Facing issues when running a simple Free rtos Button LED
I am a beginner to Free RTOS. so I have tried to build a simple button led project. When I press the button it should light up the LED.  I implemented this similar model in sequential programming. It is successful but in Free rtos I couldnt comprehend where I am going wrong. To check whether a scheduler is working or not, I have written a simple blinky led it is working.  How ever button,led tasks couldnt able to run.could some one please help me where I am going wrong?
#include <stdbool.h>
#include <stdint.h>
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "bsp.h"
#include "nordic_common.h"
#include "nrf_drv_clock.h"
#include "sdk_errors.h"
#include "app_error.h"
#include "nrf_gpio.h"
#define TASK_DELAY 200
#define led 13
#define button 11
TaskHandle_t  led_toggle_task_handle;
#define true 1
#define false 0
#define not_pressed false
#define pressed true
uint8_t button_status_flag=not_pressed;
static void setup_hardware(void)
nrf_gpio_cfg_output(led);
nrf_gpio_cfg_input(button,NRF_GPIO_PIN_PULLUP);
nrf_gpio_pin_set(led);
static void led_toggle_task_function (void * pvParameter)
    UNUSED_PARAMETER(pvParameter);
    while (true)
        bsp_board_led_invert(BSP_BOARD_LED_2);
        /* Delay a task for a given number of ticks */
        vTaskDelay(TASK_DELAY);
        /* Tasks must be implemented to never return... */
static void led_task_handler(void * params)
    while(1)
      if(button_status_flag == pressed)
      nrf_gpio_pin_clear(led);//lights LED.
static void button_task_handler(void * params)
    while(1)
      if(nrf_gpio_pin_read(button))
      button_status_flag=pressed;
    ret_code_t err_code;
    /* Initialize clock driver for better time accuracy in FREERTOS */
    err_code = nrf_drv_clock_init();
    /* Configure LED-pins as outputs */
  //  bsp_board_init(BSP_INIT_LEDS);
    setup_hardware();
     xTaskCreate(led_toggle_task_function, "LED2", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task_handle);
    xTaskCreate(led_task_handler,"LED-TASK",configMINIMAL_STACK_SIZE,NULL,1,NULL);
     xTaskCreate(button_task_handler,"BUTTON-TASK",configMINIMAL_STACK_SIZE,NULL,1,NULL);
    /* Activate deep sleep mode */
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    /* Start FreeRTOS scheduler. */
    vTaskStartScheduler();
    while (true)
        /* FreeRTOS should not be here... FreeRTOS goes back to the start of stack
         * in vTaskStartScheduler function. */
  • Hi Susheel,,
                            Thanks for your response.
    Why do you have a while(1) in your button_task_handler?
    I have kept a while(1) becuase I want to implement this logic in free rtos. I am with an impression that, every task in free rrtos needs to have a  while(1) loop.
    I want to implement button , led as a two separate tasks running on freertos. so I tried to implement them as tasks!!
  • Well, you have made no connection to the button/gpio handler to your task. I think instead of making this a task, you need to make this a button_callback handler that gets called from the button handler library when you press the button.
    Please read mode about the button library in the link i mentioned in my previous reply and the code snippet to aid to understand it.
