nRF Mesh Crashes on Android when receiving Mesh Messages via Publish in Vendor Model
When I publish messages to the mesh network via a Vendor Model, after connecting to device and performing a successful vendor command sequence, I start sending publishes of sensor data to the mesh and get a few different crashes.  The stack trace of the first one is as follows:
D/AndroidRuntime: Shutting down VM
E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.gamechanger.android.gcmonitor, PID: 29713
java.lang.NullPointerException: Attempt to invoke virtual method 'int no.nordicsemi.android.mesh.transport.ProvisionedMeshNode.incrementSequenceNumber()' on a null object reference
at no.nordicsemi.android.mesh.transport.LowerTransportLayer.sendBlockAck(LowerTransportLayer.java:745)
at no.nordicsemi.android.mesh.transport.LowerTransportLayer.handleImmediateBlockAcks(LowerTransportLayer.java:544)
at no.nordicsemi.android.mesh.transport.LowerTransportLayer.parseSegmentedAccessLowerTransportPDU(LowerTransportLayer.java:513)
at no.nordicsemi.android.mesh.transport.NetworkLayer.parseAccessMessage(NetworkLayer.java:319)
at no.nordicsemi.android.mesh.transport.NetworkLayer.parseMeshMessage(NetworkLayer.java:268)
at no.nordicsemi.android.mesh.transport.DefaultNoOperationMessageState.parseMeshPdu(DefaultNoOperationMessageState.java:60)
at no.nordicsemi.android.mesh.transport.BaseMeshMessageHandler.parseMeshPduNotifications(BaseMeshMessageHandler.java:147)
at no.nordicsemi.android.mesh.MeshMessageHandler.parseMeshPduNotifications(MeshMessageHandler.java:61)
at no.nordicsemi.android.mesh.MeshManagerApi.parseNotifications(MeshManagerApi.java:304)
at no.nordicsemi.android.mesh.MeshManagerApi.handleNotifications(MeshManagerApi.java:276)
at com.gamechanger.android.gcmonitor.viewmodels.NrfMeshRepository.onDataReceived(NrfMeshRepository.java:476)
at com.gamechanger.android.gcmonitor.ble.BleMeshManager$1.lambda$initialize$0$BleMeshManager$1(BleMeshManager.java:116)
at com.gamechanger.android.gcmonitor.ble.-$$Lambda$BleMeshManager$1$8MkBenSGVpQpWecQfKpVn56TTv0.onDataReceived(Unknown Source:2)
at no.nordicsemi.android.ble.ValueChangedCallback.notifyValueChanged(ValueChangedCallback.java:123)
at no.nordicsemi.android.ble.BleManager$BleManagerGattCallback.onCharacteristicChangedSafe(BleManager.java:2884)
at no.nordicsemi.android.ble.MainThreadBluetoothGattCallback.lambda$onCharacteristicChanged$4$MainThreadBluetoothGattCallback(MainThreadBluetoothGattCallback.java:135)
at no.nordicsemi.android.ble.-$$Lambda$MainThreadBluetoothGattCallback$R_hGfDgzC1ieM6HXyW_Z9E0hTuU.run(Unknown Source:8)
at android.os.Handler.handleCallback(Handler.java:883)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:237)
at android.app.ActivityThread.main(ActivityThread.java:8167)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:496)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1100)
I/Process: Sending signal. PID: 29713 SIG: 9
I have additional logs, it appears to crash in the nordic mesh library.
Let me know if you need further information. I am using an nrf52840 DK and the latest NCS with Zephyr to implement Mesh.
  • If I skip step 3 it does not crash, but I don't get any vendor mesh messages either.
  • static const struct bt_mesh_model_op vnd_ops[] = {
    	{ BT_MESH_MODEL_OP_3(0x01, CID_ZEPHYR), 0, vnd_get },
    	{ BT_MESH_MODEL_OP_3(0x02, CID_ZEPHYR), 3, vnd_set },
    	{ BT_MESH_MODEL_OP_3(0x03, CID_ZEPHYR), 3, vnd_set_unack },
    	{ BT_MESH_MODEL_OP_3(0x04, CID_ZEPHYR), 6, vnd_status },
    	{ BT_MESH_MODEL_OP_3(0x05, CID_ZEPHYR), 4, vnd_data },
    	BT_MESH_MODEL_OP_END,
    struct bt_mesh_model vnd_models[] = {
    	BT_MESH_MODEL_VND(CID_ZEPHYR, 0x4321, vnd_ops,
    			  &vnd_pub, &vnd_user_data),
    Simple Model
    and a simple publish function called periodically
    void vnd_publish(struct sensor_value value[3], bool publish) {
    	struct vendor_state *state = vnd_models[0].user_data;
            struct bt_mesh_model_pub *pub = (&vnd_pub);
            //Copy new data
            for (int sample = 0; sample < 3; sample++)
              //TODO: reevaluate this conversion on samples!
              state->data.samples[0].imu.acc[sample] = (value[sample].val1 << 8) | value[sample].val2;
      if (publish) {
    	bt_mesh_model_msg_init(pub->msg, BT_MESH_MODEL_OP_3(0x05, CID_ZEPHYR));
            for (int index = 0; index < NUM_OF_SAMPLES; index++) {
              //IMU Data Output
              net_buf_simple_add_le32(pub->msg, state->data.samples[index].imu.timestamp++);
                net_buf_simple_add_le16(pub->msg, state->data.samples[index].imu.acc[sample]);
            int ret = bt_mesh_model_publish(&vnd_models[0]);
    	if (ret) {
    		printk("Unable to publish %d\n", ret);
  •  thanks for the detailed information. I will give this a shot and get back to you. Is there any chance. should the 5th step be done from the firmware side? are you using your own vendor model here?
  • Yes, Step 5 is from NRF52840 dev board, and the vendor model that I am currently testing with is as shown in the code above.
  • Hi I have received a pull request on Github that might fix your issue. I think the library was trying to send block acknowledgements to a non-unicast addresses. I see that the crash you had was also in block acknowledgements for sensor messages published via 0xC000, when the library tried to increment the sequence number for a non-unicast address. Could you please try the latest dev branch and see if it works for you?
