So what I understand from the lesson over here is that we have couple of timers available to us and each timer comprise of multiple compare/capture register which can be used to generate and service an interrupt when the value of CC register is equal to the set value. In the following code I am trying to implement this feature to toggle two different LEDs using two CC register. I have set the value in CC by converting ms to ticks. Essentially telling timer to service interrupts when values in CC register equals x milliseconds hence toggeling LEDs at different time intervals in correspondence to CC registers values . I am not sure what I am doing wrong. Would love to know if there is some concept I need to understand.
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
#define LED1 17
#define LED2 18
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
void timer0_handler(nrf_timer_event_t event_type, void *p_context)
switch(event_type)
case NRF_TIMER_EVENT_COMPARE0:
nrf_gpio_pin_toggle(LED1);
case NRF_TIMER_EVENT_COMPARE1:
nrf_gpio_pin_toggle(LED2);
//nothing
void timer_init(void)
uint32_t err_code = NRF_SUCCESS;
uint32_t time_ms = 100;
uint32_t time_ms2 = 500;
uint32_t time_ticks;
uint32_t time_ticks2;
nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG; // Default timer config
err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer0_handler); // init the timer with custom timer instance, config and handler for it
time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms); // convert ms to ticks so that timer compare register can generate interprit
time_ticks2 = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms2); // convert ms to ticks so that timer compare register can generate interprit
nrf_drv_timer_extended_compare(&TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
nrf_drv_timer_extended_compare(&TIMER_LED, NRF_TIMER_CC_CHANNEL1, time_ticks2, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
nrf_gpio_cfg_output(LED1);
nrf_gpio_cfg_output(LED2);
nrf_gpio_pin_set(LED1);
nrf_gpio_pin_set(LED2);
timer_init();
nrf_drv_timer_enable(&TIMER_LED);
while (1)
__WFI();
