Inverting PWM in nRF52840 pinn
I want to output in one pin 400kHz and inverse of 400kHz in the other pin. I have somehow managed to output the the 400kHz but haven't managed to output its inverse.
Here is my code:
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define m_top     20
#define m_step    1
#define  led_external  26
#define  led_reversed  27
static nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
uint16_t step = m_top / m_step;
static nrf_pwm_values_common_t sequence_values[m_step * 2];
uint16_t value = 0;
static void pwm_common_init(void)
    for(int i = 0; i<m_step; i++)
      value += step;
      sequence_values[i] = value;
      sequence_values[m_step + i] = m_top - value;
    nrfx_pwm_config_t const config0 =
      .output_pins =
          led_external,
          led_reversed| NRFX_PWM_PIN_INVERTED,
          NRFX_PWM_PIN_NOT_USED,
      .irq_priority = APP_IRQ_PRIORITY_LOWEST,
      .base_clock   = NRF_PWM_CLK_16MHz,
      .count_mode   = NRF_PWM_MODE_UP,
      .top_value    = m_top,
      .load_mode    = NRF_PWM_LOAD_COMMON,
      .step_mode    = NRF_PWM_STEP_AUTO
    APP_ERROR_CHECK(nrfx_pwm_init(&m_pwm0, &config0, NULL));
static void pwm_play(void)
  nrf_pwm_sequence_t const seq0 =
    .values  = sequence_values,
    .length           = NRF_PWM_VALUES_LENGTH(sequence_values),
    .repeats          = 0,
    .end_delay        = 0
  (void)nrfx_pwm_simple_playback(&m_pwm0, &seq0, 1, NRFX_PWM_FLAG_LOOP);
static void log_init(void)
log_init();
pwm_common_init();
pwm_play();
  NRF_LOG_INFO("PWM application started!!");
I was looking into the previous answers but I wasn't able to still apply their solution into my program. From what I know so far is that "NRFX_PWM_PIN_INVERTED" only works in idle state and that "seq_values->channel_0 = duty_cycle | 0x8000" is a possible answer but I am not sure how to integrate that in my program.
Asking for help/advice how to integrate 400kHz output in pin 0.26 and inverse 400kHz frequency in pin 0.27 of nRF52840 board thru modifying my code?
  • GROUPED or WAVEFORM or SINGLE
    Which one of them should I use? and how could I integrate them to my code? what changes will I make?
  • Try this, not tested:
    With "step" as the number of discrete PWM changes, Change
    to
    static nrf_pwm_values_common_t sequence_values[step * 2];
    Change
    to
        for(int i = 0; i<step*2; i+=2)
    Change
          value += step;
          sequence_values[i+1] = value;
    to
          value += m_step;
          sequence_values[i+1] = value | 0x8000;
          .output_pins =
    Change
              led_external,
    To
              led_external,
          .top_value    = m_top,
    Change
    To
          .load_mode    = NRF_PWM_LOAD_GROUPED,
    Not totally sure what waveform you want, but these changes allow a PWM output and inverted PWM output ramping from low duty cycle to max duty cycle. The pins order changes because of the mapping for the different modes; GROUPED uses 2 entries per step controlling 2 pins each.
    In the code you posted it looks like you used m_step erroneously instead of step
  • Thank you so far it's working..a bit better, I can see the inverted PWM. Is there a possible way to get constant 50% duty cycle? The program is somehow making the pwm "glitchy"
    I made one example that shows how to get 50% with GROUPED mode. Suggest you refer to nrf52840 ps section PWM and nRF52 nRF5 SDK example pwm_driver to learn how to use PWM peripheral on nRF52 devices.
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
    #define m_top     20
    #define m_step    1
    #define  led_reversed  27|NRFX_PWM_PIN_INVERTED
    static nrf_pwm_values_grouped_t sequence_values[]=    {
            { 0x8000, 0 },
            { 0, 0x8000 }
    uint16_t value = 0;
          .output_pins =
              led_external,
          .top_value    = m_top,
        .values.p_grouped  = sequence_values,
        .repeats          = 0,
        .end_delay        = 0
    log_init();
    pwm_common_init();
    pwm_play();
  • 50% with GROUPED mode
    If I needed 80% duty cycle, is that still possible in the program? or do I have to change something like the GROUPED mode into another example Individual?
