How to discover custom service of peripheral
Hi, Nordic staff.
I'm working with Central device using S132.
There is a peripheral device using S112 in Nordic. I didn't make this peripheral.
My question is that is it possible to discover above service and some characteristics uuid from S132 central?
If possible, can tell me how should I do?
Best regards.
  • Thank you. That's why I made it separately.
    Is this the right way to do it?
    But it hasn't been resolved...
    What should I do... ...TT.
    void MJR_c_on_db_disc_evt(ble_nus_c_t * p_ble_nus_c, ble_db_discovery_evt_t * p_evt)
        ble_nus_c_evt_t nus_c_evt;
        memset(&nus_c_evt,0,sizeof(ble_nus_c_evt_t));
        ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
        // Check if the NUS was discovered.
        if (    (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
            &&  (p_evt->params.discovered_db.srv_uuid.uuid == MJR_LE_SERVICE_UUID)
            &&  (p_evt->params.discovered_db.srv_uuid.type == NUS_SERVICE_UUID_TYPE))
            uint32_t i;
            for (i = 0; i < p_evt->params.discovered_db.char_count; i++)
                switch (p_chars[i].characteristic.uuid.uuid)
                    case MJR_LE_NOTIFYCATION_UUID:
                        nus_c_evt.handles.nus_rx_handle = p_chars[i].characteristic.handle_value;
                    case MJR_LE_WRITE_NO_RESPONSE_UUID:
                        nus_c_evt.handles.nus_tx_handle = p_chars[i].characteristic.handle_value;
                        nus_c_evt.handles.nus_tx_cccd_handle = p_chars[i].cccd_handle;
            if (p_ble_nus_c->evt_handler != NULL)
                nus_c_evt.conn_handle = p_evt->conn_handle;
                nus_c_evt.evt_type    = BLE_NUS_C_EVT_DISCOVERY_COMPLETE;
                p_ble_nus_c->evt_handler(p_ble_nus_c, &nus_c_evt);
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        // ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
        MJR_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
  • And your ble_evt_handler ()  should be ex:
    Depend on your case
    static void gatt_c_evt_handler(ble_gatt_c_t * p_gatt_c, ble_gatt_c_evt_t * p_gatt_c_evt)
    switch (p_gatt_c_evt->evt_type)
    case BLE_GATT_C_EVT_DISCOVERY_COMPLETE:
    ret_code_t err_code;
    NRF_LOG_INFO("BBQ BLE probe service discovered on conn_handle 0x%x\r\n",
    p_gatt_c_evt->conn_handle);
    err_code = app_button_enable();
    // GATT service discovered. Enable notification of Read.
    err_code = ble_gatt_c_read1_notif_enable(p_gatt_c);
    err_code = ble_gatt_c_read2_notif_enable(p_gatt_c);
    } break; // BLE_GATT_C_EVT_DISCOVERY_COMPLETE
    case BLE_GATT_C_EVT_TEMPERATURE_NOTIFICATION:
    data_state ^= p_gatt_c_evt->params.button.button_state;
    NRF_LOG_INFO("Link 0x%x, Data state changed on peer to 0x%x\r\n",
    p_gatt_c_evt->conn_handle,
    data_state);
    if (temp_T1>=0)
    BLE_probe[p_gatt_c_evt->conn_handle].probe_T1 = temp_T1*10;
    BLE_probe[p_gatt_c_evt->conn_handle].probe_T1 = 4000+abs(temp_T1)*10;
    if (temp_T2>=0)
    BLE_probe[p_gatt_c_evt->conn_handle].probe_T2 = temp_T2*10;
    BLE_probe[p_gatt_c_evt->conn_handle].probe_T2 = 4000+abs(temp_T2)*10;
    BLE_probe[p_gatt_c_evt->conn_handle].respon_time = temp_respon_time;
    if (data_state==0xff)
    bsp_board_led_on(LEDBUTTON_LED);
    bsp_board_led_off(LEDBUTTON_LED);
    } break; // BLE_GATT_C_EVT_BUTTON_NOTIFICATION
    case BLE_GATT_C_EVT_STATUS_NOTIFICATION:
    char temp_str[64]={0};
    if (p_gatt_c_evt->params.button.button_state==0)
    strcpy(temp_str,"Battery good.");
    BLE_probe[p_gatt_c_evt->conn_handle].batt_status = 0xff;
    strcpy(temp_str,"Low Battery.");
    BLE_probe[p_gatt_c_evt->conn_handle].batt_status = 0x00;
    NRF_LOG_INFO("Link 0x%x, Battery status: %s\r\n",
    (uint32_t)temp_str);
    check_sum=0;
    check_sum = BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[5]+BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[4]+BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[3]
    +BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[2]+BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[1]+BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[0]
    +BLE_probe[p_gatt_c_evt->conn_handle].ble_name[0]+BLE_probe[p_gatt_c_evt->conn_handle].ble_name[1]+BLE_probe[p_gatt_c_evt->conn_handle].ble_name[2]
    +BLE_probe[p_gatt_c_evt->conn_handle].ble_name[3]+BLE_probe[p_gatt_c_evt->conn_handle].ble_name[4]+BLE_probe[p_gatt_c_evt->conn_handle].connect_ID
    +BLE_probe[p_gatt_c_evt->conn_handle].disconn_code+(BLE_probe[p_gatt_c_evt->conn_handle].probe_T1>>8)+(BLE_probe[p_gatt_c_evt->conn_handle].probe_T1&0xff)
    +(BLE_probe[p_gatt_c_evt->conn_handle].probe_T2>>8)+(BLE_probe[p_gatt_c_evt->conn_handle].probe_T2&0xff)+BLE_probe[p_gatt_c_evt->conn_handle].batt_status
    +BLE_probe[p_gatt_c_evt->conn_handle].respon_time;
    sprintf(uart_tx_buff,"CT probe%d=%02x%02x%02x%02x%02x%02x,%s,%d,%x,%x,%x,%x,%x,%x\r\n",p_gatt_c_evt->conn_handle+1,BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[5],
    BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[4],BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[3],BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[2],BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[1],BLE_probe[p_gatt_c_evt->conn_handle].ble_mac[0],
    BLE_probe[p_gatt_c_evt->conn_handle].ble_name,BLE_probe[p_gatt_c_evt->conn_handle].connect_ID,BLE_probe[p_gatt_c_evt->conn_handle].disconn_code,BLE_probe[p_gatt_c_evt->conn_handle].probe_T1,BLE_probe[p_gatt_c_evt->conn_handle].probe_T2,
    BLE_probe[p_gatt_c_evt->conn_handle].batt_status,BLE_probe[p_gatt_c_evt->conn_handle].respon_time,check_sum);
    uart_serial_tx((uint8_t *)uart_tx_buff,strlen(uart_tx_buff));
    //dbt_printf("%s",uart_tx_buff);
    } break; // BLE_GATT_C_EVT_STATUS_NOTIFICATION
    // No implementation needed.
  • Defined as "ble_nus_c_evt_handler"
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                printf("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                printf("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
                printf("BLE_NUS_C_EVT_NUS_TX_EVT\n");
            case BLE_NUS_C_EVT_DISCONNECTED:
                printf("Disconnected.");
                scan_start();
                printf("client evt handler\r");
    "nus_c_evt_handler" is used in "nus_c_init".
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler   = ble_nus_c_evt_handler;
        init.error_handler = nus_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
