO signal.
#define SER_CON_SPIS_CSN_PIN        NRF_GPIO_PIN_MAP(1,13)    // SPI CSN signal.
#define SER_CON_SPIS_RDY_PIN        NRF_GPIO_PIN_MAP(1,15)    // SPI READY GPIO pin number.
#define SER_CON_SPIS_REQ_PIN        NRF_GPIO_PIN_MAP(1,14)    // SPI REQUEST GPIO pin number.
#define SER_CONN_CHIP_RESET_PIN     NRF_GPIO_PIN_MAP(1,1)    // Pin used to reset connectivity chip
// Arduino board mappings
#define ARDUINO_SCL_PIN             27    // SCL signal pin
#define ARDUINO_SDA_PIN             26    // SDA signal pin
#define ARDUINO_AREF_PIN            2     // Aref pin
#define ARDUINO_13_PIN              NRF_GPIO_PIN_MAP(1, 15)  // Digital pin 13
#define ARDUINO_12_PIN              NRF_GPIO_PIN_MAP(1, 14)  // Digital pin 12
#define ARDUINO_11_PIN              NRF_GPIO_PIN_MAP(1, 13)  // Digital pin 11
#define ARDUINO_10_PIN              NRF_GPIO_PIN_MAP(1, 12)  // Digital pin 10
#define ARDUINO_9_PIN               NRF_GPIO_PIN_MAP(1, 11)  // Digital pin 9
#define ARDUINO_8_PIN               NRF_GPIO_PIN_MAP(1, 10)  // Digital pin 8
#define ARDUINO_7_PIN               NRF_GPIO_PIN_MAP(1, 8) // Digital pin 7
#define ARDUINO_6_PIN               NRF_GPIO_PIN_MAP(1, 7) // Digital pin 6
#define ARDUINO_5_PIN               NRF_GPIO_PIN_MAP(1, 6) // Digital pin 5
#define ARDUINO_4_PIN               NRF_GPIO_PIN_MAP(1, 5) // Digital pin 4
#define ARDUINO_3_PIN               NRF_GPIO_PIN_MAP(1, 4) // Digital pin 3
#define ARDUINO_2_PIN               NRF_GPIO_PIN_MAP(1, 3) // Digital pin 2
#define ARDUINO_1_PIN               NRF_GPIO_PIN_MAP(1, 2) // Digital pin 1
#define ARDUINO_0_PIN               NRF_GPIO_PIN_MAP(1, 1) // Digital pin 0
#define ARDUINO_A0_PIN              3     // Analog channel 0
#define ARDUINO_A1_PIN              4     // Analog channel 1
#define ARDUINO_A2_PIN              28    // Analog channel 2
#define ARDUINO_A3_PIN              29    // Analog channel 3
#define ARDUINO_A4_PIN              30    // Analog channel 4
#define ARDUINO_A5_PIN              31    // Analog channel 5
Please let me know your feedback on the same. It is very urgent for me to confirm the hardware point of view.
Thanks and Regards
Rohit R
    Okay, thank you for the feedback.
    I will follow the steps and in case of any queries, I will get back to you.
    Thanks and Regards
    Rohit R
    There is a change in pin usage.
    The hardware team decided to use the below pin as switch configuration
    P0.26, P0.12, P0.13, P0.15, P0.17, P1.10, and P1.13 as switch pins.
    P0.02 and P1.15 as LED pins.
    above pins, I can map as per requirement?
    P0.17 but I tried to connect button and read interrupt, I am not able to get interrupted on this pin.
    Meanwhile, I have checked pca10056.h file and found that P0.17 is mapped to "#define BSP_QSPI_CSN_PIN   17"
    means I can not use these pins correct?
    Thanks and Regards
    Rohit R
    Yes, but P0.12 is used for button on DK, and P0.13/P0.15 is connected to LEDs. Make sure you either use them as specificed in pca10056.h together with BSP, or modify the board header to remove LEDs/BUTTONs or move to other pins.
    On the DK, P0.17 is connected to the QSPI external memory chip, and is disconnected from the pin headers by default. You can use it, but you need to cut/solder the solder bridges in order to disconnect from memory and connect to pin headers.
