How to send data to own AWS server using Cloud Client sample ?
HI All
Actually I need to send GPS data to own AWS server so from here I setup AWS server and use cloud client sample and follow the step
like
1) change the cloud backend to the AWS_IOT
2) Enable AWS IOT setting and added ID, HOSTNAME and SEC TAG.
3) Updated the modem certificates.
but get an error.
this my Kconfig
# Copyright (c) 2020 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
menu "Cloud Client Sample Settings"
config CLOUD_BACKEND
	string "Selects the cloud backend to be used"
	default "AWS_IOT"
	help
	  Possible values are "NRF_CLOUD", "AWS_IOT", "AZURE_IOT_HUB".
config AWS_IOT_BROKER_HOST_NAME
	string "AWS IoT MQTT broker hostname"
	default "a6i4ulevbqzm-ats.iot.us-east-2.amazonaws.com"
	help
	  Default is set to be the nRF Cloud MQTT broker.
config AWS_IOT_CLIENT_ID_STATIC
	string "Client ID"
	default "nrf-352656101080789"
config AWS_IOT_SEC_TAG
	int "Security tag for TLS credentials"
	default 111
config MQTT_BROKER_PORT
	int "AWS IoT MQTT broker port"
	default 8883
config CLOUD_MESSAGE
	string "Sets the custom message published periodically to cloud"
	default "{\"state\":{\"reported\":{\"message\":\"Hello Internet of Things!\"}}}"
config CLOUD_MESSAGE_PUBLICATION_INTERVAL
	int "Sets how often the custom message should be published to cloud, in seconds"
	default 10
config CLOUD_CONNECTION_RETRY_TIMEOUT_SECONDS
	int "Sets the number of seconds between each cloud connection retry"
	default 30
choice
	prompt "Cloud Publication Trigger"
	default CLOUD_PUBLICATION_BUTTON_PRESS
config CLOUD_PUBLICATION_BUTTON_PRESS
	bool "Triggers publication to cloud upon a button press"
config CLOUD_PUBLICATION_SEQUENTIAL
	bool "Sets sequential publication to cloud set by the CONFIG_MESSAGE_PUBLICATION_INTERVAL option"
endchoice
config POWER_SAVING_MODE_ENABLE
	bool "Requests PSM from cellular network"
endmenu
module = CLOUD_CLIENT
module-str = Cloud client
source "${ZEPHYR_BASE}/subsys/logging/Kconfig.template.log_config"
menu "Zephyr Kernel"
source "Kconfig.zephyr"
endmenu
this my prj.config
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_NCS_SAMPLES_DEFAULTS=y
# Log level
# For more verbose and detailed log output, set the log level to
# CONFIG_CLOUD_CLIENT_LOG_LEVEL_DBG=y instead.
CONFIG_CLOUD_CLIENT_LOG_LEVEL_INF=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
# DK
CONFIG_DK_LIBRARY=y
# AT commands interface
CONFIG_AT_HOST_LIBRARY=y
# Generic cloud API
CONFIG_CLOUD_API=y
# Selected cloud backend
CONFIG_CLOUD_BACKEND="AWS_IOT"
# nRF Cloud
CONFIG_NRF_CLOUD=n
# CONFIG_NRF_CLOUD_CONNECTION_POLL_THREAD=y
# AWS IoT
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_STATIC="nrf-352656101080789"
CONFIG_AWS_IOT_BROKER_HOST_NAME="a6i4ulevbqzm-ats.iot.us-east-2.amazonaws.com"
CONFIG_AWS_IOT_SEC_TAG=111
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
CONFIG_AWS_IOT_CONNECTION_POLL_THREAD=y
# Azure IoT Hub
# CONFIG_AZURE_IOT_HUB=y
# CONFIG_AZURE_IOT_HUB_DEVICE_ID="my-device"
# CONFIG_AZURE_IOT_HUB_HOSTNAME="example.endpoint.com"
# CONFIG_AZURE_IOT_HUB_SEC_TAG=10
# Heap and stacks
# Extended memory heap size needed for encoding nRF Cloud messages to JSON
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=4096
is there any i need to change?
Thanks & Regards
Iand Prj.config file
    jaydip kavaiya said:
    The only problem with modem LTE configuration.
    What is the issue with the modem configuration?
    As per your suggestion I use PSM mode so get GPS data and after send data to AWS
    in Modem_configuration getting error.
    Can you please provide the error code you get?
    Øyvind
  • HI Oyvind
    Thanks you for your Support and all valuable answer
    problem is solved, Now I get the GPS data and also send to my AWS server
    for just now I am only doing basic not use PSM mode(for PSM mode definitely need your help),
    but from use of below step I did it successfully.
    Step 1: Init_app as it is use in GPS sample code
    Step 2: Get GPS data after some time (3 min)
    Step 3: Close the GPS socket
    Step 4:  send this command
                 (i) AT+CFUN=4
                 (ii) AT%XSYSTEMMODE=1,0,0,0
                 (iii) AT+CFUN=1"
    Step 5: Modem confgi as it is in AWS sample code
    Thanks & Regards
    Jaydip Kavaiya
